Question about Philips 42PFL7422D 42 in. LCD TV
My Philips LCD TV just changes channels by itself
My Philips LCD TV just chnages channels by itself and is unwatchable as does it every 5-10 seconds or so. How can i stop it changing the channels by itself please?
  • 127 Answers
It could be one of the buttons to change channels is jammed
Posted on Jul 13, 2010
  • alistair_gat Jul 14, 2010
    i dont think so as the channles change from say 88 to 7 then to AV and then to something else...
  • v_vlahos Sep 19, 2010
    Have the same issue. Did you find a solution? thanks
Block unwatched tv channels
Look in the main menu for programming---most sets have a way to manually skip out or delete channels in the up/down programmed menu.
Mar 19, 2012 | Vizio VW32L 32 in. LCD HDTV
Hello , My TV is 42PFL7422 LCD , The problem is oprating function change itselfs and also chanel TV with AV port. How to stop it Thank you
he problem of your TV is the button of the channel will not getting back so channel can't stop
you have to do is replace the button if you will or use a remote control to access the channel and never use manual changing channel again
Mar 09, 2011 | Philips 42PFL7422D 42 in. LCD TV
Please Help. My Philips 42"
Hello, you should take the remote control out of the room, just in case it causes. Let me know if it did not help. Then we will continue to the other options
Mar 04, 2011 | Televison & Video
Volume keeps turning itself up philips lcd tv
this is due to surface mount capacitors going faulty on the side buttons panel. You can simply disconnect the cable from this board and use you remote to control the channels and volume. if you want it fixed you will have to replace the side button control panel which is a cheap part.
Jan 29, 2011 | Philips 37PF5521D 37 in. HD-Ready LCD...
Philips 32pf732198 no sound on certain channels
Unplug,replug the tv an hour later.Go to ur tv menu reset the Audio setting.The setting will go back to the factory setting,should work solved ur problems.Not than ur Tuner signal board have problems,must change.
Apr 06, 2010 | Philips 30PF9975 30 in. LCD HDTV
Screen stock on Software Upgrade Application
First of all the software update may not have been done yet, when tv's go through an update (depending on which update) the set can turn it's self off and seem to be done, but you need to wait it out and the set will turn it's self back on, Wait it out for about 30 minutes before doing anything. be paitent. UNPLUGGING THE SET CAN DAMMAGE THE TV DURRING A SOFTWARE UPGRADE!!!
If after a LONG period of time try unplugging the set and re-setting the micro. But only as a last resort!
If the upgrad failed and you can't get the set to function properly you need to change the ssb board. If the set is in waranty, waranty should cover this.
Sep 03, 2009 | Philips 42PFL5332D 42 in. LCD Television
Philips LCD 17PF8946/37 TV not working
The good news is that the "No Input Signal" message means that your TV is not broken. If you are trying to watch cable, then you have simply turned the TV to the wrong input channel. If your cable comes into the Philips using a coaxial cable wire, use the Philips remote to change the channel to Ch.3 or 4 - whichever channel you normally watch cable on. Make sure the cable box is turned on if you have a cable box. If the cable box connects to the TV using another type of wire, use the Ch+/- on the Philips remote and go through all the AV channels until you find the right one. Good luck! Let me know if you need additional help.
-Tha Mp3 Doctor
Dec 30, 2008 | Philips 17PF8946 17 in. HDTV-Ready LCD...
PHILIPS 32PF7331/12 LCD TV
Press tv on sky remote then press help ,channel list appears . goto tv set use onset channel change button to scroll to hd channel .press volume up button onset to select.
Sep 28, 2008 | Philips 26PF5320 26 in. LCD Television
Philips 42PFL7422D 42 in. LCD TV Logo
947 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
