Question about Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer doesn't restart after interrupt
I have a maytag Neptune washer. I had started a load to wash and needed to add some more clothes after it had just started the cycle already and a little bit of water was already in the washer. The lock light had just lit. I held the start/stop button in for 5 seconds and the machine stopped and then the door unlocked a few seconds later.
I then added the additional clothes and started the washer again.
The cycle started but only ran for about 5 to 10 seconds and then stops. I have tried by advancing the cycle knob to various settings and then pushing the start button to see if the cycle will kick in again, but it always runs for a few seconds and then stops again.
How do I fix this?
Thank you in advance for your help.
    Brigadier General:
  • 3,917 Answers
Hi
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
Is the cold water turned on? If not, turn it on.
Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean.The water-inlet valve is the device on the washing machine that the fill hoses are attached to.If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 13, 2010
Where do i put liquid detergent in top stacking may tag older model
Just pour the liquid/powder into the wash tub prior to loading clothes... this machine does not have a detergent dispenser...
Jul 06, 2014 | Maytag Neptune MAH5500B Front Load Washer
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
How to fix a errow ob on maytag washing machine
OB is an out of balance load error, try re-distributing the clothing and see if it helps, also make sure the machine is level, if this doesn't help there may be a fault with the out of balance switch or lever.
Mar 06, 2012 | Maytag Neptune FAV6800AW Top Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Maytag neptune washer clothes staying wet after cycle
    Is your door lock light on when machine is in use? I am having the same issue as you and I believe it is because my door is not locking during use.
    Apr 17, 2010 | Maytag Neptune MAH5500B Front Load Washer
    My Maytag Neptune front load washer displayed ND with 19 left in wash cycle. Door won't open, what can I do?
    Not draining,throw rugs tend to clog this unit as do bobby pins and under wires I'm giving you a link to the repair manual it covers the 3000 through 5500 it will help you get the door open and the clothes out so you can start bailing...
    http://www.servicematters.com/maytag_library/docs/16010061.pdf
    Sep 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
    Can't interrupt the washing cycle on coin operated Mah21pddww
    Unplug the washer, wait three minutes for the door to unlock then do what you need and plug it back in. Should still have the time left on it that was there when you unplugged it.
    Aug 17, 2009 | Maytag Neptune MAH5500B Front Load Washer
    My maytag neptune wash machine does not drain and spin clothes it
    its ok dc means the clothes are unbalanced..even the load open lid and restart..onthejob
    Jan 31, 2009 | Maytag Neptune FAV6800AW Top Load Washer
    Maytag neptune front load odor
    its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
    Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
    Detergent goes where?
    3 - Select Cycle
    This is according to the owner's manual I have. Has worked for 9 years for me.
    Jun 28, 2008 | Maytag Neptune MLG2000A Front Load Stacked...
    Maytag Neptune MAH5500B Front Load Washer Logo
    130 people viewed this question
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
