Question about Samsung PCL545R 54" Rear Projection Television
No green or blue color in pictures!
We bought a Samsung PCL545R Tv second hand. The pictures are red and yellow or orange. We have tried to adjust but don't have a manuel on this tv. Please help if you can to adjust this.
Thanks Rhonda
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
You need to find a qualified servicer. You have component failure.
Look for TV Repair on craigslist or yellowbook.
Craig www.classtorations.com
Posted on Jun 08, 2008
No green or yellow color
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 29, 2017 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Tv is yellow orange color what is problem
The model indicated does not have a "bulb" as it uses 3 picture tubes.
Examine the picture with color set at zero---stand back and look= if the screen has a mostly yellow (all or part of the screen) you have bad Glycol in the blue picture tube(if need explanation ask) and a look in the lens of the Blue tube will confirm this.
If able with back off and a small mirror look in each lens--red picture, green picture and blue picture.
If the Blue looks like a floodlight with little or no image--bad glycol in that tube.
Jun 16, 2012 | Samsung HCN5527W 55" Rear Projection...
All the colors for all programs are blue and yellow on tv. have tried all the picture settings but nothing changes.
hi" do you try to adjust color settings.theres a red,blue,green color adjustment under picture setting.
try to set red color to full.
of you already do that.
probably your display driver board has a causes the problem.
display driver board produce image comes from the tuner, then it sent to x and y drive of your LCD screen.
Aug 30, 2011 | Sanyo DP26647 26 in. LCD TV
Tv gets light blueand stays that way...comes back to perfect color the back to blue X-RAy looking it is a samsung pcl545r
Behind the screen, there are three color tubes: Red Green and Blue.
Unfortunately, rear projection screens often have these problems and the tubes do go out after extended use.
Take the television to a TV Repair shop to have this fixed. But in the long run, this may end up costing you a lot more than if you would purchase a new TV. The light tubes are fairly expensive.
Jun 03, 2011 | Samsung PCL545R 54" Rear Projection...
I need the color code for phone cables. 25 pair up to 1800 pair. I need to splice it.
white/blue
white orange
white green
white brown
white slate
red blue
red orange
red green
red brown
red slate
black blue
black orange
black green
black brown
black slate
yellow blue
yellow orange
yellow green
yellow brown
yellow slate
violet blue
violet orange
violet green
violet brown
violet slate
**Keep all pairs together and you should be fine***
Feb 22, 2010 | Lands Phones
RED CONVERGENCE SCREEN PATTERN BOWING AND CAN'T ADJUST
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 13, 2009 | Samsung HC-P4752W 47" Rear Projection...
Wiring on a RCA RJ-45 wall jack
the RJ45 wallplate is not meant for ethernet. It's an 8P8C connector for a phone. Will it work as a network jack? Maybe. I wouldn't use it, but if you really want to try, wire it thusly:
1 Blue --- Orange/White
2 Orange --- Orange
3 Black --- Green/White
4 Red --- Blue
5 Green --- Blue/White
6 Yellow --- Green
7 Brown --- Brown/White
8 White --- Brown
I'd still recommend a CAT5 wallplate with a CAT5 jack.
Apr 11, 2009 | Computers & Internet
Blurry, Multi-Color, Multi-Line
covergence problems and its not adjustable you need work done on the convergence board or a new board and realignment which can be timely.
Nov 01, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung PCL545R Color adjustment!
i'd recommend you return it to your friend..sounds like quite an issue with the innards.
Apr 20, 2008 | Samsung PCL545R 54" Rear Projection...
Bad ghosting of all colours
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 09, 2008 | Samsung PCL545R 54" Rear Projection...
Samsung PCL545R 54" Rear Projection Television Logo
66 people viewed this question
Henry  Thomas
Henry Thomas
