Question about Microwave Ovens
How do I replace the bulb in my Delongi microwave?
  • Anonymous Jan 28, 2009
    How do I change the bulb on the Jenn '
    Air microwave JMV8208AAS  Does the cover pop off on the inside to replace the bulb
  • Microwave Ovens Master
  • 9,098 Answers
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
Many models use one halogen lamp to illuminate the cooktop and another to illuminate the cavity. You must not touch them with your bare skin as the oils will shorten the bulb life.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 23, 2008
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
How to replace light bulb in microwave model MMV5208WW-1
The support page with free manuals is here.
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=MMV5208WW1&siteCd=WHRCOM&userType=Consumer
The owner's manual says:
Cavity light: The cavity light bulb is located behind the vent
grille at the top front of the microwave oven, under the bulb
cover, and is replaceable. Remove two screws on the vent
grille, tilt the grille forward, and lift it out. Open bulb cover and
replace bulb. Close bulb cover, replace vent grille, and secure
with screws.
Cooktop light: The cooktop light bulb is located on the
underside of the microwave oven, and is replaceable. Remove
bulb cover screw, and open the bulb cover. Replace bulb,
close bulb cover, and secure with screw.
To remove the grille, see my video at microwavecontrol.com.
Sep 28, 2016 | In Microwave Ovens
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Can't figure out how to replace light bulb for model #721.66319
Sears Parts Direct lists the microwave, 72166319500 , as using the lamp, 6912W3B002L. This is available for $6.49 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Microwave-Parts/Model-72166319500/0582/0123245/50026833/00004?blt=06&prst=&shdMod= .
Unplug the microwave and wait a bit before starting to replace the bulb. To change the bulb, you first need to take off the entire cabinet (remove 4 screws on the back of the microwave and lift the part up). Then see the parts diagram on the page given above. There are 2 screws that hold the switch and bulb assembly to the frame of the microwave. I believe you should be able to pull the bulb housing down from the middle of the assembly and then push the unit up after replacing the old bulb with the new bulb. However, the bulb housing may have two screws holding it in place.
I hope this helps.
Nov 25, 2012 | Microwave Ovens
Delongi microwave starting on its own
Sorry to tell you but that sound like you have a short in your touch panel. If you have the skills you might check with the manufacture to see if they sell replacement parts. You could also see if they have a manual online that you could download and look up troubleshooting. This comes up as their offical site. www.shopdelonghi.com/Official_Store
Aug 16, 2012 | Microwave Ovens
HOw do i replace the inside bulb?
Hi. I just told you, there is no acces for the bulb in microwaves. Bulb replacement is not supposed to be a user level maintenance operation. You will need to remove the microwave outer cover to replace the bulb.
Here again my instructions: How do I replace light bulb.
Regards.
Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
I have a Delongi Microwave combi and need to locate the lamp, the model is AC930AMQ, so far I cannot see the lamp anywhere and need to replace it. If it is internal I have no prblem with that as I am an...
I removed the outer case by three posidrive screws and two security screws. The lamp is located in a downward position on the left hand side looking from the back. A normal 25watt 300c ses bulb is suitable so no need to buy original if you don't want to. Take care before removing cover by unplugging the unit and only work on the lamp area as there is high voltage present charged in the capacitors !
Oct 17, 2009 | DeLonghi Microwave Ovens
Need a replacement lightbulb for the Delongi AD1099 Rotisserie Oven and can't locate. It is not a microwave, though.
You can locate the correct bulb that you need at www.repairclinic.com. They have an extensive assortment for all appliances. When you search for your bulb keep in mind to put in the complete model # that is on your unit. Also this site can help you find a different replacement since it shows the type and size of bulb. Go by the wattage rating and what it looks like to fit right in. There are other similar sites and even belonging to Delonghi.com but I believe the repairclinic site is better.
Jan 23, 2009 | Microwave Ovens
Replacing GE Spacemaker Light Bulb inside Microwave Oven...
Here is the GE download page for your manual. Page 35 of your  manual gives the light bulb replacment instructions.
http://genet.geappliances.com/DocSearch/Dispatcher
Dec 30, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Panasonic genius microwave light bulb replacement The bulb on my Microwave model RMC275PD blew and no the microwave won't start, if I replace the bulb will the microwave work again? Thanks Richard
Yes definitely that should be working fine again since it only stop working when the bulb blew,so go ahead and replace the bulb so you can use it again...
Hope that helps.......
Aug 27, 2008 | Whirlpool RMC275PD Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
