Question about AOpen MS-810 Computer Speakers
AOpen MS-810 Speaker DIN 8 control connector
Hi!!!
On AOpen MS-810, on DIN 8 control connector... I don't know the pin distribution. Could you please show me that. (both male and female connector)
Thanks in advance
5 Suggested Answers
SOURCE: which transformer to use
To solve the problem I tosted the whole mess of wires and equipment and bought new equipment. $8,024 spent and now all the new converters are labeled. The industry needs to mark all equipment with DC-IN 9V or whatever. This is a real problem if you have kids and grandkids and too many different standards.
Posted on Dec 16, 2008
SOURCE: I need a circuit diagram for My Logitech Z-640 Computer Speakers
You may have to call Logitech support or email to find out what the pin out is. that would be my only solution if there is one.
Posted on Apr 24, 2009
SOURCE: Connecting BA735 digital 3.5mm plug with S/PDIF coax jack
The male mono plug (from the left small speaker) should be connected into the right speaker (small speaker with controls) . After plugging the multi pin cable from the control speaker to the sub-woofer you need to plug in a signal source from your computer (or any other digital signal) into the sub-woofer. This digital input looks like an ordinary RCA plug but carries many channels of audio. That connects to the enabled digital output of your computer. Some computers output digital through a 3.5mm jack others look just like an RCA phono jack. If you are lucky some BA735 sub-woofers have a second input that is a standard 3.5mm stereo jack and it will take analog audio from computer, DVD, MP3 player or the like. I have three sets of these speakers that I love because of their big volume considering such a small size.
Posted on Apr 30, 2009
damnor01
  • 1179 Answers
SOURCE: I have got a system
The actual Processor fan connects to the CPU Fan header on the mainboard. It's 4 small pins. It plugs in right near the CPU socket on the mainboard. Check the user manual for exact placement, you may download it from the AOpen website if you don't have one already.
Plug in the 20Pin connector if that is the most Pins that the mainboard will allow. Cable tie the other 4Pins back onto the 20Pin connector.
Then if there is additional 4Pin connector required by the mainboard for CPU power and you don't have that connector on you power supply, you will need to purchase a Molex to 4Pin CPU power connector. When you go to the computer store check with them that all is correctly connected.
Take care!
damnor01
Posted on May 25, 2011
Pinout for 8pin din plug
Hi looking at female 8 pin din with the groove at bottom this is No 8 going clockwise to the left is pin 6 next is No 1 then 4 - 2 - 5 - 3 - 7. ..Hope this helps..
Jan 27, 2016 | JVC Audio Players & Recorders
Anyone know where to get an 8 pin din cable for my Yamaha YST-MS55D multimedia speakers?
I just bought one here in Holland in the handyman store. Where do you live?
Oct 07, 2014 | Yamaha YST-MS55D Computer Speakers
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
I have got a system with an Aopen motherboard which having only a 20 pin connector for smps connectivity. the Atx smps i have is is 24 pinned. i can connect the main line by splitting up the 24pin...
Take care!
damnor01
May 25, 2011 | AOpen MX4GER Motherboard
Vizio VZ42L. HDTV has stereo speakers connected by what appears to be 5 pin DINS to the television. I would like to use one of the two speakers as my "center" speaker for the surround sound. Is...
Hello
Your Vizio has a 5 pin din connector to take the speaker connection out. There is a 'noch' in the din socket from which count towards left; the first is pin number [1] second is pin number [4]; third is pin number [3]; fourth is pin number [5]; and fifth is pin number [2]. Out of these, pin numbers [2.4&5] has no connections from inside, that is [NC]; not connected. Pin numberes 1&3 are two speaker positve terminals, and the body of the 5pin din pin will act as negative to both channels, that is common.
The company has provided only two channel stereo sound from it to out. There is no provision to get a center speaker out of it. OK.
Feb 12, 2011 | Vizio 42 in. LCD TV
Someone gave me a YST-MS50. The left speaker (no controls) does not work. It is not the speaker or the cable from the main unit to that speaker. I find that only 7 of the 8 wires in the 8 pin cable going...
If you don't get it to work would you be willing to sell me the right satellite speaker with the controls? email me: red...4..dsc..@....g..mail.com... (just take out all the dots)
Dec 05, 2010 | Yamaha YST-MS50 Computer Speakers
What Is the Blue Input Port on the Back of the AOpen Subwoofer?
It is a proprietary controller that plugs in to that port. Kind of a wired remote, that controls on/off, subwoofer volume, and speaker volume.
Aug 17, 2008 | AOpen MS-810 Computer Speakers
Replacing a Blaupunkt Reno with Florida
Hiii...
This is a PIC mybe can be help you...
Thank's
Jan 27, 2008 | Blaupunkt PA4100 Car Audio Amplifier
Looking for a control pod.
I recently had a similar problem. In my case the left speaker had no sound. Finally traced the problem to a broken wire inside the control pod plug, which I destroyed by dissecting it. For those who have the experience, or know someone who does, purchase a new plug, which a Mini DIN 8 pin (RS-422 standard). It should be available at any good electronic parts store. Solder new plug on to cable, which requires a fine electronic soldering iron and a fair bit of skill (the wires are very fine).
Look at the plug (from the rear); you will see it comprises a top row of 3 pins equaly spaced; a middle row of 3 pins (there is room for 4 pins but one pin is missing just left of centre); a bottom row of 2 pins. I numbered these as follows:
8 o 7 o 6 o
5 o 4 o 3 o
2 o 1 o
The wire from the controller comprises 8 coloured cores and a bare core. The wiring of the eight cores are as follows:
DIN CORE PCB
pin 8 - brown 8
pin 7 - red 7
pin 6 - orange 6
pin 5 - yellow 5
pin 4 - green 4
pin 3 - blue 3
pin 2 - white 2
pin 1 - black 9
body clamp - bare wire - G
In case your coloured cores vary from mine I have also listed the pin each one goes to on the printed circuit board plug, which will let you identify the colours.
Oct 11, 2007 | Level 9 Sound Designs Monsoon Planar Media...
AOpen MS-810 Computer Speakers Logo
73 people viewed this question
Top AOpen Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an AOpen Audio Player and Recorder Expert? Answer questions, earn points and help others
