MY GE Profile side by side GSH25SGPCSS stopped dispensing ice and water. Nothing on the dispenser works or lights up. Neither of the LED temp displays light. The compressor run continuously and it gets very cold and all of the lights inside work. I tried replacing the Main PCB and still have the same problem. Any suggestions
WR55X10942 Main Control Board WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty . http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
This could be as simple as the door switch or as complex as the dispenser control board. I would try the door switch first. When the door is close it turns on the dispenser controls. If the contact is defective in the door/light switch then this happens. Unplug remove the door switch and mark wire locations. 1 Powers the lights and the other powers the dispenser. and one is the power itself. Sea Breeze
Could be the connector at the bottom of the freezer door corroded but it could also be the main PCB failing as the low voltage power supply may be dropping out . By the 'light inside' do you mean in the dispenser or inside the fridge ??
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
So your not getting water from the dispenser either??? Yes the water filter can be the source of your problem. Let me know if the water is coming from the dispenser.
