Question about Gateway (4000811) Motherboard
Power button what is the correct sequince for the power button jumpers to be set on to the motherboard.
  • 1 more comment
  • Andriettef Apr 20, 2008
    where to place jumpers model SIS 661FX7MI
    foxconn
  • Mandeep  Singh
    Mandeep Singh May 11, 2010
    Are you asking where to connect the power button cable on the motherboard ?
    Or
    Do you want to know where to place the jumper on the baord.?
    Do tell the model and make of the motherboard
    President:
  • 2,351 Answers
Hi Andriettef,
I did not find a motherboard with 661FX7MI but I did find these.
1st link. http://www.foxconnchannel.com/EN-US/product/Motherboards/detail_overview.aspx?ID=en-gb0000116
And these. http://www.foxconnchannel.com/EN-US/searcher.aspx?key=661FX7MI
When you find the correct model, post it here. Armed with these links & you find the correct board. Download the manual & you'll be able to set your board up.
Have more questions, feel free to ask.
Mike
Posted on Apr 20, 2008
  • Mike Peluso
    Mike Peluso Apr 21, 2008
    How to vote you're expert & also how to repost more questions for same problem or answer expert's questions.
    Enter FixYa.com site.
    Sign in to your FixYa account.
    Locate My Profile on our FixYa's homepage.
    Under My Problem locate your problem and click on it.
    Under the solution given by the expert, choose.
Need jumper settings for the power button
this will help u...
http://www.mxdatarecovery.net/pics/ms-7525-msi-motherboard-front-panel-power-switch-hd-led-connectors.gif
http://rays-place.net/Extras/PCTechGuide/tutorials/images/MBoard/P2-Power.jpg
Nov 24, 2012 | Computers & Internet
I Need the jumper settings for the fic k8mc51g motherboard from a emachines desktop computer. Putting the motherboard in a custom case.
There is a 4-Pin Speaker connector that is not used by Gateway on the motherboard (right beside) the CMOS jumper settings (Pins).
The clear CMOS settings jumper block is right beside the speaker pins. You can use this jumper block to clear the CMOS RAM, which is powered by the onboard real-time clock button cell battery.
Pin 3 is indicated by the markings on the board.
Settings: Pins 1 and 2 covered = Normal Operation Pins 2 and 3 covered = Clear CMOS enabled.crazyeyes746.jpg
Jun 26, 2011 | Computers & Internet
Ram beep ok but no display
try reseting the bios using the jumper method. you should find a jumper near your cmos battery. turn your computer off, unplug the power cord. The jumper should be in position 12.. set it on ..23. Press power button with power cord still unplugged. Let it stay like this 1 or 2 minutes. Set the jumper back in position 12..., plug the power cord then turn your PC on. If this doesn't work, simply take out the cmos battery and stay with it like 3 minutes. Put it back in place, then turn your pc on.
Jan 15, 2011 | Intel D845GVSR Motherboard
How can I reset password for Bios Phoenix? the problem is that i can't run windows also
Try this, this is called "Backdoor BIOS Passwords" (manufacturers use these passwords for testing and maintenance.)
Reported Phoenix BIOS backdoor passwords include BIOS, CMOS, phoenix, and PHOENIX.
OR
Try removing your CMOS Battery. (Note that all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.)
Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in your system.
OR
Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Power on your machine
-jwma
Jan 06, 2010 | Computers & Internet
Not powering on at all - I have been built a new computer from scratch with all brand new components. After hooking all of them up and plugging in the power source. Nothing is happening when the power...
1. Could be as simple as not having the Power Switch on the right jumper...double check.
2. The board will power up with nothing hooked to it... just power, CPU, MEM... disconect everything to just to get the board up to the bios.
3. Make sure PS is securly connected to the MB.
4. Check Jumper on the Board to make sure the Test Jumpers are not set
5. Memory is seated correctly... if you pull them out the board will start and beep...
Dec 31, 2009 | Gigabyte GA-G41M-ES2L Motherboard
My SB light on my ASUS motherboard comes on when i plug in the power cord. when i turn it on, it show nothing.
make sure the ram, cpu, and graphics card is set correctly, otherwise, remove the battery, put the jumpers on clr cmos, then push the power button, while the power is still the in keep do ing it on and of, the remove the power again posh the on button, to make sure all the left over power streams has left the light should die, the put back the battery the replace the jumpers, then the power cord then try again
Oct 07, 2009 | ASUS P4B533-E (P4B533-E/L/1394)...
Clear BIOS pwd micron gx3 notebook
Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
http://www.dansdata.com/images/io006/cmosclr500.jpg
Or take out the coin battery and replace it after 10 seconds.
http://www.hardwarezone.com/img/data/articles/2003/726/bios-clear-jumper.jpg
Note, all bios settings will be set to default. So be aware of some possible issues you may need to correct in bios after the reset.
Jul 08, 2009 | Computers & Internet
Mobo power
There are jumpers on the motherboard,
check all jumpers are set correctly, as from the user manual, this could be a problem.
check all your front lights are wired properly
power button, reset switch, must be correct too.
double/treble check them before building it.
Richard.
Apr 20, 2009 | Asrock 845GV (P4I45GV) Motherboard
No signal to the monitor
Its actually a configuration problem
1.) ensure that the clock speed jumper is set propperly according to your processor
2.) ensure the the cmos jumper is set correctly
3.) check that all jumper settings are correct accorind to your hardware as described by the manual
4.) make certin that all the power cable / s is in propperly, some boards require the main power cable plus the extra 4 pin yellow x 2 black x 2 to poer the processor,, there should be a place to plug it in on the board itself
if that fails then
1.) unplug the system
2.) remove the cmos battery and the rams
3.) press and hold the power button for 10 seconds then release
4.) replace the memory followed by the cmos battery
if that fails
check that your processor is working..
Jul 15, 2008 | ASUS M2N32-SLI Deluxe/Wireless Edition ATX...
Can not power-on
If you Motherboard was working initialy then there should be no problems once you replace the jumper to the correct (normal) cmos setting, ensure that this is done correctly because this could be you problem. if the jumper is in the correct position and all you other hard ware is functioning correctly and still your motherboard won't power up then check that you memory module(s) are installed correctly as well as that they and the processor chip are all functioning correctly. if you have checked all these and you still have a problem then you will have you replace your motherboard as it could be burnt or damaged.
Jun 05, 2008 | Intel Motherboard
Gateway (4000811) Motherboard Logo
309 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
