Windows xp installation
Im still having trouble with installation, ive gotten some new errors they are Media test failure check cable exiting PXE ROM and the other one is System32\ntall.dll  unknown hard error
    Genius:
  • 3,422 Answers
HI,
Here is what the Media test failure check cable eiting PXE ROM means:
Iam sure when we were changing some settings with the BIOS you must have done something wrong.Just reemember if you changed some settings over there.
try change the boot-order in the BIOS
try to disable "network-boot" in the BIOS.
This issue is often caused by either an incorrect setting in BIOS or a bad boot device, such as a bad hard disk drive. To resolve this issue,Isuggest you go through the steps in document CH000229 relating to a similar error message.
Now coming to System32\ntall.dll unknown hard error:
Restart your computer. The ntdll.dll error you're receiving could be due to a one-time, temporary issue and a simple reboot may resolve the problem completely.
If the ntdll.dll error only displays when you use a specific software program, uninstall the program, reboot your computer, and then install the latest version again from scratch.
Update drivers for any hardware in your computer where updated drivers are available. Outdated drivers sometimes cause ntdll.dll errors.
Test your memory for damage. If you're receiving ntdll.dll messages, one possible cause could be a bad memory module in your system. Testing your memory will either identify a problem or clear your RAM of any responsibility.
Perform a repair installation of Windows XP. If individual software reinstallations fail to resolve the problem, a repair installation of Windows will replace the ntdll.dll file. Remember to install all Windows service packs and other patches after this installation.
Perform a clean installation of Windows XP. A clean installation will completely remove Windows XP from your PC and install it again from scratch. I don't recommend this step unless you have stepped through all previous troubleshooting steps and you're comfortable that the ntdll.dll error is not caused by a single program (Step #2). NOTE:a single program or plugin is causing the ntdll.dll error, reinstalling Windows and then reinstalling all of the same software may lead you right back to the same ntdll.dll error.
While extremely rare, if everything else has failed, including the clean installation from the last step, you could be dealing with a hardware issue with your hard drive. If so, replace the hard drive and then perform a new installation of Windows XP.
Posted on Apr 20, 2008
PXE-E61 : media test failure, check For Realtek RTL8101E/8102E PCI-E Ethernet Controller v1.06 (080222) PXE-E61: Media test failure, check cable PXE-M0F: Exiting PXE ROM.
The system is not finding any bootable media (Hard Drive) and is attempting to boot via the network card (PXE Boot) the error message is saying that there is not PXE network to boot from and it is exiting the process.
Generally, this is caused by a hard Drive failure. Reseat the drive and or drive connections and see if the system will find the hard drive.
Generally, a Hard drive failure
Jun 17, 2011 | Computers & Internet
When trying to reboot I'm getting this pxe-e61: media failure
"Intel UNDI, PXE-2.1 (build 082)
Copyright (C) 1997-2000 Intel Corporation
For Realtek RTL8101E/8102E PCI-E Ethernet Controller v.105 (071227)
No bootable device -- insert boot disk and press any key"
install new NIC drivers from your laptop manufacture's site.
Nov 02, 2010 | Computers & Internet
My Sony PCG K45 laptop will not boot up - I get a black screen with white text constantly scrolling saying For Realtek RTL8139(X)/8130/810X PCI Fast ethernet Controller v2.12 (010817) PXE E61 media...
That means the laptop is not recognizing that it has a hard drive installed. The settings may have gotten messed up in BIOS regarding boot order as well. Given that model initially shipped with XP, I would say the hard drive is old enough that it could have failed.
Nov 11, 2017 | Sony VAIO K45 Notebook
New hard drive, getting PXE-E61 media test failure, check cable
Broadcom is a maker of Network cards and PXE is a generic name for Network Boot Bios .. have you set your Laptop to boot from a network before CD ?? (go into BIOS @ power on and set CD first, hard disk second)
If not, then it can't see any other bootable device so ends up trying the network as a 'last resort' ...
Nov 29, 2008 | Computers & Internet
PXE-E61:Media Test Failure
you got that error message because your harddrive isnot detected so it try to boot from network and you don't have OS in the network.
Most of the time is your hdd is dead. In some cases the motherboard is dead.
You can replace your hdd.
for OS (vista vs XP), if you have enough rams and high cpu, you should install vista, but for me, I prefer XP.
for the price, you should call microsoft seller.
Jul 05, 2008 | Acer Aspire 5050-3242 Notebook
PXE-E61 Media test Failure
hy i have your solution.its simple. the problem is remote network data entry that start in the bios systems, produce by a virus call downloader.trojan or bootable Tj.exe, normally the bios has to read it and it gives the error " media test faliurecheck cables",ir you dont repaired quickly your laptop or desktop eventually will not boot the windows att all, this have to be kill before that happens, First of all clean your pc with Trojan Remover and then do just a simple task restart your desktop or laptop and do not let it initiate windows just press F2 at the bios and go to the Bios program and then go to the tab name Bios and press F9 that means "default bios systems" and everything will change in your bios and when your desktop or pc restart it will never show that message again and your bios will initiate with no problems and the virus that put that into your pc will no longer control your bios system.
May 11, 2008 | Computers & Internet
Error Message: PXE-E61 Media Test Failure Check Cable
Not always the Hard drive, boot into the bios setup utility and de-select network bootfrom the boot options. If it tries to network boot first you will always get that failure.
Apr 12, 2008 | Compaq Armada E500 Notebook
Trying to start my computer
you have a failed hard drive and will require a replacement.
Oct 15, 2007 | Toshiba Satellite P25-S5263 Notebook
EvoN200 still not working, see comment
Im new to this site, so sorry if this has been mentioned before, but the screen quotes you receive seem to indicate that it is trying to boot from a networking server, as if your laptop is a workstation with no operating system. If you are able in the bios may be a menu something similair to boot from LAN, this should be dissabled. Did you have an operating system already on or is there need for a system repair/re-install.
Oct 13, 2006 | Compaq Evo Notebook N200 Notebook
Computers & Internet Logo
408 people viewed this question
David Payne
David Payne
