Question about Dishwashers
I hsvr s kitchenaide kudg25shwh1 and it will not pump out at the end of the cycle on both the normal and soak and scrub settings...only pumps out when cancel is pushed...do i need new electronics?
  • david65972 Jul 13, 2010
    The water pumps out completely when the cancel button is pushed, therefore the hose is likely not blocked, and the pump seems to be working properly...why would the machine pump out only when cancel is pushed and not during a regular cycle???
  • 6,784 Answers
Hi. This will be a control fault. Before you replace the control, kindly, shut down the appropriate circuit breaker for five minutes. You can also unplug the unit, if possible. Let the Microcomputer sit for five minutes with out any power. This will force the logic chip to reset. Once the five minutes are up, simply, reintroduce power to the unit and try to run a normal cycle. If you experience the same issues after the hard reset, this will confirm that the Microcomputer is indeed damaged.
In this case,You will need to have the affected board replaced, asap. Once replaced, the unit will operate correctly. The necessary part number will be 8530929.
Posted on Jul 13, 2010
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
Our ken ore elite dishwasher 66513423k701 clean button flashes 6 times pauses and flashes once. We did have a problem with the dishwasher dumping water all the floor and discovered the discharge pump was...
It sounds like you just need to reset the controller. This is done by running (or partially running) a diagnostic cycle, which will clear the error. Here's how to do it: Depending on the model, and the keys you have, press the following sequence of keys quickly (with less that 1 second between key presses:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
You will know that you have entered the diagnostic cycle when all the lights light up. Let it run for a few minutes, and then press Cancel to stop the diagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jan 18, 2015 | Kenmore Dishwashers
Run a service test for kitchenaid dishwasher
Did you check behind the toe-kick panel for the tech data sheet? Assuming that you have checked and that it is missing, there here is the "secret keystrokes" that will make most Whirlpool/ KitchenAid/Kenmore/Maytag diswashers enter the diagnostic cycle:
Oct 18, 2014 | KitchenAid KUDS30IXSS Builtin Dishwasher
My system keeps flashing the 90 code indicating low water flow. My pool is full. What's wrong and how do I get the system to run normal? I just set the pool up and it has flash this cood from the...
Most low flow alarms are caused by the pump stopping before the chlorinator cycle ends. You must set the chlorinator hrs between the pump cycle. Start and set your pump cycle, wait at least15 to 30 minutes and then set you chlorinator hrs and make sure to it completes it's cycle at least 15 to 30 minutes before the pump cycle ends, If your pump turns off before the chlorinator cycle ends, you will get a low flow alarm......
Hope this helps, if it does, please rate...
Jul 25, 2011 | Intex Automatic Salt Water System for ...
The "clean" light blinks 7
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Jun 28, 2011 | KitchenAid Dishwashers
My kitchenaid keeps flashing clean and when you push the start it has a 2 and
Hi
If clean light is blinking 7 times then it may be an issue with heater circuit, door switch or wash pump. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
Daniel
May 18, 2011 | KitchenAid Dishwashers
Will not cycle. clean light flashing 7 times and then goes out, and then flashes 7 times, and this is a constant sequence
Hi
If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back for further assistance.
Daniel
Mar 19, 2011 | KitchenAid 24 in. KUDS01FLBL Built-in...
Kitchenaid dishwasher....clean light will not turn off. Dishwasher will not turn on. Just had motor and pump replaced on Thursday 12-30.
Hi
If clean light is blinking indicates an issue with heater circuit, door switch or wash pump. To resolve this please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset.
Daniel
Jan 01, 2011 | KitchenAid Dishwashers
We can't get it to cycle.... the green light next to 'clean' is flashing on the panel - can't get it to stop flashing and run??
Found it; High temp scrub--Energy saver dry---High temp scrub---Energy saver dry--press start, close door ,wait for it to reset,open door press cancel and you are ready to go.
Jul 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Setting cycles and turning dishwasher on
Frenda Most likely the problem with your dish washer is shorted one or more pads on the key panel. To fix it the key panel has to be replaced. If you'll provide the complete model number and color for the control panel for your dish washer, I can help you to find the best deal on this part. Gendos
Jan 17, 2007 | KitchenAid 24 in. KUDG25SH Built-in...
Dishwashers Logo
Top Dishwashers Experts
Marvin
Marvin
