Question about Oreck XL Ultra Bagged Upright Vacuum
The motor runs erratically and smell like it burning.
I think it time to replace the motor. Can you suggest a parts supplier? I will replace the plastic fan also. What else should I do while i have this on the bench?
  • Anonymous May 06, 2008
    My vacuum has always smelled like it's burning. I've taken it to Oreck, they say it's fine, I return home and it still smells like rubber burning.
    President:
  • 1,673 Answers
Replace the belt, check the brush roll, do the ends turn freely and are the brisles worn, if so replace it. For parts, you will just have to find a repair shop that can supply you with parts, or try the internet.
Posted on Apr 20, 2008
Model 1580 central vac electrolua stopped burning smell
If the smell is like burning metal and very strong, the motor is bad and needs replaced.
The circuit board inside could also have shorted and burned out. You can check the motor by removing the low voltage wiring from the side of the vacuum and using long-nosed pliers. Open the pliers and slip a point into each terminal. The motor should come on if it's still good. If it does run, the problem is with the relay board.
Although you can get either motor or board and replace them yourself, if you let the tech at an authorized Aerus Electrolux store do it, there's a one year warranty on the part/s and labor.
The nearest store can be found using the following link.
http://www.aerushome.com/storelocator/
Mar 02, 2011 | Electrolux Central Vacuum
When running it smells like something is burning
Hi
If it smells like burning rubber, then your belt is probably slipping due to having lost tension and needs to be replaced. If it's another smell, it could be the motor burning out, but that is often accompanied by smoke. There could also be something caught around the revolving brushes in the cleaning head. Lie the vacuum on it's side and make sure you can spin the brushbar freely by hand. Also check for any debris entangled in or obstructing the brushes. This would also cause the belt to slip resulting in a smell of burning rubber. It could also damage the motor so I suggest not using the vacuum until the source of the fault has been determined.
Instructions on replacing the belt can be found in your user manual. If you don't have one or need further instruction on how to do this, please post back for further assistance.
Regards,
BElectric.
Nov 25, 2010 | Eureka Capture Upright Vacuum Vacuum
Vacuumed water - won't work
it sounds like the motor overload is cutting out.
it should automatically reset in time.
  • try removing the motor from the vacuum.
  • jump the motor. (power directly to the motor leads) be careful doing this! because once you plug it the motor will jump...keep your fingers from moving parts.
  • With the motor running, you will want to inspect the commutator -(where the carbon brushes push against)
  • if a blue spark is large and wrapping around the commutator then you will need to replace the brushes to begin with...in worse cases the armatures commutator would have to be cleaned with emery paper.... or armature should be replace. i think vacuum motors sell as a assembly...depending on what type of vacuum you have it might be better just buying a new one.
Oct 07, 2009 | Vacuums
Burning smell kenmore canister
Had a burning smell coming from the vacuum. Opened it up and noticed sparks in the motor area. Ordered a new motor from Sears and replaced it. Works great now.
Mar 04, 2009 | Kenmore Vacuums
Vacuum shuts off and has a burnt smell
Try removing the drivebelt, and try running it to test like this. The brush bar will not turn, but it should function normally without smell at this point. If it doesn't, you may need a new motor as I think the brushes may have worn down - producing an electrical type burning smell.
If it runs fine without the belt attatched, then there is probably a build-up of hair or threads at each end of the roller stopping it turning freely. With the hoover off, check it turns freely and easily. A small metal nail file or similar is usually a good tool to clear it.
If the roller is stiff, the belt will not turn easily, and overheat on the motor spindle - causing the burning smell.
Jan 08, 2009 | Hoover Vacuums
Upright Vacuum Cleaner Lost Suction
If you had the dryer sheet under the intake filter for any length of time you risk burning out the motor . If
it smells like burning hair and plastic then the motor is toast. Also check the hose and dust passage, but I fear that it is the motor.
Sorry...
Sep 24, 2008 | Kenmore 31913 Progressive Direct Drive...
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
Jun 10, 2008 | Sebo Automatic X1 Bagged Upright Vacuum
Burning Smell coming from the moter
This could be a motor problem. There is always a slight blue arcing that occurs when an electrical motor runs and can be visible through the exhaust vent, but any excessive arcing indicates a problem. If the carbon brushes are sticking, this will cause excessive arcing and can be corrected by an experience service person, but if there is any electrical failure, the motor would have to be replaced. There are no parts available for these motors and the expense of replacing an armature (the likely culprit) would be more than the motor. This could also be as simple as a worn belt, but usually, belts will not produce the smell your describing. When a motor is burning out, it will produce an acrid odor that will linger for a long time.
Feb 23, 2008 | Hoover U5262-900 / U5260-900 / U5266-900 /...
Oreck XL Ultra Bagged Upright Vacuum Logo
175 people viewed this question
Top Oreck Vacuums Experts
xalint1
xalint1
Kory Ronning
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
