Question about Car Audio & Video
Alpine amps...#3552 and #3542. 12v power and grounds connected. Both units have contacts for remote which are not connected. Volt meter shows 12v at the terminals, but does not power-up. I believe that the problem is the remote. Should there be a jumper for the remote terminals? Do you a a wiring instructions?
  • 6,826 Answers
I checked for Alpine.com amps #3552 and #3542 and it was not listed as a current model.
I further, checked for data on the manual and also the parts, and found nothing on their website.
Unfortunately, I would conclude that it is not supported by Alpine anymore.
Is this a new model? or and older model?
Usually remote terminals are used for remote controls, in my experience. If you use a test light to connect the remote, does it change the behavior of the unit?
If not, I do not think a jumper on those terminals will help.
I looked at the following web page and determined what you have is not currently marketed:
http://www.alpine-usa.com/product/category/amplifiers
Posted on Jul 13, 2010
I have a 12" d4 type r 1000 rms and a alpine 1000 amp speaker sounds great but smells like something is burning, my amp never over heats or shuts down but the smell is still coming from the sub?
Cut your gain back on the amp. It sounds like they are set too high. Check your install instructions on how to set your gain. If you have a 4 or 5 volt output head unit your will not be at half way. Im running a JL Audio 500 /1 on a skar wwv10 dvc in a ported box. My gain is set about half way & its plenty loud.I have a Alpine 9887 headunit 5 volt output on my RCAsI can take a volt meter & set my speaker output at 45amps & my gain in perfect.
Apr 28, 2014 | Alpine Type-R SWR-1242D Car Subwoofer
I HAVE A PPI PCX 2200 THAT IS NOT GETTING ANY POWER AT ALL I CHECKED ALL FUSES STILL NO POWER
1.verify connections...Make sure your ground wire is grounded to a location on the body where you will sand the paint away to make good metal to metal contact. 2.with a volt meter check for battery voltage on the red wire of the amp as close to the amp as possible.verify that your remote or trigger wire from the radio (blue wire) id connected to the remote terminal of the amp.. turn on key switch, turn on radio and see if amp powers up. if no then verify 12 vdc at the remote terminal of amp, very 12vdc at red power wire. verify ground. If all this is good i would suspect you have a faulty amp.
May 05, 2011 | PPI PCX-480 Car Audio Amplifier
How can i set up the amp alpine model mrd-m1000
The basic steps to set up a car amplifier are these: 1. Disconnect the car battery's negative terminal before doing ANY electrical work on your vehicle. Failing to do so can damage your equipment or cause injury to your person. 2. Determine where you are going to mount your amplifier. This can be in the trunk, on the back of a seat, under a seat, etc. Pick a place with good airflow, otherwise your amp may overheat while playing. 3. Run the ground wire from the mount location to a ground location. The ground location should be a location where you can securely connect the cable to the vehicle chassis, and the connection should be metal-to-metal, without any paint in between. 4. Run the speaker cables to the amp. This means any cables coming directly from subwoofers as well as RCA cables coming from the head unit. Don't forget the remote wire from the head unit. 5. Run the positive (live) power wire directly from the vehicle battery to the amp. You will most likely have to drill through the vehicle firewall in order to get the cable through. 6. Connect the ground wire to the ground location. 7. Connect the speaker wires and remote wire to the amp. Make sure these cables are connected on each end to the proper inputs. 8. Connect the ground wire to the amp. 9. Insert the fuse into the in-line fuse on the live power cable, within 2 feet (24 inches) of the positive terminal connection.If your cable didn't come with an in-line fuse, you will have to buy a fuse separately, strip the power cable, cut it, and insert the fuse in the specified location. 10. Connect the power wire to the amp first, and then to the battery. 11. Power up your system, and play some music!
Mar 06, 2011 | Alpine MRD-M1000 Car Audio Amplifier
Wont turn on i bought it though craigslist
well this is what you do to check it to see if you bought a blown amp.
wire it into your car and then take a digital volt meter check to see if you have power and ground and remote turn on .
take the red lead and put it on the battery wire at amp and the black lead to the ground then see if you get 12volt to 14.4 use the amps ground for the black test lead if nothing you may have blown fuse or bad ground.
check the remote wire same way as about if you get 12 to 14.4 volt it works if not could be blown from radio or bad ground
checking the ground put the black meter lead on ground wire and the red lead on 12 volt power source if nothing a bad ground.
if your get voltage on the remote wire and battery wire and have good ground then you need to call the seller and get your money back ..
Oct 16, 2010 | Eclipse EA3422 Car Audio Amplifier
NO SOUND OUT OF SUB WOOFERS I AM GETTING POWER TO THE AMP
the easiest thing to do is check the voltage at the amp, between the red power wire and the black it should be the same as the voltage across your battery under the hood. now turn your radio on and c heck the remote turn on wire this wire is at the amp and is usually blue it should have 12 volt when the radio is on and 0 volts whe the radio is turned off check between the blue remote wire and the black ground wire unhook subs from amp and check the resistance across the speaker terminals with a digital mutimeter, if your subs are 4 ohms then your reading on the meter should be around 4, if it is close to 1 or 0, then it's probibly your subs. if everything is good check the fuse on the amp
Jan 07, 2010 | Alpine MRD-M1005 1000 Watt Mono Amplifier...
DEQ 9200 does nothing but blink
check your remote and ground source make sure remote power have enough ampirage for signal source that can cause it to blink
Jun 28, 2009 | Pioneer DEQ-9200 3-Band Car Equalizer
Light doesnt come on
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Let me know if you have any other questions.
Aug 26, 2008 | Alpine MRP-M350 Car Audio Amplifier
Car amp wont turn on
I'll assume that you've checked the amplifier's on-board fuses.
Jul 29, 2008 | Alpine PDX-1.1000 1000W x 1 Car Amplifier...
Wont turn on...
Jun 11, 2008 | Alpine MRP-M850 Car Audio Amplifier
Power problems
You need to confirm that you have 12v DC on the remote turn-on and B+ terminals of the amp.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
Dec 24, 2007 | Pyle PLA2540 Car Audio Amplifier
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
