Question about Hayward 250kbtu Ng Pool Heater - Inground
Display indicates a "Communication Failure".
How do I fix this Problem. Is it something I can do, or I need a gualified serivce repair technician.
  • 52 Answers
Well, if you post the problem I might be able to help
The Pool Tech
Posted on Jul 14, 2010
How do I fix my printer Bizhub c252, when I power it on it display the time clock and the display screen goes off before it finish booting
If the machine fails to boot, it normally is a main board failure or a NVRAM failure. It would be best to contact a trained technician for this repair.
Jul 14, 2017 | Konica Minolta bizhub Office Equipment &...
Fix my problem get sy cf on my display
Hello Eric espy, thanks for your post!
From my understanding you used the icemaker on your Frigidaire refrigerator and now have a code of "SY CF" on the display. That code of "SY CF" stands for communication failure after power up. This could be a possible communication error between the UIB (User Interface Board) and main control board. I would suggest performing a reset, which should clear any false error codes. If you continue to receive the error I would suggest contacting a professional technician for proper diagnosis and repair. This may help you avoid unnecessary part purchases. -Matt
Feb 22, 2015 | Frigidaire Refrigerators
Microwave keeps shutting off after a few seconds and error number H97 shows up on display pad. What does this error mean?
Error code H97 is an indication of a possible failure of the Magnetron, DPC board or the High Voltage Inverter board. It could be just a loose wire connection also between the DPC board and the High Voltage Inverter board.
This failure will require a service technician to diagnose and repair.
Jan 24, 2015 | Panasonic Microwave Ovens
Have no picture or sound on aoc hdtv aoc l42h961?
Is the power cord plugged in all the way? Try a different power cord if you see no indication of power. If that doesn't fix it, you might have a bad power supply. Electrolytic capacitors in the power supply are a common failure component and it might be cheaper to repair than to replace. I am a repair technician and was able to repair my two AOC televisions for less than $3 by replacing 4 electrolytic capacitors. You will need to pay a technician for parts and labor.
May 14, 2014 | AOC Televison & Video
F20 error code on Frigidare electric range
Hello rjshomesnj - Typically error code E20 indicates that the range has detected a communication failure between EOC (electronic oven control) and ESEC system (electronic service element control). In other words, the range has an issue with the switch for the burner. I will personally recommend contacting a certified technician to move forward accurately and to assist with the repairs. You can often locate qualified servicers by visiting the manufacturer website.
Mar 01, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
CE error code on electrolux refrigerator
Hello Alan Rapp - Typically error code CE indications a communication error at power up. You would need to contact a professional to check the wiring between the main control board and user interface board. Technician will need to move forward accurately and either part will possibly need replacing.
Jan 02, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
Panasonic tv plasma blinking red led
This is what it says on Panasonic's website:
"Panasonic utilizes the blinking light as a form of self-diagnostics, similar to the "check engine" light in your car. If you've ever experienced that, you know that a check engine light could indicate anything from a loose gas cap to a major failure.
Panasonic uses the number of times the light blinks, to aid the technician in trouble-shooting the problem. The blinking light indicates an area of concern and helps the technician to isolate the problem and order the correct parts. This in turn speeds up the repair process, keeps parts cost down, and helps both you and the servicer by allowing the technician to complete a repair in one trip in most cases."
You'll probably need to call a repair man to fix your TV.
Mar 05, 2011 | Panasonic TC-50PX24 50 in. Plasma TV
Canon IR2018 E007
E007 Fixing film sensor failure
The fixing film sensor is faulty. - Check the connector of the fixing film
sensor.
- Replace the fixing film sensor.
- Replace the DC controller PCB.
you need to call a canon technician to sort it out
Mar 22, 2009 | Toshiba e-Studio162D Copier
Hayward 250kbtu Ng Pool Heater - Inground Logo
52 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
