Question about Refrigerators
I have a Whirlpool (WRN28*WG6). I don't think the thermometer switch which controls the damper gate is working. It stays open and everything in the fridge section is freezing. I need to purchase the thermometer and damper switch which controls the damper gate. Where can I get 1 one these? Temporarily, i have fixed the gate from opening and closing, but its hard to get the right temperature in the fridge.
  • sve_chen Sep 11, 2008
    I have exactly the same model fridge-freezer and it froze my food in the fridge section. I started off reducing the temperature settings (it has no temp control in the fridge, just one dial in the freezer...) and will see how I go.
    Additionally, though, my fridge doesn't seem to have "resting" periods. It's running all the time! Is this normal? What could be the problem and can i fix it myself?
  • Anonymous Nov 15, 2008
    "Me Too" - I'm looking for a source for this thermostat, or even just a part number so I can search for the right component. There's nothing identifiable on the assembly, except the (indistinct) number PDC228SB on the damer itself.
HVACRH20
  • 237 Answers
SOURCE: Hot point side by side electronics not operating damper
See if you have some paperwork on how to test, etc. located in a plastic bag taped up to the underside of the fridge. Pull the front vent cover off and you should see (feel) a bag taped up there with the test paperwork in it. If you don't have it let us know and maybe I can email it to you.
Posted on Dec 26, 2006
watugot
  • 290 Answers
SOURCE: Everything freezes in the refrigerator
Your damper that controls the air to the fridge side is stuck open. It can be caused by moisture getting on it and freezing it so it wont close or by a failure in the electrical circuit that controls it. There was a service bulletin from about 3-4 years ago about defective control assemblys. I have replaced several and as far as I know Frigidaire is still replacing some of them for free if they fall under the model and serial numbers that were affected.
You can tell if it is frozen by turning the controls off and thawing the damper at the upper left rear of the fridge section with a hair dryer.. After you have it thawed out, turn the controls back on and you should hear the damper door motor running. Keep your thermometer in it and check it after a while and see if it shuts off before it freezes.
Post back with the complete model and serial numbers and I will try to locate the service bulletin at my shop computer tomorrow.
Posted on Oct 26, 2007
hotuna
  • 288 Answers
SOURCE: Whirlpool Side By Side GD5RHAXNQ00-Electrical Issue
The arcing noise is just that, a loose connection causing electricity to arc from one place to another. this is initiated by opening the door and closing the light switch. The small glow is from a small amount of voltage reaching the bulb. If you are inclined, repair it. remove the cover, look for the burnt wire or connection. If its a removable part, replace it. If not clean it up and/or make a new connection. One thing is for sure, it will not get any better and may get worse and burn up something more critical.
Posted on Jan 13, 2008
Krames
  • 18 Answers
SOURCE: Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Posted on Nov 15, 2008
  • 175 Answers
SOURCE: The freezer section is working ok but the fridge
hi..you may have a coolant leak and need it repaired
and recharged.
check this out..
thank u..
kindly rate my response..
Posted on Jun 14, 2009
GE Profile Arctica fridge running too cold
You may want to check your damper assembly to see if the door is broken. If the door is broken it will air to migrate to the refrigerator compartment causing freezing issues. Also check to make sure that the damper door is not staying open. When you take the cover off with the door open the damper should close. If the damper is open then you need to replace the damper. Here is the damper to order.
Dec 05, 2012 | GE Refrigerators
Why is Fridge not cooling well?
The part number you need is going to be WR09X10050. This is for the damper assembly, but while you are at it change out part number WR55X10150. this is the part that controls the damper and more than likely if one fails the other will be soon to follow
Jun 05, 2012 | Hotpoint Refrigerators
I have a side by side Kitchenaid fridge (Model KSRA25ILSS02). Problem is that the fridge side is not cooling proberly. I have cleaned the consdenser fan and coils on the bottom of the fridge and have...
turn temp all the way down in fresh food side and open the door but hold the door switch closed. damper should open when unit finds temp too high. Could be damper or control if it does not open.
Apr 14, 2011 | KitchenAid Refrigerators
When I open my rear gate the done and interior lights stay on when the gate is closed. I have to pull the fuse. If I drive around and put the fuse back in the lights stay off till I open the gate again and...
Hello, it sounds likethe switch that controles the light is jaming, try pushing the sswith in and out firmly with your finger. If you get the same responce as you do when uou close the tail gate you have found the problem. The switch may need replacing.
Nov 05, 2009 | 2000 Jeep Grand Cherokee
Whirlpool bottom freezer 5 years old everything freezes in the fridge
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 10, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Side by Side GE Hotpoint Refrigerator HSS251FMCC
You may have a double problem. One, you state that the damper stays shut. if the box is running 50 degrees, it should be wide open, My question is, do you think because that there is no air from the damper that it is closed? The usual problem on these units is that it is not defrosting and the evap coil gets blocked with ice. This will cause an air flow problem to the ref side, although the freezer seems to work. The most likely cause is a bad defrost heater. If not, then possible a bad damper if it is not opening.
Aug 30, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Oct 26, 2007 | Frigidaire FRS26R4C Side by Side...
Refrigerator side freezing
kjn, I think what happened here is that the automatic damper assy. is stuck in the open position. This is why everything froze in the refer area. This includes the water filter and cartridge. I would unscrew the filter cover and see if it's frozen in there. If you find the filter frozen, take a hair dryer and go over it lightly until it will unscrew. After that you will have to check to see if the damper is stuck. You should be able to hear it open and close by turning the control on and off. Or get a mirror and hold it at an angle in back to see the gates. Part number for the damper motor is 240440701. Not that hard of a job...Catriver.
Jun 14, 2007 | Frigidaire FRS26R4A Side by Side...
Kitchen Aid Refrigerator Issues
Great job on the defrost drain fix, it's exactly what we do. Check that the duct damper does close fully when the refer side temps are set to warmest. It could be freezing due to that damper not closing fully or at all. It should only be open to let cold air in until the temp is satisfied then closes again. The temp control in the refer may also be failed so it doesn't know the temp was reached. The bi-metal is only there for a safety device basically to kill power to the heat elements if the defrost cycle runs too long or the area gets too hot. I'd suspect the air damper is stuck open and contstantly letting cold air into the refer side.
Feb 03, 2007 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Refrigerators Logo
386 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
