Question about Hotpoint Aquarius WF000 Front Load Washer
Lights flashing hotpoint aquarious wf541G several lights flashing and will not start
Temp solution, switch on and off at wall socket with on/off switch in and out, untill only on/off switch is lit, then use wall switch for power on off. worked for me.
Posted on Jul 25, 2010
Hotpoint aquarius dishwasher, programme seems to be stuck on eco 45, have tried swithching power off at mains as suggested, soon as power is back on washer selects eco 45 and starts but does not run any cycle or fill,<br /> Thanks for any help,<br /> Barry Davies<!-- from fixya rte -->
Posted on Aug 16, 2010
Hotpoint Aquarious WF210. Machine stops mid cycle...Reduce Creases and Time Saver lights flashing. On-off flashing quickly. Any suggestions ?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} For Hotpoint, Creda and Indesit error code definitions use this link. This will give you some idea as to where the fault may be.
Mar 06, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Error code F-05 for hotpoint aquarious washing machine
your pump/filter/outlet hose is blocked. clean it all out with the power off.
Oct 30, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
All lights flashing on Hotpoint WF541G washing machine
It's probably a loose connection in the wiring in the machine. Seems to be a problem with the WF741 machines and is most likely a similar issue with yours. The probability is that the vibration from the machine is enough to work some connections loose. If you have someone competent to do this, then check that all connectors are pushed firmly onto their circuit boards. (I have posted a separate reply to this issue for the WF741 model on here.) See if this helps.
Oct 09, 2009 | Hotpoint Aquarius WD63 Front Load...
Machine fills and drains at the same time.
Check the height of the drain hose and make sure the drain hose is higher than 30 inches from the ground. If your drain hose drains into the floor you may need to purchase a siphon break to stop the problem
Apr 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
May 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
595 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
