Question about Dishwashers
It seems the the water will not enter the mashine. I have cleaned the swing blades but that did not help. It has worked perfect for some years please help
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be an issue with the water inlet valve that has gone bad. You’ll need to check the water inlet valve which is located behind the lower access panel on the left or right side of the Dishwasher. Also check the main water line for any clogs/obstructions and try to clean the inlet valve, its bad then it should be replaced. Also check the float switch however, as its not filling at all then it seems to be a water inlet valve issue. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 13, 2010
I have an Andis 10 blade model MBG2 that i use on my border collie and miniature schnauzer. When i go to cut my dogs hair it works perfectly for a few seconds (which leads me to believe the blade is still...
When is the last time you cleaned and oiled your blades? Or if you have been using them for a long time they may need to be sharpened? Blades experience wear and tear and require regular maintenance.
Aug 08, 2013 | Pets - Others
Blades normally glide tight thru hair....cleaned and oiled blades but still meeting resistance on perfectly combed not matted hair. Blades are approx 5 yrs old. Do they need sharpened maybe. Should I...
Ok if you take them appart don't touch the screws you will find it hard to re-align, if your blades haven't been sharpened for 5 years the i think its a very good place to start
Jan 22, 2011 | Andis AGC2 Hair Trimmer
Our delonghi magnific was cleaned using delonghe descaler and began leaking almost immediately, we replaced the water resevour but this has not improved matters, any thoughts? Nic
i had the exact same problem. My machine was working perfectly and have had it for about 5 years. I descaled usnig the solution that was sold to me by DeLonghi Customer Service, followed the instructions perfectly and after the cleaning/descaling process was complete, it started leaking from the resevoir side and possibly underneath. The water tank seal seems to be fine and cannot locate the source of the water without taking the machine apart. I also hear steam coming from somewhere for about 5 min after making a cup of coffee. If you find a solution, please email me at steve_hadeed@yahoo.com. Thanks
Aug 23, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Hi my mum bought a bissell big green clean mashine about 2 years ago and never used it because she cant find how to out together , instruction manual could you help please
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Aug 12, 2010 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Washes until before rinsing and stops.
I think the problem was a bad waterfill value. removethe water from the base
RINSE/DRY = Water filling fault (over or under filling)
regards
balisonu79
Jan 04, 2010 | Bosch Washing Machines
Water comes out from the bottom of the mashine
Pressure switch failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 16, 2009 | Washing Machines
Cleaning Oster 78004-011 Clippers and blades
OK compressed air is perfect for your clipper, thats all it needs! Take the filters off (at the bottome of the clipper, either side of the cable) periodically and clear from excess fur. Replace. As far as the blades are concerened, Brush the excess furr off with a toothbrush or similar. Slide the cutter (smaller of the 2 blades) to one side (past half way but not all the way off!) clean exposed teeth on both blades with a bit of oil and a toothbrush, push the cutter the other way and repeat. Blade wash's tend to rust the blades, you need a big pot of WD-40. Get a 5 litre tub from the internet, only thing is there, postage will be a killer. I work for a clipper repair, blade sharpening company and we have it delivered by the truckload! Do what you do with the blade wash, but do it in WD-40. Wipe off excess afterwards and dont soak the clipper in any liquid because of electrc shock.
Thats all you can do! When your blades go blunt or clipper needs service repair: www.sheareaseltd.com If I have helped you please tell your friends about our website! Thank you!
Feb 25, 2009 | Oster Golden A5 2-Speed Universal Motor...
Washing mashine repair
Plug off the wall. Clean out your outlet filter. Access is a door in the front bottom of your machine, be prepared for some water to come out. Refit.
Sep 17, 2007 | Washing Machines
Quiet Series 100
It sound like a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Check if pump spins when it should force the water up into the sprayer arms. In case it doesn't spin you should replace the pump. Good luck !
Sep 11, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
12 people viewed this question
Top Dishwashers Experts
Owen Barnes
