Question about Watts Onan Portable Generator - 4000 , Model# 5500
I have a Onan 7.5 from 1998. only 80 hours on it. Would turn over very slow and would not start. Will not turn at all now. Fuel pump and celinoid kick in. Took out starter had it tested and it was ok. What to do next?
    Scholar:
  • 142 Answers
If you have it for 12 years, it ran only 80 hours, it may have got rusty.
If you can open generator back cover, try to see the condition of generator iron (stator and rotor).Check the bearings.
Check the oil (level and condition, it may have water or gas in it).
Take out the spark plug and without fuel try to turn the motor manually.
If you can turn it, try to clean if any rusty parts, drain the oil, clean the crankcase with cleaning oil (make a few turns)and fill it with good new oil.
Try to spray some WD 40 or some rust remover spray where you may have rust: the generator interspace, bearing legs, through the spark plug hole etc.
Thats all I can advice now. If no result try another quiary.
Posted on Jul 13, 2010
Doesnt want to start, when it does it runs rough then dies, several tries and it will run rough and eventually smooth out and run ok, also intermittant loud clicking sound,think its the fuel pump
sounds like u need a new fuel pump when u first start up fuel has seaped back to tank only when u crank it brings fuel back up then the speed keeps fuel ok , replce fuel pump shud b ok then.
Oct 09, 2013 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan generator fuel pump
Did you change the pump with the correct Onan pump, these are special low pressure pumps, and automotive pump will not work and can cause dangerous flooding and carb issues.
Jun 24, 2013 | Electrical Supplies
I have an onan 4000. will start but then sut off. chanced spark plug oil filer and fuel selnoid not sure what to do next
this may sound like a smart *** answer but turn on its side and shake it the low oil switch is stuck
Aug 04, 2011 | Watts Onan Portable Generator - 4000 ,...
Onan generator dies after 2-3 hours of running , wiil not restart rigt away wait 10 minutes starts no problem then runs for 15 minutes shuts down and keeps reapeating on 15 off 10
This sounds like overheating. These small generators don't have overheating protection, but if a low oil pressure or low oil level is present it may be the reason for stopping.
Check the oil level in the starting conditions and again when it stops. It may become under the "stop" level and after some time the precipitated oil has reached the "start" level. The same may be with oil viscosity and oil pressure.
Try to add some oil or change the oil with bigger viscosity.
Jul 07, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan 5000 surges
Governor is "hunting. An adjustment should take care of it. nothing more. Take it to camping world and they know what to do.
Sep 15, 2009 | Watts Onan Portable Generator - 5000 ,...
Onan microquiet 4000 will not turn over. It was running for about 10 to 15 minutes at a time. Sometime even 30 minutes and then it goes dead. After trying to crank it back several times, it was turning...
Sometimes people mistakenly think there's a problem with a carb on Onan 4000 generators. Be sure to ensure the fuel pump is pumping fuel to the carb by pulling the hose off the carb and watching for adequate flow. A faulty electric fuel pump can often only show symptoms or act up after it is warmed up. Sometimes it may run for 10 or 20 minutes and just shut down. Check for fuel flow immediately upon stalling if this is your symptom. Mine would shut down after 20 minutes and not restart for awhile. I pulled the hose off the carb immediately and noted there was no fuel in the line and it would not pump fuel while holding the start switch on either. If you are mechanically savvy you can disconnect the hot wire the positive wire (red) leading into the fuel pump and connect it with 12 V and see if it pumps fuel out the hose also, but be careful to capture the fuel coming out the hose). Once cooled down it pumped fuel in a weaker than normal stream, but when hot after 10 or 20 minutes it quit pumping causing stalling of the generator. Replaced the fuel pump (and new filter while at it) and everything worked fine again on my 1995 Onan. Much stronger fuel stream noted too from the hose.
Sep 06, 2009 | Coleman Electrical Supplies
Onan 4000 start good runs only ten minutsand shuts down,starts up
First locate the oil pressure switch and see if you can bypass it,then see if it runs. If not check the fuel filter and fuel pump,make sure solonoid for fuel pump is kicking on.
Jun 07, 2009 | Watts Onan Portable Generator - 4000 ,...
ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
does it have original oil in it? if so they use a lighter weight oil than recommended for engine break in. change your oil and filter and see if that doesnt solve it.could be thinning out loosing pressure when hot. i have seen this beofore.. :)
Mar 24, 2009 | Watts Onan Portable Generator - 4000 ,...
Try to restart to see what happens. However, make sure to have a volt meter to check output voltage. You may be loosing voltage and therefore it shuts down. Check oil pressure switch, rings, brushes. Replace brushes if they are less than 1/2" short and clean rings with emory cloth until copper is noticable.
Jan 21, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
168 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
