Question about Danby Heating & Cooling
Danby standup aircondioner ( 3 in 1) , does not MODEL APAC9030
Danby standup aircondioner ( 3 in 1) , does not have external water tank. Red ''empty'' light will not shut off (there for) and the unit does not work. Fan is working, but not AC or Dehumidifier. Emptied internal holding tank....drained water from drain...and it won't work. Is there a way to
reset the unit?
If you receive an answer to this I have the exact same problem... dougakers at msn dot com
Posted on Aug 14, 2010
  • trev_t_7 May 31, 2011
    Also the same isuse! bypassing "full water" switch makes no difference. trev_t_7 at hooootmail dot com
My unit is flashing a red light in the water full indicator. Therefor the air conditioner will not function. Both water tanks are completely empty. It is a portable Danby unit. Model SPAC 8499-3. Any...
You may need to reset the unit, if you did not turn it OFF & unplug it when you drained the tanks
To reset the units electronics, turn the unit OFF and unplug it for 15 minutes. After the time has elapsed, plug the unit in & turn it ON. The electronics should have reset and reverted back to the original factory settings. If so, you can adjust the settings to where you like.
Hope this helped you & thanks for choosing FixYa.
Sep 09, 2011 | Danby Heating & Cooling
Remove Water Tank
  • require you empty the unit by hand (usually less expensive units). These have either a removable water tank which must be emptied, or have an internal tank and a drain, where you have to empty the water into your own pan. Sometimes the drain is on the bottom of the unit, making it hard to find a pan that will fit under the unit to drain it.
  • discharge most of the water through the exhaust hose (usually more expensive units). This is called "Auto-evaporation" or "Self-evaporating" feature.
Most units are made so that they can be drained with a gravity hose that flows to a drain inside or outside your house. But the water must drain down. If the drain is higher than the unit, you may need a condensation pump to move the water upward. A few units do include a pump to send the water a short distance through the drain pipe.
do no forget to rate the solution as fixya if it helps you.
thanks.
Jul 02, 2008 | Danby DPAC10031 Air Conditioner
I have misplaced my operating instructions for my Danby dehumidifier model DDR 3008 EE. When I plug it in, turn it on, it runs for maybe a minute then the red full water tank lights up and it quits. The...
The model number you listed did not reveal anything. However, the link below is a link to a Danby model, that had a model number closest to yous. Most of the units have the same parts and function. Click n the literature tab and the Owners Manual will come up.
http://www.danby.com/product/DDR30E/12
Hope this helps you. Please let me know.
May 15, 2011 | Danby Dehumidifiers
Dandy model DPAC8399 water lear from rear water hold tank
Dandy instructions are located here:https://www.danby.com/wp-content/uploads/2016/04/DPAC83991.pdf
Basically, you need to attach the external tank tray at the bottom, remove the tank male fitting and screw it into the external tank female port.
Nov 24, 2017 | Danby DPAC8399 Air Conditioner
My danby air conditioner/dehumidifier model dpac 8399-4 leaks water all over the floor and never fills the holding tanks what can I do to fix this problem?
Probably needs cleaning. I assume it is on a level surface. Water drips from the evaporator coil into a collection tray of some type and then drains into the holding tank, this tray is either broken or the outlet is plugged.
Good Luck,
Gilsh
Nov 26, 2009 | Danby DPAC8399 Air Conditioner
Red light is on???
You need to empty the water in the tanks, there are two one is external the other is internal if you do not have the external tank attached do so and with the unit of, then turn the unit on and put it in cool mode and watch for the water to drain if this does not work emty the water from the scre holes with the unit unplugged and drain it outside you will need leverage as it will need a slight tilt to do so. Hope that helps..
Jul 31, 2009 | Danby DPAC120068 Air Conditioner
Red light on??
that means the internal tank is full and needs to be emptied. Drain useing a bucket or the hose that came with the system. Open up drain caps and just drain it. Top and bottom caps.
Jul 16, 2009 | Danby DPAC120061 Portable Air Conditioner
Need new external water tank quick release for Danby DPAC9030
You can order it from Danby directly (you can get their contact online from the Danby website). They cost like 4$+shipping, I had to buy one last summer. They ship to Canada and the US.
Jun 19, 2009 | Danby DPAC9030 Air Conditioner
Red flashing light
Had the same problem, thing shutting off after an hour, no water in the tank. I had the external tank attached, was always bone dry. What I didn't know was on the side, there is a slide out tray which acts as the internal tank. The lid to that tank activates a micro-switch which tells the unit that it's full. This tank was dry too, but the switch was getting jostled, casuing it to trip. I've taped down the switch now, and it's fine. I check the tank every few days, just to be safe, but it's never got any water in it. Hope this helps.
Jun 25, 2008 | Danby DPAC9030 Air Conditioner
Red light wont shut off
check to make sure your fill bucket is correctly placed back into the unit. there is a safely switch that will not let the unit work without the bucket in place..hope this helps let me know?
Aug 24, 2007 | Danby DPAC10031 Air Conditioner
Heating & Cooling Logo
335 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
