I need the procedure to remove a fuser in a Canon imageCLASS D860
  • 6,993 Answers
take off all the plastic covers above, below and to each side of the Fuser. Then pull the thin black plastic sheet back and tape it down to the printer so you can get at the connectors.
You will need some kind of offset screwdriver to get the 3 Fuser screws out. Do not even think about stripping one of them or you are seriously screwed (pun intended).
Good luck
Posted on Jul 13, 2010
I am looking for Canon ImageCLASS D860 driver for Windows 7 64 bit
Users installing drivers for Canon ImageClass D860 printers must make sure that the driver being installed is genuine. Only genuine drivers must be installed on your system. Illegitimate or third party drivers that claim better performance from the Canon ImageClass D860 printer should not be downloaded or installed on the system as such drivers are likely to have malware that would get installed on the system and cause damage. Authenticity of the drivers can be checked by verifying details of drivers provided on the official website of manufacturer.
Nov 08, 2010 | Canon imageCLASS D860 All-In-One Laser...
Paper jammed at exit rollers of Canon D860. Paper
If you remove the plastic covers on that side of the printer, you will see a small screw holding a bar against the rollers. Set the printer on end so you can remove this screw with out dropping it into the printer, and then the rollers will be loose enough that you can get the paper out.
May 12, 2010 | Canon imageCLASS D860 All-In-One Laser...
Sounds like there is a papper jam but I can not see papper. Copies are coming out crumpled.
These machines use a fuser film. When they get torn or go bad they make a paper crumpling sound. When this happens it also causes wrinkles and creases in your copies. There may also be areas of your copy where the print will rub off. This means it is time for a new fusing unit. They are not cheap and removal of the old unit and installation of the new unit is not easy so plan on having a service person replace it. Just do a search for Canon D860 fuser or fusing unit.
Good Luck and Thank You for using Fixya.
Apr 30, 2010 | Canon imageCLASS D860 All-In-One Laser...
I need to add the Canon d860 to my laptop. Can I download the program from online service. is there a fee?
You can download the driver from
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=335&modelid=10517
Select your OS (Operating System) and choose the files to download.
Please don't forget to rate me and give me a vote.
Mar 24, 2010 | Canon imageCLASS D860 All-In-One Laser...
What's the procedure for replacing the fuser on the canon imageclass D860?
Hi Un-plug it first I Have changed many. You need a very small No 2 phlips screw driver like 1 inch long and a regular no 2. First you take the covers off the left side. I think its about 3 or 4 pieces. Look under the black plastic sheet and you will see the fuser. Using your small screw driver remove the the screws holding it in. Un-plug the connectors and pull it out slowly right side first. The thing that goes bad is the fuser sleeve. The replacement to use is the HP laserjet 4000. It should cost about 20-30 $.
Jan 21, 2010 | Canon imageCLASS D860 All-In-One Laser...
My cannon ir 1600 gives e000 system merror, could u pls help me
E000 indicates a Fuser (Fixing) Unit error.
Some can be reset, others need a part replaced.
Jun 05, 2009 | Canon imageCLASS D860 All-In-One Laser...
Need Help Please
problem w/the fuser, probably the lamp is not turning on and not heating the rollers, need to change.
Jun 02, 2008 | Canon imageCLASS D860 All-In-One Laser...
Driver
Drivers for the imageClass D860 can be downloaded from here
Apr 25, 2008 | Canon imageCLASS D860 All-In-One Laser...
14 people viewed this question
jasbo
jasbo
