Question about Dryers
Dryer making rattling noise during use Jenn Air Ultra 22 JDE1000W We have taken off top cleaned but not sure is belt is in proper spot
tzweeb
  • 318 Answers
SOURCE: Kenmore 70 series dryer making loud rattling noise, drying ok
it could be a worn motor bearing, but they usually last for 20 years, i would guess that you have a worn drum roller, the thing that holds up the drum and looks like a wheel.
if your sure the motor has a worn bearing then replacing the motor is not easy as you have to unscrew the blower wheel from the motor shaft.
it also may be that you are talking about the idler pulley being worn. it is the device that holds tension against the belt and they also will wear out and be "wobbly"
Posted on Dec 29, 2008
SOURCE: dryer makes noise as drum rotates on ge profile gas dryer
Solution: the drum slides were worn out and needed replacement.
Posted on Jan 14, 2009
  • 7 Answers
SOURCE: whirlpool gas dryer #lgr 4634 jq0 not drying and rattling noise
is the dryer tumbling
Posted on Jun 12, 2009
dtci80
  • 125 Answers
SOURCE: My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Posted on Oct 21, 2009
erpaalai
  • 999 Answers
SOURCE: Dryer is making a rattling noise.
Rattling could be anything from a bad idler or support pulley or coins in the vanes. If you can hear it you can find it pretty easily.
Eric
Posted on Jun 13, 2010
SAMSUNG steam moisture sensor front load dryer has noises coming from it. Need help to pinpoint possible problems and how to fix.
You may have a roller out of alignment or off track with the drum now if you took the front panel off. Check to make sure the rollers are on track and the front slides may need t o be replaced if your dryer is a 2 roller model.
Feb 08, 2017 | Samsung Dryers
Jenn air ultra 22
spline in the shaft connected to the drum check for wearing out.
Nov 05, 2013 | Dryers
When dryer starts it rattles and then rattles again when it is turned off.
Hi tpasstwo..
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like the drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Note: This method works with most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer if you have to.
Note: Some tops hinge and tilt backwards so they do not have to be removed and the electrical console with stay with the lid.
Also remove the lint filter and the screws holding the lint filter housing in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer by removing two screws located on either side of the top of the dryer housing and unplug the door switch.
This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.Now is a good time to replace the front felt seal on the drum if it needs to be replaced. Be sure to use a good grade of weatherproof cement on the seal to glue it to the drum, sometimes the glue is furnished with the seal.
Now is also a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear they will make a thumping type of noise.
If your drum rollers have too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them and are only squeeling then they probably only need lubrication.
Remove the rollers and clean the shafts that the roller rolls on, remove any hair,dust,etc from roller and shaft.
Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vaseline.
Reassemble the dryer.
Plug back into your electrical receptical.
This should solve your noise problem.
Please take time to rate me thumbs up
Sep 24, 2011 | Maytag Dryers
Our dryer is making a loud rattling noise when drying clothes. My guess is the bearings need oiling. If so, how do I accomplish this?
Hi aardvarksout...
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check your drum rollers for flat spots or wear, if they have flat spots they will make a thumping type of noise or if there is too much wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil, or a light lubricant like Vasoline.
This is a FREE answer, Please take time to rate me
Jun 19, 2011 | Dryers
We have a Jenn-Air Dryer, model JDE2000 that has recently started making an obnoxious rattling noise while running. The belt appears to be intact, the drum rotates and clothes are dry when finished. I've...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Mar 19, 2011 | Dryers
Dryer started making a noise then drum was not working proper. belts is still good
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Remove the lint filter, and the two screws that hold the lint filter housing in place to the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
or wear on them replace them.
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 15, 2011 | Dryers
Rattling noise
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
May 11, 2010 | Maytag PYE2300AY Electric Dryer
Rattling and very loud
Rattling and very loud sounds like a very worn roller on the belt tensioner inside the dryer. The top and front panels must be removed to replace these items. Remove the top first to inspect. Usually the inner bearing on the roller locks up making the roller to receive a flat spot on it which causes the belt to jump upon hitting the flat spot on the roller. That is the sound of the dryers drum you hear
Apr 17, 2010 | Dryers
Dryer is making a loud rattling sound when it is turned on
Your problem sounds like drum rollers have flat spots on them or in need of lubrication. If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Jan 03, 2010 | Dryers
Planer Rattle
If it is belt driven then maby replace the belt. That may be the problem.
Jun 14, 2009 | Tools & Hardware - Others
Dryers Logo
264 people viewed this question
Top Dryers Experts
Marvin
Marvin
