Question about Kenmore Professional SR365S Iron with Auto Shut-off
Won't shut off when i push the red button
Kenmore steam iron the iron will not shut off when i push the red button
Switch may be damaged
Posted on Apr 20, 2008
I bought steam generator iron, iron work but doesn’t produce steam
Mix 1:1 water and white vinegar. Fill the water reservoir with mixture and hold the iron like you would normally. Keep pushing the steam button until steam comes out.
Nov 01, 2017 | Irons
I just bought this iron in March 2015. The iron leaks water all of my clothes when I press the steam button. I have it set on the highest setting for iron and steam.
Increasing the temperature setting can ease this issue, however it is important to consider the type of fabric you are ironing.
1st option: Fill the iron up, and let the iron stand as the iron heats for little while before using. This may allow more of the water to be converted to steam.
2nd option: You could try using deionised/distilled water in your iron.
If you find that the water leaks out sporadically, it may be worth pushing the steam button once or twice before applying it to clothing.
I have attached a link with a little bit more information How to Stop Steam Iron From Dripping
Apr 30, 2015 | Irons
Philips 8300 steam generator iron keeps cutting out
I have this iron about 2,5 years, work a few times. when i shut down the steam generator the iron stays on. And now in one hour of work it shuts downs about 4 times. the lights on the steam generator are week. what main board i shuld switch?
Mar 21, 2013 | Irons
"My rowenta DG9540 iron won't stop steaming. It starts as soon as it is switched on regardless whether the steam button is pushed in or not. What might the problem be?"
1) check the ejection button of the stems for particles, has blockage the mecanism by using hard water to due mineral deposit clean it.
2) other wise you must go to some repair shop for fix it.
God bless you
Jul 11, 2012 | Irons
No steam coming out
Is the red overheat warning ligth on? if so, press the reset button, that should reset the thermostat and make it work again.
Mar 13, 2010 | Homedics PS-200 Iron with Auto Shut-off
Steam Question
Found the answer. The steam button is built into the handle. Push the button and you have steam.
Feb 27, 2008 | Steam Fast SP-660 Iron with Auto Shut-off
Steam Button
Your iron pump is faulty the high pitched sound is normal.
Rdgs
Alan
Nov 27, 2007 | Rowenta Perfect Iron
Steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Sep 10, 2006 | Rowenta Professional DE880 Iron
Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Sep 10, 2006 | Euro-Pro Steam Generator EP8020 Iron
Kenmore Professional SR365S Iron with Auto Shut-off Logo
77 people viewed this question
Top Kenmore Irons Experts
Steve
ray gallant
Tom Chichester
Are you a Kenmore Iron Expert? Answer questions, earn points and help others
