Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
How do you recover the data from my external harddrive
    President:
  • 2,571 Answers
You can try to open the enclosure and fit the drive into a pc, or buy a new enclosure to fit it in, they are quite cheap.
You can buy a caddy that you just push the bare drive into.
Posted on Jul 13, 2010
Can data recovery be done after cloning another harddrive onto it?
Very Rare Chance to recover all data. you might get some. that too if those sectors of hard drive are not overwritten while cloning.
May 14, 2016 | Toshiba MK1059GSM 1 Terabyte 1TB SATA/300...
How to Recover my password protection manager when i accidentally deleted in sony 1tb external harddisk
Did you delete the program from YOUR computer, or from the actual Harddrive that stores your data? THe link to download is here and they also have support... http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-rme/sw_hdd_pwpm#supported_products
Dec 08, 2014 | Sony HDE1/B 1TB External USB Hard Drive...
Usb external hard drive not detected
If you can hear the hard drive spinning you have a chance of recovering the data. The only program I have known to recover the data is `Easy Recovery Professional` Once the data is recovered you may be able to format the drive.
Jan 19, 2014 | Lenovo Computers & Internet
Asus pro31f series duoT2350 notebook does not boot up. Potential motherboard failure? How do I recover data?
A) Remove ALL power. Remove the AC adapter (Charger), and Battery.
B) Remove the Harddrive;
According to specifications it is a 100GB SATA harddrive.
Harddrives are measured across their width.
A laptop harddrive is 2.5 Inches across in width. (2 -1/2 inches)
Desktop harddrives are 3.5
Install the Asus Pro 31F harddrive in a 2.5 SATA external enclosure.
The external enclosure has a USB cable. Turns your laptop harddrive into an external harddrive.
One example of a 2.5 SATA external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
C) I believe what may be going on, is you have a failed Power MOSFET, or Power MOSFET's.
?O_O?
MOSFET,
http://en.wikipedia.org/wiki/MOSFET
Power MOSFET,
http://en.wikipedia.org/wiki/Power_MOSFET
D2PAK surface mount,
http://en.wikipedia.org/wiki/D2PAK
(Requires using a clip heatsink on each lead when soldering.
After all, this uses Transistors )
Motherboard problem, yes I believe you may be correct.
Repairable? Yes.
Find a tech that can perform this? Isn't easy.
Most just want to replace motherboards.
Why? More $$$$$$$$.
(Ahem, I'm telling you about it, so I am not one of these noobs! Lol!)
Regards,
joecoolvette
Jul 30, 2012 | Computers & Internet
My Lacie external drive clicks but won't spin up. It is about a year old, maybe less. It was working fine and just stopped working. It has not been dropped. In fact it hasn't been moved.
Your harddrive is bad, the motor bearing that spins your cylinder heads is damaged, even though the harddrive hasn't been dropped, or removed, this is a result of faulty and cheap product. Theres nothing you can do to replace the motor bearing, you will need to just get a new harddrive and install into the external hd enclosure or get a new external drive. If you decide you want to recover your files, you will need to take this harddrive out and maybe take it to bestbuy/ office depot where they will have to send your harddrive out to a data recovery center. They might be able to recover some data, or all, or none. It is a pricey move to take this step.
Jan 28, 2011 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Data disappeared overnight
I've seen a lot of flack about these puppies lately. It's usually due to the external enclosure, the harddrive is in, and not the harddrive itself.
It is for this reason, that I suggest that you take the harddrive out of this enclosure, and install it into a decent, affordable, new external enclosure.
External enclosures are relatively cheap!
The harddrive inside the Maxtor One Touch II is a desktop size harddrive. It's a 3.5 inch one.
(3 and a half inches across in width)
It is a Sata harddrive.
These are examples of external enclosures for a Sata 3.5 inch harddrive,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(My recommendation would be the Vantec NexStar 3 NST-360 Su-BL)
This external enclosure has instructions, is easy to install the harddrive, and uses a USB cable just like your old one.
May 14, 2009 | Maxtor OneTouch II external hard drive...
Can the disc of a external harddrive be change to get your data recovery back
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jan 14, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
External Hard-Drive Problem.. Please Help!
hi there, from what you are describing u have problems with the harddrive plotters so you have little time to save data. using the program get data back for ntfs or fat you can format your harddrive and block bad sectors from your harddrive and with the program mentioned above you can recover all the information you had on your harddrive.
give it a try
Jan 07, 2008 | Western Digital My Book Essential Edition...
Acomdata external harddrive gone blank.
dont copy any data from or too the disk then use recover software. like Recover My Files, and if you copy any data to that disk it will damage the data you want.
Jan 06, 2008 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
127 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
