Question about Sharp AL-1642CS Copier
HI iM HAVING AN ISSUE WITH MY PRINTER AND I SEEM TO HAVE MISPLACED MY MANUAL. There is a ligh tnext to the green print button with a right side up check mark and an upside down check mark. What does it mean if this light is on?
  • 1,110 Answers
This is your pre-heat or energy save mode light. It means that the machine is in the energy save mode. This light goes off when you press the print button which will "wake up" the copier and bring it to a ready to copy state. It will remain ready for a minute or 2 after making your last copy then it will return to sleep mode. Sharp had to do this in order for the machine to qualify for the Energy Star rating.
Thank You for using Fixya.
Posted on Jul 13, 2010
On printer error cod 6A00 displayed, on computer screen icon says service error 5C10. Have cleaned ink wells and wiped off excess ink. After cleaning far right side a long skinny black piece came out,...
Hi
Error 5C10 means a paper jam or the printer has encountered an internal error. And error 6A00 is caused due a paper jam in the sheet feed unit or near the print head. You can also reset the printer to resolve this issue. On the printer press and hold the ON/OFF button or unplug the power cord. Wait for 10 seconds, press power button ON/OFF button again. If this doesn't resolve the error code then unplug the printer for 10 minutes. Also, inspect the back panel of the printer for any paper jams. To clear the paper jams---
Turn off the printer and disconnect the power cord and USB cable. Remove the jammed paper slowly using the following procedure. Open the rear cover to check if the paper is jammed. Pull out the cassette and check if the paper is jammed inside the cassette area. Stand the printer with the rear side down, holding the document cover. Press the tabs together and pull the green cover toward you. Check if the paper is jammed. (If you were not doing Duplex printing, you do not have to follow this procedure.) Close the green cover and place the printer back to a normal position. Reconnect the power cord and power on the printer. Confirm the Alarm light is off. Load paper back into the ASF or cassette. Press to clear the message and continue printing. If you are printing from application software, follow the instructions displayed on your computer. Hope this helps... Please post back if you need more information.
Daniel
Jun 20, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Flashing lights on printer
The iP4300 manual says this for 10 flashes "
The size of paper may not be compatible with automatic duplex printing. The sizes of media suitable for auto duplex printing are A4, Letter, A5, and 5" x 7". Make sure that the size of the paper loaded in the printer is correct. Pressing the RESUME/CANCEL button will eject the paper and restart printing from the front side of the next paper. The reverse side of the ejected sheet will not be printed." Hope this helps
Mar 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I am having trouble changing the cartridge on the printer. The
im so sorry for the inconvineince that your having on this printer but let me help you.
if :
Red paper.jpg paper and red inkout1.jpg ink light flash alternately and green power.jpg power light is off possible problem: Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. If the lights are still on, that means the printer is having a hardware issue if: Green power.jpg power light is off; red paper.jpg paper and inkout1.jpg ink lights flash (quickly) possible problem: The printer may have an internal error. Turn off the printer, wait a few seconds, and turn it on again. If the lights are still flashing , that means the printer is having a hardware issue
Feb 10, 2010 | Epson Stylus C88 InkJet Photo Printer
HELLO...WE HAVE AN HP PSC 950 PRINTER, COPIER, SCANNER , FAX AND IT PRINTS SUPER SLOW...THIS HAPPENED BEFORE AND I PUSHED A BUTTON TO CORRECT THE PROBLEM BUT IM NOT HAVING THE SAME LUCK THIS TIME...HELP!!
I would seem the quality is set to high instead of normal or draft (even faster). Right-click on the printer in the Printers and Faxes folder and select Properties. Under Printing Preferences you can set the default quality. When printing photos you can override this setting.
Dec 30, 2008 | HP PSC 950 All-In-One InkJet Printer
HP Laser Jet 1300 won't print
Hi there
check the connecting wiring. ( inside cables ).
hope this fix your problem
thanks
Hamedo
Nov 18, 2008 | HP LaserJet 1300 Printer
Says Photo print but want normal print
On the MP750 (and MP780...) there are 3 small "buttons" on each side of the screen. On the right side, the lowest button controls the movement from plain to glossy to high resolution to photoprint. So, if you are on one of these settings and want to switch, you press this button. Pressing it only once will affect only the paper size, but pressing the button twice will control the resolution. To move among the options use the arrow buttons (left and right) under the menu...then just push the ok button. It worked for me.
Oct 12, 2008 | Canon PIXMA MP750 All-In-One InkJet...
Brother HL 2040 Printer
Tap the GO key down 3 times. for an internal print out.
Jun 15, 2008 | Brother HL-2040 Laser Printer
Trouble Printing Pictures
Hi
All you need to do is reset the printer to the factory settings, follow the instructions manual for dell 3000cn steps.
Print the Gradation [ESS] Test Print On the Printer
To print all four 20% toner test prints, perform the following step:
Power off the printer.
Hold down the up and down arrow buttons on the printer and power the printer on.
Press the down arrow button until Test Print appears and press the button.
Press the down arrow until Cyan20% [ESS] appears and press the button.
Press the button. The test print will print.
Press the Cancel button.
Press the down arrow until Magenta20% [ESS] appears and press the button.
Press the down arrow until Yellow20% [ESS] appears and press the button.
Press the down arrow until Black20% [ESS] appears and press the button.
STEP: Clean the contact points on the drum cartridge and the right side of the 3000cn-series / 3100cn printer.
To clean the contact points on the drum cartridge and the right side of the printer, perform the following steps:
Unplug the power cable.
Pull to open the front cover, and then lift to open the top cover.
Raise the lever on the top right side of the drum cartridge
Grasp the drum cartridge by the handle and lift up and out
Using a clean, dry, lint-free cloth, wipe the contact points on the drum cartridge
Clean the right side of the drum cartridge.
Using a clean, dry, lint-free cloth, wipe the contact points on the right side of the printer
Insert the drum cartridge.
Close the top and front covers.
Plug in the power cable.
Power on the printer
This should resolve the issue
Nov 08, 2007 | Dell 3100cn Laser Printer
83 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
George Mclaughlin
Ed
Ed
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
