Question about Yard Machines 155 Torque Briggs Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000
My yard machine 14.5 hp briggs engine with 42" cut mower deck won't start. Battery has 12.8 volts amd when the key is turned it clicks.
It’s a bad solenoid. Mine was located under the shifter plate?
Posted on Aug 08, 2010
  • 3 Answers
The clicking means its not making enough contact somewhere. it could be the battery is not charge you could try to jump the tractor or follow the red wirer the whole way up.
Posted on Jul 13, 2010
I changed the deck drive belt & the baldes spin but when I lower the cut height from the highest setting(5) down one (4) the blades spin slows down too much & it's not cutting the grass. I need to...
Sounds like you had to change the belt because their is too much resistance in the shafts that the blades are attached to. This may be from grass. Anyway, that is where I would check, to make sure everything turns freely when not connected to the belt .
May 17, 2014 | Yard Machines 13AN772S000 42-Inch 500cc...
Why won't my yard man briggs and stratton 7.5 hp engine crank
Check for blown fuse if good put a light tester on the starting then turn the key if your tester lights up then you know that the stater is bab if it does not then you do not have power to the shotch. One red wire should have power all the time and the other red wire should have power only when the key is on.
Jun 20, 2013 | Yard Man Yardman Riding Lawn Mower 38in...
My Yard Riding Lawn Mower won't start when I turn the key on it just clicks
Click means solenoid has enough battery power but maybe not enough battery power for the armature of the starter to spin, it may be low battery or bad solenoid contact - inside it, (copper washer and pin), or thirdly it may be the engine is stuck so try to turn it a bit by hand to rule this out. Turning the engine a bit by hand may also free a starter gear that has jammed on the flywheel teeth.
Jun 30, 2012 | Yard Man Yardman Riding Lawn Mower 38in...
We are needing a diagram on how to put a deck belt on a 42 inch yard machine
Needing a diagram on how to put drive belt on 42" 20hp poulan pro lawn mower
Jul 23, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Riding lawn mower stopped working, now it just makes a clicking noise when you turn the key, the grass was pretty high when this happened...did the engine blow?
clean the battery posts for one, and make sure the unit has a full 12 volts in the battery ,, these units charge slowly as it is, and if the battery gets to low, the machine will just quit, you try and start them, and all you get is a click
Jun 16, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Yard Machines RL 638, '07 model, will not start
Sounds like the blades may be engaged. The cable may not have disengaged completely the last time. When the engine is trying to turn over, the belt is engaged trying to turn the blades which could be why the deck is jerking. It will not start if the blades are engaged because of the safety switches.
Apr 30, 2010 | Yard Machines 155 Torque Briggs Stratton...
Husquavarna tractor battery won"t start engine
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
Jun 25, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Starter energizes, won't turn engine.
your battery is in a weak state also the solenoid is shorting out replace the solenoid
Jun 06, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Cutting size question
* f your yard is up to an acre in size, the ideal cutting width is 30-42" (76-106cm). To avoid being underpowered, or putting too much strain on the engine, make sure your mower or tractor offers a minimum 14 horsepower. Riding mowers are the most commonly purchased for lawns this size. * For a yard that is between one and three acres, you’ll reduce your mowing time with a cutting width of 42-46" (106-116cm) and a strong engine up to 16 HP. Typically people purchase lawn tractors for yards of this size. * If you’re mowing more than three acres, you’ll need to look at the garden tractors, with cutting widths up to 54" (137cm) and at least an 18 HP engine, preferably bigger.
Aug 27, 2008 | Ariens 34 In. Zoom Series Riding Mower
Yard Machines 155 Torque Briggs  Stratton Riding Lawn Mower (NonCARB Compliant) 13AM772F000 Logo
1,439 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
