Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Freezer fan on compressor off
I have an older freezer kenmore model 253-9218711, power was off for 6hrs, upon power comming back on, freezer compressor never started. Light works, fan is working freezer warm ( due to compressor not turning on. cked for voltage at compresser, 0 volts, cked for voltage at power cord and relay have 120v. compressor is not open has reaistance for what get ohms were. Where can I start to look for the issue? defroster timer, or ?
Tks for the help.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 117 Answers
They make generic "compressor packs" to solve these. Your capacitors and relay and parts that support the compressor operation went out.
If you're really really like just the temp overload switch went and you can jumper bypass it. It usually looks like a piezo electric type of disc connected right onto the comp case itself.
But you're right with the DT, the motors go out on them a lot. They are usually for 4/6/10/12 hours depending on make and model. Sometimes the contacts go So if you could isolate them... they're on the larger side and will go from the power to the compressor. Use a jumper and test for a complete circuit to the plug and through the compressor before trying it.
By law all freezers and ovens have to have a schematic diagram on them. Often it it in a little plastic package and sometimes just wallpapered to the inside of a large piece of sheetmetal in back.
Good that you know how to use a meter!
Posted on Jul 14, 2010
My freezer turns on when plugged in and cools to below zero, then shut off and warm to 37 degrees before turning back on. I just replaced the temperature control thermostat and the defrost thermostat.
Sounds like compressor is overheating and taking hours to restart. check by listening for the hum of the compressor shortly after it has reached temperature. also check the condenser is clean and fan working.
Dec 07, 2015 | Kenmore Freezers
I have a kenmore chest freezer model 19502/19702. I had it unpluged for 5 months. When I plugede it back in the power light flickers. Tryed other outlet. Other then that it seems to be working
We purchased this same Kenmore chest freezer model 19502/19702 in 2010. In less than 2 years the compressor quit. If you do a search on this model you will see dozens of complaints. Don't waste your time or money on this freezer.
Apr 16, 2012 | Kenmore Freezers
Kenmore freezer model C10BLEM blows circuits. I just bought it used. At original owners it worked well. I plug it in and after a couple of minutes it blows the circuit. I plugged it into the furnace...
If it is a chest freezer, almost certainly it is the compressor. Only way to check is to pull the power plug out then remove the compressor wires from the terminals then make sure it doesent touch the frame of the freezer, then plug the power back in and see if the power trips again. If not, there is the problem.
Aug 22, 2011 | Kenmore 22.7 cu. ft. / 643 liter Chest...
Kenmore chest freezer does not stay below 30 degrees compressor runs but I don't see a fan to cool the compressor
If your chest freezer is less than 50 years old, it does not have a fan. Cooling coils contact inner walls of freezer compartment, warm coils dissipate heat through outside walls of freezer. If compressor runs, temp is 30+ degrees, gasket is OK, lid not left open, then you have one of two contions: 1. Low capacity compressor 2. Refrigerant leak. Solution to either is to replace freezer. (My opinion: Don't get a Kenmore brand, which generally ties you into poor warranty and slow and poor service.) No matter what brand name is on the freezer, it is most likely manufactured by Electrolux (in St. Cloud, MN) or Haier (from China). Look at the model / serial number plate before purchase to see where it was manufactured. Yes, the USA manufactured ones are better. (and I'm not just saying that because the plant is less than 15 miles from where I am sitting right now)
Jan 01, 2010 | Freezers
Freeezer with no compressor activity
If all fans are running, but not compressor You could try to install 3 N 1 start kit, thats might help 50/50. If it will start compressor - be ready for compressor to go out soon. might work for a year.
Dec 13, 2009 | Kenmore Freezers
2 year old Kenmore freezer won't keep cold. It
Check underneath the unit and make sure the compressor is running and that the compressor fan is turning.
Oct 15, 2009 | Freezers
Kenmore Freezer Model 253.26732104 Compressor
the defrost timer may need reseting. when the defrost is on, it cuts power to the compressor so they don't run at the same time. it's usually behind the bottom front grate on the right side. also check the main circuit board. there's a fuse on it.
Jul 31, 2009 | Kenmore Freezers
We lost power due to storm since restored and now the compressor starts but stops within 30 seconds and does this over and over
It sound like your compressor is in trouble, I would try and see what amp. the compressor is running in this 30 seconds. If it is over the name plate requirement I would try to change a 3 in 1 electrical component to see wheather it helps. Check your amp. at all time.Hope this help.God Bless
Jun 25, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore upright freezer
No it is not the timer. You may have an open overload protector at the compressor. Check across the overload for a reading with an ohm meter. If it reads zero it is good, if not replace it.
Sep 13, 2008 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Kenmore upright freezer.
Will need a little more information to assist you with answers. Will need the model number if available for you Kenmore and will usually be on inside Freezer/refrigerator door and near bottom. Will look like model #363.1234567 for example.
Now if it's not cooling at all, is the compressor running beneath the fridge? Is the condenser fan running that is below the freezer and near the compressor? Is the evaporator fan blowing air in the freezer section? Do you hear clicking noises in the compressor area and can you feel the compressor to see if you feel warm or hot to touch around its side and top? Can you tell me of any other things that you noticed before the refrigerator stopped working? Is the temp control digital or manual settings? Has the settings been changed since you turned the refrigerator off and then back on? Thanks, Sea Breeze
Oct 28, 2007 | Freezers
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
289 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
