Question about Acer X213WB Monitor
Monitor just suddenly went off and won't come back on. What could be the problem?
  • 11,361 Answers
Failed DC filter caps, and check the main AC fuse, the power supply should be putting out 5vdc and 18vdc the minute it is plugged into the wall outlet, check for that without turning on the monitor.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking, or have high ESR) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jul 13, 2010
Samsung 21.5 LCD monitor suddenly turned dark. Can this be fixed or should I just trash it?
Your monitor has symptoms of power supply failure. The age of the monitor and the cost of repair will influence your decision whether to repair it or dump it
Feb 25, 2013 | Computers & Internet
Won't stop cycling through brightness settings
sounds like it might need a cleaning. are the buttons hard to push or are any of them giving you a different feeling then the rest?
Aug 13, 2017 | Samsung SyncMaster 2233SW Monitor
The OSD screen is up and won`t dissengage(after trying the 10 second hold down) , also the video display say`s switch the cable leads , I don`t understand. The menu,+,-, auto buttons won`t work. What might...
try powering off your monitor and disconnect the cable at both ends. switch the ends if that doesn't work try another cable.then turn the monitor back on see if the osd menu went away.
Mar 23, 2010 | HP RY117AA w2408 24" Widescreen LCD
Acer X233H monitor whilst in use suddenly went black
sounds like the video card went out or the cable shorted can you try that monitor on a friends computer?
Nov 30, 2009 | Office Equipment & Supplies
Monitor suddenly went dark. Switched it to another system but still dark. Power light on. V9s S1901D S/N T34F501728
Disconnected Data cable from the monitor to the back of the CPU. Do a self test on monitor if u get colors on the monitor it is working fine.
check for loose cables. Try to do factory reset on monitor using buttons on monitor.
Aug 17, 2009 | Scanport JTX V9S (Black) 19 in. Flat Panel...
The screen on my Gateway monitor suddenly went light blue. Has anyone else had this problem or know the solution to get it back to white?
Does the screen remain the same color when you turn it off and back on, unplug it and back in, or disconnect it from the pc and reconnect it?
Jun 15, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor screen went blank after changing resolution
Try unplugging the monitor and then restart, and then go back to default settings.
Jan 30, 2009 | Samsung 793S 17" CRT Monitor
LG W22h2TQ monitor just turned black
easy way to find out go to bestbuy and purchase a video card and install it if everything works out its the video card if not then its the monitor that went bad if its still under warranty send it back and get a replacement,
Dec 15, 2008 | LG W2252TQ Monitor
Picture is Sideways
Do a system restore. That worked for me.
May 22, 2007 | BenQ FP567s 15" LCD Monitor
Acer X213WB Monitor Logo
107 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
