Question about Canon Image Runner 3320I Copier
Image Runner 210S
My image runner 210 S flashes the error code E000 every time I start it. Then it doesn't work. How can I please remove the code?
  • 682 Answers
It is a fuser problem:-you have to check-.
1-low temprature due to blown lamp(change it).
2-thermal switch(reset it)by pressing on it.
3-ac driver problem(heater control board.
Posted on Apr 27, 2008
Canon image Runner 2202 error code E000-0000
Aynalem, Canon image Runner 2202 error code E000-0000
Aug 10, 2016 | Canon Office Equipment & Supplies
How to resolve problem for canon imagerunner 2420L pritner error show "restart if problem persist "
There should be an error code on the screen too, what is it? it should start with E
Sep 06, 2014 | Cannon Office Equipment & Supplies
Error000
This error means that the Fixing heater is not working. It has not reached operating temperature after a specified time. It has probably blown the heater element.
You will need a trained technician to repair this.
E000 errors will not clear until the fault has been rectified and then reset by a technician. This is to prevent any fire risk.
Apr 30, 2010 | Canon Image Runner 1630 Copier Copier
Image runner 210s error code E000. What to do?
Your problem in the fuser unit.Check and clean the fuser unit component parts:thermistors,thermofuses,verify the continuity of the heater lamp,and verify the upper and lower fuser roller mechanical.
Nov 24, 2009 | Canon imageRUNNER 210S Copier
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
E000
A E000 code means the error history has detected any one of the following error codes 4 times :E001;E002;E003. Here's the definitive reset procedure Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
please rate my answer after trying if satisfied
Jul 06, 2009 | Canon Image Runner 1630 Copier Copier
Error E000
First of all a E000 is a power proble that the fuser is not warming up in time or power is not avaible. Is it possible that you may not have a outlet just for the copier by it self.... It could be low on usable power. If the power is good, I would say that your Upper heating unit is shorting out from time to time. You will need to have to replace the fixing unit if it is to much of a pain to deal with.
Jan 05, 2009 | Canon imageRUNNER 210S Copier
Canon 330 image runner Error code E000
E000 is a fuser problem.
take out the fuser (this is where the paper exits and gets hot) the tow long big rollers, the lamp may have blown or the thermofuse (keeps the copier from over heating and going to meltdown) may be bad.
The newer ones (not sure about this model ) have a ceramic instead of a heat lamp and also a thin brown film instead of rollers.
if it has a film make sure it is not torn or displaced.
Nov 21, 2008 | Canon imageRUNNER 210S Copier
Canon Image runner photocopier
It is very easy... What code is it? It may not be resetable with out replacing a part... Need more info...
Jul 07, 2008 | Canon imageRUNNER 210S Copier
170 people viewed this question
old marine
old marine
