Question about Woodcraft Pirate Ship 3d Construction Kit
HOW DO YOU ASSEMBLE THE SAIL AND RIGGING? - Woodcraft Pirate Ship 3d Construction Kit
What equipment do I need to start windsurfing?
Windsurfing equipment consists of board that looks like a big surfboard and the rig. The rig is like the engine. It has many parts including the sail, the mast, the boom (the part you hold on to) and the extension and universal.
The choice for your first windsurfing board and sail depends on many factors. The main ones are: sailing conditions where you sail, your weight and your ability. Stronger winds, less weight and higher skills indicate a smaller board and sails. For most people a board with more or less 180 liters of volume with a sail around 4.0-6.5 sqr.meters is the perfect starter package.
from http://www.uswindsurfing.org/?page_id=70
Feb 27, 2013 | Water Sport
Wish to tackle rust spots and areas on steel boat
To stop rust,the best thing to do is chemically convert it.remove loose paint and rust with a sanding disc,then treat the remaining surface rust with phosphoric acid/water solution(the acid is available at lowes or home depot pretty cheap).It converts iron oxide to iron phosphate(which is stable and paintable).Take a paper towel soked in the solution and stick it down on fairly heavily rusted areas to sit overnight,maybe also followed by saran wrap to keep it wet.
Mar 14, 2012 | Cars & Trucks
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
The water runs constantly, not just when the furnace turns on.
Do you have a sail switch or current sensing relay with this humidifier? In order for the humidifer to turn on and off u need either a sail switch that senses airfllow in the return air duct and will turn off the humidifier when the blower motor stop or a current sensing relay that senses current on the blower motors common wire. I will post of pic of each one
Jan 03, 2011 | Aprilaire 700 Humidifier
When i turn my rear defroster on in my 2002 impala my radio just cuts out and gets nothin but static. ive tried adjusting the antenna which way it faces and everytrhing but it continues to not work. any...
I believe there is an antenna coil located behind one of the 1/4 sail trim panels. I ran across this when I had to put a strut in my 1999 LeSabre. Back seat, sail trim and package shelf had to be removed to access upper strut mount. Mine was behind the left sail trim. Removing the sail trim I knocked the cover off so I asked my GM parts guy what it was. It was radio related. I believe the back defogger grid is the radio antenna. It was around $18.00. I would check that as my son's 2002 Impala rear defog is inop and that's one of the things I will be checking. Good luck.
Dec 05, 2010 | 2002 Chevrolet Impala
INSTALLED HE360A, FAN MOTOR RUNS, EVEN WHEN FURNACE IS OFF? IS THIS NORMAL
Yes - but it doesn't have to work that way. There are several methods you can use to have the humidifier run only when the furnace runs. Look on the back page of the installation instructions. The method I chose was to install a sail switch. This is a switch with a arm attached which has a "sail' attached to it. When the furnace blower runs, the sail catches the blower airflow and activates the switch; allowing the humidifier to operate.
You can also wire in a current sensing relay (figure 6 on the instructions) or connect the humidifier directly into the furnace motor ignition box (if so equipped. My furnace dates to the late 70's and has no place to plug in a humidifier; which is why I installed a sail switch.)
Now however I probably would go with the current sensing relay option as this looks to be the easiest route to follow. Honeywell has their 32001754-001 avaliable for less than $35 from Sears.
Dec 01, 2010 | Honeywell HE360A1027 Whole House...
Error code F64 on lower thermador oven. Works for a minute or so then beeps and F64 is showing,
Hi, i found out from Thermador customer service that error code F64 means that the lower fan switch (located inside the bottom trim on the right side) is not being detected as closed. In my case, this was because the header (P4) on the Display panel had broken loose from the PC board and was no longer making contact. P4 is where the lower fan switch wires connect to the control boards (actually the display panel).
Nov 12, 2010 | Thermador Ovens
What is the most important sailboat hardware?
If you are looking to sail with comfort, safety or performance you may have to put together not only the wind, the ocean, the sails but your sailboat hardware.From blocks for proper sail trim to furling units for easy sail handling. These are examples of some important salling hardware: Bailers, Blocks, Rigging, Winches, Shackles and rope cluches.
Aug 12, 2010 | Cannon Boating
Whats a sail switch
A sail switch is a Blower "on" proof switch. It's purpose is to prevent equipment such as air cleaners and/or humidifiers from energizing unless the blower is running. The sail switch literally has a sail that is put in the ductwork. When the blower starts, the airflow will push the sail so as to close a switch allowing accessory equipment to operate.
I hope you find this information to be very helpful to your moving forward. Let me know if you have any further questions, comments, or concerns.
Please leave a rating. :-)
May 11, 2010 | Aprilaire 550 Humidifier
Age of Sail Privaterr's Bounty will not play
You need to run it under windows 98 compatibility mode:
To do this locate the file "privateer.exe". By default, this file is located in Program Files/Global Star/Privateers Bounty - Age of Sail 2.
- Right click on the privateer.exe and select Properties.
- Click the Compatibility tab.
- Check the Compatibility Mode box by clicking in it.
- Use the drop down menu to select Windows 98/ME.
- Click Apply, and then click OK to close the window.
Hope this helps.
Graham.
Jan 08, 2009 | Global Star Software Age Of Sail 2:...
Woodcraft Pirate Ship 3d  Construction Kit Logo
71 people viewed this question
Top Woodcraft Toys Experts
ray gallant
Are you a Woodcraft Toy Expert? Answer questions, earn points and help others
