Problem with Intel Motherboard
searching the drivers
How can i update my motherboard drivers for gigabyte. thank you.
Posted by avatar on Apr 20, 2008
    • By avatarGuest May 02, 2008
    • I HAve need Drivers of Intel D845 GREG
    • By avatarGuest Apr 20, 2008
    • When I run Google Earth it tells me that I need to up date my Graphics card drivers. The Graphic card is an onboard system on the mother board.
      On the mother board is the following : Prescott 800 ATA 133 DDR 400
      What do I do to up grade the required driver so that Google Earth can focus at says eye level 1.5kms or lower. It currently does runs in emulation mode because of this required upgrade not being downloaded.
      Please reply to Norman
      E-mail : gng@yebo.co.za
Solutions (4)
Best Solution
hi i am sameer,
I have asus p5vdc-mx mother board . i have not video controller driver, please help me for this roblem.
  • By Author imageGuest May 09, 2008
khaef,
I need the model number of your Gigabyte motherboard to find your drivers. Look on the board for typed white lettering. Or look for a white sticker located on the sides of your (White) PCI slots. The model number will be similar to these Examples.
(GA-8IG1000MF, GA-8IPE1000MK, and GA-8ITXR) ECT....
Your board s model number will start with the lettters,
GA- ?????? When you find it list it here & we'll go from there.
Mike
Guest,
You need to list the name & model of your video card in order to upgrade it's software. To do this, right click once one an emty spot on your drsktop. Than left click properties. This will open up your display properties. Click the settings tab, than click the Advanced button. Than click the Adapter tab. Under "Adapter Type", post that information & the "Adapter Information" here at FixYa in your post. This includes (Chip Type, Memory Size & Adapter String). Than I'll be able to guide you to the correct site for a software upgrade.
Mike
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
54
  • By Author imagesdgdfh Mar 13, 2009
I don't have motherboard driver CD, Now I Need drivers from net Model No:Intel E210882 Reply at:gopanint@gmail.com With regards Gopakumar KS
Yousuf Machines & Structurals LLC
PO Box No. 37012
Dubai, U.A.E.
Tel . No.04 3417044, Fax No. 04 3417045
Suggested Solution (2)
Fiend your solution direct from Gigabyte. Here is your solution.....
830
  • by Author image masum114 Over a year ago
Source: motherboard driver link in gigabyte 945GCM3 rev 1.0
Was this solution helpful?
No
Yes
How can i update my motherboard VGA drivers online...?
thank you.
rumy.
  • by Author image mmrumy Over a year ago
Source: searching the drivers
No
Yes
Add Your Solution
See all Intel Motherboard Problems
