Question about Philips Televison & Video
My HDTV model # 50PP920217F has no sound nor picture, what components should I suspect to be defective?
  • Philips Master
  • 8,617 Answers
THe LSB ( Large Signal Board ) is the number one cause of the two symptoms.
Posted on Jul 14, 2010
How do I fix my hd TV when it works for a few minutes up to an hour or so, and then the screen goes black with no sound
Check out the power supply board. I suspect that after it gets hot after a while it shuts down due to a defective component that is heat sensitive. Problem is that you have an intermittent and you have to wait for the hassle to appear, if and when.
Aug 21, 2015 | Seiki SE551GS 55"led...
Tv has power but no picture
check for defective buffer board, check bad component or burnt parts.
Sep 08, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
I have a big magnavox tv that all of a sudden the picture went out with only sound. I tried everything possible from changing cables and calling my cable company to see if the problem was there but no
Your flyback has failed most likely...bad new is they are nearly impossible to find, This is a known issue on most of the models below. The site Tv Repair Kits can sometimes get replacements - but its not often.
This repair kit is known to work on Magnavox TV sets with the following Chassis/Model Numbers.
DPTV305 , DPTV305F , DPTV310 , DPTV315 , DPTV330 , DPTV330F , DPTV335 , DPTV340 , DPTV345, MAG01
Model Numbers
( 43PP9202/17 43PP920217 43PP9202/17F 43PP9202/84 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920201 50PP920217 50PP920284 50PP920284F 50PP920217F 51MP392H/17 51MP3964H/17 51PP9303H/17 51PP9363H17 51PW9303/17F 51PW936317F 55PP9352/17 50PP920217F 51MP392H17 51MP3964H17 51PP9303H17 51PP9363H17 51PW930317F 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F 60PW938317F 43PP9202/17 43PP9202/17F 43PP9202/84 43PP920217 43PP920217F 43PP920284 43PP920201 43PP920284F 46PP9302/17 46PP930217 46PP930201 46PP930217F 46PP930284 46PP930284F 46PP9302H17 50PP9202/01 50PP9202/17 50PP9202/84 50PP9202/84F 50PP920217F 51PP9303H/17 51PP9363H17 51PW9303/17F 50PP920201 50PP920217 50PP920284 50PP920284F 51PP9303H17 51PW930317F 51PW936317F 55PP9352/17 55PP935217 55PP935201 55PP9363H17 55PP9502/84 55PP950284 55PP950201 55PP950217 55PW936317F 55PW9383/17F 55RW9515/35 60PP9202/17 55PW938317F 55RW951535 60PP920217 60PP920201 60PP920217F 60PP9352/17 60PP935217 60PP935201 60PP9363H17 60PP938317F 60PP9502/17 60PP950217 60PP950201 60PW936317F )
Mar 29, 2012 | Philips Televison & Video
Sound but no picture
The best way is to have a TV technician do the
troubleshooting. It has a defective component
that seems to become ok when your TV circuit
is energized for a while, not at an instant.
Sep 22, 2009 | LG 42LC2D 42 in. LCD HDTV
Mitsubitishi TV model VS50800 (1998) - sound but no picture. What could the problem be, defective 'bulb'?
There may be a switch on the back of the TV that chooses whether to output video to the component connections or the RCA/S-Video connections.
RCA cables - red, yellow, white
S-Video - single cord (usually black)
Component Video Cables - red, green, blue
Sep 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Convergence menu not available on my RCA HDTV. Model R52WH74YX58 I have installed all 3 new fuses as well as DL231 and CP230 and resoldered the pins on the flyback and IC, but I still have not got an...
The only fuse that will govern the convergence option is FL231 along with the two other components that you mentioned. If that didnt fix the issue the deflection board or the convergence power supply is defective. The deflection board is most suspect.
May 26, 2009 | RCA R52WM24 52" HDTV Projection Television
NO PICTURE
There's an internal electronic parts of your HDTV that are cold soldered / defective. I suggest to bring the unit to an authorized service center to properly diagnose and fix it. best regards
May 22, 2009 | Mitsubishi Power Adapter for DiamondPoint...
Phillips HDTV looks like it is in 3D
Your convergence ic's went bad and possibly took out the fuses in that circuit. I believe they are stk392-120's on that set. Also, check all the resistors around them. Should be located on two heatsinks near front of chassis. Good luck.
May 19, 2009 | Philips 50PP9202 50" Rear Projection...
Panasonic pt 53tw53 rear projection
Check the vertial output IC. either for defective solder or defective IC. This model has a feature if the vertical output IC fails for any reason the picture tubes blank out as a safety issue.Thereby giving no picture but audio still functions.
Mar 11, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Televison & Video Logo
67 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
