Question about Car Audio & Video
Hi I recently got a toyota subwoofer for a 2002 e12 corolla it's made by panosonic/Matsushita model # EAB1689D The problem is i don't have the lead and am wondering if possible to get it or find the wiring diagram to make my own cheers!
5 Suggested Answers
gregstobbe
  • 56 Answers
SOURCE: I want to know electrical diagram toyota corolla 1995 1.6 4AFE
all the wiring diagrams can be found here for free.
http://www.autozone.com/shopping/repairGuide.htm?pageId=0900c1528006f4db
hope you get it solved.
Ps dont forget to rate the solution. Thanks
Posted on Dec 28, 2008
ButtFuzz
  • 463 Answers
SOURCE: i need a wiring diagram for fog lights oem to my toyota
The link below is a Typical fog lamp / driving lamp hookup. Keep in mind that in most states, for these lamps to be 'legal' (and thus pass inspection), you must wire them such that:
1. You can cut them off (in other words, there must be a switch installed to turn them off)
and
2. They may only be operated with the low beams. (therefore, you must power your on/off switch from the low beam circuit)
http://www.accessconnect.com/fog_driving_lights_wiring.htm
Posted on Feb 28, 2009
SOURCE: Toyota 1999 Corolla,low idle,my corolla idles at
adjust the accelerator cable.
Posted on Mar 15, 2010
Testimonial: "i thought the idle was ecu controlled,but i see what your saying,ajust cable stop.ie allen screw with locknut to bring up revs.thanks"
TheAsian
  • 93 Answers
SOURCE: Belt routing diagram for1999 Toyota Corolla
Posted on Jul 02, 2010
  • 239 Answers
SOURCE: i recently bought a 2005
2005 Toyota Corolla Car Stereo Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Power Antenna Wire: Black
Front Speaker Size: n/a
Front Speaker Location: n/a
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Blue
Rear Speaker Size: n/a
Rear Speaker Location: n/a
Left Rear Speaker Wire (+): Black
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
rate pls
Posted on Aug 18, 2010
What is the Toyota conquest 2000 model 1300 tappet settings
https://www.google.com.au/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=2002+toyota+corolla+valve+adjustment https://www.google.com.au/webhp?sourceid=chrome-instant&ion=1&espv=2&ie=UTF-8#q=2002+toyota+corolla+valve+adjustment PL3Z1Y
Dec 20, 2016 | Toyota Cars & Trucks
Replace dome light bulbs toyota corolla 2002
Your owner's manual should have a page listing lamp numbers and applications. You can also visit an auto parts store and find out what you need
Jul 15, 2013 | Toyota Corolla Cars & Trucks
Dashboard light out were is the fuse box in 2002 corolla
All fuse box locations and fuse ID information is in the owner's manual. If you don't have one go here and download one from the Toyota site.
Nov 08, 2012 | Cars & Trucks
What is the model no?
The most comprehensive list that I have found on the model NUMBERS of the Toyota Corolla is on Wikipedia. Your 2007 is likely an E140 or E150 which had just changed from the E120 style of 2002. But go to the site and look at the pictures to verify.
It's a great car... I drove one for years! Awesome design. Just bought another Toyota... the Matrix 5 speed. It is a LOT of fun.
I hope this helps....
/denis
Dec 10, 2010 | 2007 Toyota Corolla
What tire sizes will fit toyota corolla 2002 ce
Usually a toyota corolla has 195/65R15 tires if it has 15 inch wheels. Some of the sport models have 16 inch wheels. Those sizes are 205/55R16. If you have any concerns all manufactures will post the Original Equipment sizes on the inside of the drivers side door jam.
Nov 16, 2010 | 2002 Toyota Corolla
Cabin Air Filter 2002 Corolla
Toyota initiated cabin air filters in Corollas starting in 2003.
Jan 03, 2009 | 2001 Toyota Corolla
Toyota corolla 1998 gasoline owner manual
go to ebay, I got mine from there. good luck!
Nov 13, 2008 | 1998 Toyota Corolla
Car Audio & Video Logo
57 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
