Question about Watches
My hugo boss watch clasp will not come undone, how do i fix it!! One of the clasps is stuck and the other isn't!
Noggin
  • 944 Answers
SOURCE: Hugo Boss watch
go to this link and find your nearest Movado Group(they make and repair the watches) service centre; http://a3.geoserve.com/scripts/esrimap.dll?Name=L&Com=fo&Db=DLRMovall&Ds=Movado&Filt=User4%20LIKE%20'_S%25' They can probably answer your question over the phone or e-mail, if not they certainly could if you could get the watch inspected. Most jewellers would also probably know - sometimes the serial number can be marked inside the watch, but I found no information online about your model that discusses this. Hope this helps, hope it's real :)
Posted on Mar 25, 2007
SOURCE: Watch clasp on Tag Heuer
http://www.worldofwatches.com/cust/sizingwatch.asp?d=0
Posted on Dec 26, 2008
landsend
  • 1066 Answers
SOURCE: clasp on rolex president comes unlatched.
there is a little flange on the clasp that can be bent to make it snap tightly.  Most jewelers will do this service for free while you wait.
Posted on Mar 22, 2009
  • 61 Answers
SOURCE: The folding deployment clasp on the bracelet/strap
The newer straps on TAG are generally wider than the professional series and the cost of a new genuine TAG heuer clasp or bracelet may easily exceed the costof buying an entire watch of that series used.
I recommend searching for an after-market strap/ buckle usuing your case back numbers as the search criteria.
Posted on Oct 17, 2009
Testimonial: "Thanks - I'll try that!"
escapement
  • 2338 Answers
SOURCE: need a watch band clasp extender
Click on my profile (escapement), then click on Tips and Tricks. There you will find how to order parts from AK. Rate me, please.
Posted on Mar 18, 2010
How to open clasp on hugo boss yachting timer ii watch
it has a fold out clasp , holding thumb close to the clasp pull the other side upwards this should open the clasp.
Oct 11, 2017 | Hugo Boss Watches
Skagen watch - 233 SGS - the clasp on the stainless steel bracelet is not secure - the clasp comes undone in normal use - nothing energetic - and the watch falls off - been lucky so far as have either...
Hi ,
i would contact Fossil group as they are the manuafcturer of Skagen watches . looking at the model it uses a slider type clasp.
the metal on the locaking part can be easily bent causing to come undone.
Aug 25, 2017 | Skagen Watches
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
Watch strap for tango clasp where it fastens on to the bracelet tubes come off.
this is an easy fix that can be done by a quality watch maker o jewelery repair shop , should cost no more than 10-20 dollars. All you need to do is bring it in and tell them that you need to have the clasp riveted. Its just a pin of sorts that has come undone. Look and see if there is a fast fix in your area they are usually very affordable and do the repair as you wait.
http://www.fastfix.com/
Oct 14, 2010 | Raymond Weil Tango 5560-STP-00328 Wrist...
Unclear as to how you adjust the rubber band strap
  1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
  2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
  3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
The clasp broke from my Fossil watch. Can the
mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
Jul 06, 2010 | Fossil Watches
The spring in the clasp has broken so the watch band will not stay closed. How can I fix this problem?
replace clasp is the best option..if clasp has 2 buttons on it these can be a easy fix but they always break again so i would replace clasp section or even all the bracelet for the watch .you will need model and serial numbers of the watch then try manufacture or ebay or a repairer
Mar 25, 2010 | Watches
I have a silver/gold braided watchband and the clasp keep coming undone. Can I replace the band itself or have the clasp repaired. Marianne Wadle 515-28-50866
Your watch clasp alignment is off , that's make it lose,, most of the time i able to fix it if not then replace with new one, I hope this info helpful
from
Amfix Jewelry & Watch Repair
203 N. LaSalle Street
Chicago, IL 60601
Ph : 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Aug 28, 2009 | Watches
Clasp on rolex president comes unlatched.
Mar 12, 2009 | Rolex Day-Date President 118238 Wristwatch
Lost the clasp for my kenneth cole reaction stainless stell watch
I personally would take it to a jewerly and watch repair shop. If they don't have what it takes to fix it there they can get it. And they work on just about every thing
Dec 16, 2008 | Kenneth Cole 3227 Wrist Watch
Watches Logo
267 people viewed this question
Top Watches Experts
Arturs Kalnins
Arturs Kalnins
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
