Question about Maytag Cooktops
I need to replace the dual element switch, but the orignal switch is discontinued and the replacement wires up different. my mdl # cve3400w
  • klj6264 Jul 13, 2010
    I need help wiring the new switch up. It has more terminals on it than the old one.
  • 6,826 Answers
Unfortunately, if Maytag discontinued it, and you cannot find it online nationally, I am afraid that it will be a difficult if not impossible repair.
The following blog on the Internet covers this problem:
http://www.applianceblog.com/mainforums/maytag-magic-chef-admiral-jenn-air/16029-cve3400w-replacing-dual-burner-switch.html
Posted on Jul 13, 2010
    President:
  • 670 Answers
I found this part at this link, http://www.repairclinic.com/SSPartDetail.aspx?s=t-cve3400w-%3d%3di1014250&PartID=1014250 would this work for you? Let me know if this works. Thanks.
    I have the switch but it wires up different than the old one
  • Stephen Lam Jul 14, 2010
    To connect the new switch from the old one, follow these instructions:
    1. Attach the black wire(s) from the old switch (terminal 2) to the new switch terminal P1.
    2. Attach the jumper cable to P1 and "jump" it to S1.
    3. Attach the orange wire (old switch terminal 5) to S2.
    4. Attach the yellow wire (old switch terminal 4) to 4a.
    5. Attach the white wire (old switch terminal 3) to terminal 4 on the new switch.
    6. Attach the single red wire from the right front element to terminal 2 on the new switch.
    7. Attach the 'compound' red wires (the ones that come from the left rear/outlet connection and is also attached to the right rear switch) to terminal P2 on the new switch.
    There is no need to separate the compound red wires
My Jenn AirCooktop Model CVE3401 burner problems
The part you need to replace is the switch. The switch is housed under the top and connects to the dial you are turning.
The switch for the dual burner is 12002125, and 74011242 for the single burner.
The single burner switch runs about $20.00 and the dual runs about $50.00 for the parts
Apr 24, 2010 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Control for dual element has to be wiggled just so -so to shut element off, what do I need to fix it? Heats perfectly, shutting it off is my only problem.
The control you're wiggling (infinite switch)needs replacement. Model# and the position of the dual element (right or left, rear or front) is needed to get the part number.
Mar 03, 2010 | Cooktops
I need instructions for wiring in replacing a dual burner switch on a CVE3400B cooktop. The replacement switch is different from the original. Do you have a diagram for the new switch that shows how to...
We followed the instructions that came with the switch that addressed a "compound wiring" configuration. We also used the black jumper wire as shown in the instructions.
We got to this solution in a trial by error manner though, because the three of us working the problem were convinced the stovetop was wired in a "piggyback configuration" and tried that road first. It would have been helpful if the instructions had included an explanation of the switch manufacturer's interpretation of "compound" and "piggyback" configuration.
Jan 09, 2010 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Range replacement switch installation ???
sounds like you have the wrong sw . do not install . ck the old # and see it this is a proper replacement . / I did look your sw and it has a blue housing and muilti break of shaft . it should replace a standard sw but not the dual element . re ck where you purchase to make sure is the right one .. mm
Dec 08, 2009 | Cooktops
JEC9530, dual element burner(right front) does not work the light does come on, the burner does not and the knob has play in it.
This coulb be either the switch or the burner. Either can be tested with an ohmmeter if you can read the wiring diagram. Hope this helps!
Feb 26, 2009 | Jenn-Air JEC9530 Electric Cooktop
Rear eye want come on
sounds as if you have a wiring issue, somehow power is backfeeding into the other switch. aliitle too late but was the switch an exact match or was it a new substituted aprt, its possible that the manufactue either sent wrong part , or the new switch altough appears the same ,,wire terminals were in different locations
Nov 10, 2008 | Frigidaire 26" Built-In Electric Cooktop -...
COOKTOP
its been my experience that the dual burner switch is far more likely the culprit, unless you can physiclaly see the outer ring is broken( visual inspection works wonders. as far as trying to ohm out i generally look at theelemnet itself (4 wires lead to the elemnt you can trace 1 to the outer portion of element, and 1 to the inner portion.WITH POWER OFF Iswithc those 2 wires and the restore power try element ad watch for outer ring to work inner ring no good. now i know its the switch not sending power. reset wires and order new switch
Mar 08, 2008 | Cooktops
Replacement dual burner Gaggenau CK594
You have 2 line, 2 load, and if there is an indicator light, 1 for that and 1 ground. The other guy may be right about the 2 grounds, if not, the indicator light may have a connection for hooking it to another light in series. The tech cannot understand the schematic? get someone who can.
Jan 15, 2008 | Gaggenau 47 in. CK 594 Electric Cooktop
Cooktops Logo
69 people viewed this question
Top Maytag Cooktops Experts
Harry Miller
Level 1 Expert
Marvin
Marvin
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
