Question about Dell Inspiron 1525 Laptop
Laptop not switching on - Dell Inspiron 1525 Laptop
  • 484 Answers
It could be as simple as a bad on or off switch to turn it on or off. If the Dell is still under warranty, contact Dell for their warranty service.
If it is out of warranty, contact a local PC repair shop to have them diagnose this problem. It is not an expensive part, so it should not cost too much getting it repaired either way.
-a. .
Posted on Jul 13, 2010
No power on
If the laptop battery is normal, but can not boot, check the power switch. Laptop power switch using a micro switch.
Check the power switch circuit when the power switch is in addition to checking the performance is good outside, but also check the external circuit components for damage.
If the battery power for laptops. But is not charging properly, or does not use the power adapter, then it should be checked laptop power interface circuit and peripheral components.
Sep 23, 2013 | HP Compaq nx6325 Notebook
I have been using my Iogear kvm switch for almost 2 years now to switch between a desktop and a laptop, both Windows XP. I unplugged the laptop in a hurry to go do a presentation, and plugged everything...
This almost sounds like the display setting on your laptop was changed to an external device. Most laptops are designed to be hooked up to an external display, such as a monitor or projector, specifically for presentations. You can alternate the display options in the following ways:
  1. Laptop display only
  2. External display only
  3. Laptop+External clone
  4. Laptop display + extended desktop on external display (dual monitor setup)
Check your laptop display settings and make sure that it's not in presentation mode (options 2-4) before connecting the KVM switch to it. It may be recognizing the KVM switch as an external display in option 4 mode.
Mar 25, 2011 | IOGear GCS634U KVM Switch
IOgear KVM not working with laptop
First, you have to make sure that the KVM switch is directly connected to your laptop, and NOT to a docking station.
This KVM switch is designed to work with direct connections to the computers.
Second, the light indicator on the KVM switch is not an indicator for power. It's an indicator to see which port is active. If your laptop is connected to port 2, but the focus of the KVM is in port 1, then the port 1 will have a light, not the port 2.
You may also refer to the user manual of the KVM.
Thank you!
May 13, 2010 | IOGear GCS634U KVM Switch
Where is the wireless on/off switch on the acer 5570z laptop?
In the model 5570z, the wireless communication switch
(which is optional) will be in the front, between the right and left speakers and also between the headphones/speaker/lineout jacks and the bluetooth communication switch (also optional).
That switch cannot be present, depending on the exact configuration of your laptop model.
Check your laptop's user manual.
Nov 11, 2009 | Acer Aspire 5500 5570-2609 Laptop
Laptop will not switch off untill press switch button of laptop
you have a corrupted software try to format and reinstall it again, most corrupted system comes from improper shut down sometimes during installation your CD or DVD rom is defective although it is reading and seams working fine try to install your system using other rom drive
Sep 18, 2009 | Acer Aspire 5920-6727 Notebook
Swithcing from laptop screen to lcd monitor
Hi
Connect the monitor, flat panel, or projector to the laptop's 15-pin video connection on the back of the computer as shown to the right. Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. video.gif For example, often either Fn + F3, Fn + F5, Fn + F8, or Fn + F9 is pressed to switch between alternate displays. So if your laptop was Fn + F3, pressing and holding both Fn and F3 at the same time would switch between displays. Often, the alternate key pressed in conjunction with the Fn key will be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display and/or one or the other at a single time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants.
Feb 01, 2009 | HP Pavilion dv6000z Notebook
Laptop switches off and doesn't switch on again.
your battery has become weak. you need to change the battery. If the issue persist, you need to service your laptop.
Dec 27, 2008 | Dell Latitude D630 Notebook
Laptop switch
try to spray the switch with "Contact Spray 90" ur switch maybe oxidised i think it will solve
Nov 28, 2007 | Fujitsu Siemens AMILO Pro V7010 Notebook
Dell Inspiron 1525 Laptop Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
