Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Ph level for saltwater intex system is too high and water is a bit cloudy what do I do?
  • 11 Answers
Get your water tested at your local pool store and they are going to tell you to add Muriatic Acid. Follow their instructions carefully, hopefully they are a good company. Salt water systems tend to drift the pH slightly basic (high) because of the offgasing of Hydrogen ions in the water. Hayward Mineral Springs salt has pH and alkalinity buffers in the salt already, depending on what brand of salt you are using, that might be your problem.
Posted on Jul 14, 2010
Help brown pool water, high iron content in well
your alkalinity is way too high. It shouldn't be above 7.8... 7.4 - 7.6 is ideal. I use muriatic acid to lower my ph. Also, your alkalinity is too high. should be between 80 and 120.
There is a sequestering agent you can use to try and drop the metals out of the water, if any are present. You stated you had high iron.
However, before tackling the iron, you need to get your ph under control. Chances are if you get your ph and alkalinity in line, your water will look a whole lot better.
If it is still cloudy, I would use a floc product.
Jun 19, 2013 | Intex Automatic Salt Water System for ...
My intex saltwater system pool is cloudy
The chlorine level maybe too low and it is allowing algae to start growing.
Check the Ph level, it should be around 7.
Check the chlorine level in the pools water, use your chlorine test kit.
Check the salt levels, make sure it is at the correct concentration, too low a salt level and the Intex will not be able to generate enough chlorine.
Jul 03, 2012 | Intex Automatic Salt Water System for ...
Ph level and clorine level too high
get in the pool companies to adjust the levels to correct and remove the alge growing in the water
Nov 04, 2017 | Intex Automatic Salt Water System for ...
I have an above ground pool 18' round 52" deep. I purchased the intex saltwater system. I have had it run everyday for 8hrs a day and the ph is high and reads no chlorine. What to do?
Salt generating systems cuase pH to rise over time so you generator appears to have been working. What is the salt level in the water? Perhaps your pool is low hence no more chlorine generation.
Aug 27, 2010 | Intex Automatic Salt Water System for ...
Ph level too high in my Intex Saltwater System Pool. How long do I hold the 3-way test strip in the water before reading? I have added the proper amount of ph lower 3 times and it is still high. I hold it...
Have you had a lot of rain?
Rain will make ph go up
too much chlorine can produse Hi ph
Just keep treating with ph down ti'll you reach 7.2-7.8
As for the test strips you only need to dip and pull out
then wait 10 seconds and compare
Jul 17, 2010 | Intex Automatic Salt Water System for ...
Ph level is high
Heather,
leave it alone for a week
If it is still high then get a bottle of ph down.
Make sure you go slow otherwise you might find yourself needing to boost it again.
Jun 21, 2010 | Intex Automatic Salt Water System for ...
Just added an Intex salt water Gernerator to my existing above ground pool. Water is green, can I add chlorine shock to speed up the process. And Ph is low. Can i add PH increaser or should I just wait and...
Yes, you can add chlorine. Liquid chlorine will raise the ph a bit. Don't know what kind of shock you are adding, but wait a day, recheck ph level, than adjust.
Apr 18, 2010 | Intex Automatic Salt Water System for ...
High ph, algea, salty taste
You are going to need to buy chemicals anyway (acid for sure and probably algaecide) so find a good pool store tech and have them test your water and recommend the proper doses.
In summary though, you should not taste the salt in the pool and being able to means the salt content is to high. Chlorine generators will not work if the salt is to high and the fix is to drain water and dilute the remaining water until the salt content is no higher than max. No chlorine could explain the algae.
Generators also cause the pH to rise over time so you will need to keep acid on hand to counteract that.
Jul 05, 2009 | Intex Automatic Salt Water System for ...
Ph level is high cloudy water
Chlorine generator systems gradual increase the water's pH. You'll need to add acid to keep the pH down around 7.4. High pH can lead to cloudy water so get the pH balanced and you should be ok.
Jun 14, 2009 | Intex Automatic Salt Water System for ...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
1,630 people viewed this question
Top Intex Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Ian Summerfield
Ian Summerfield
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
