Question about Whirlpool Duet GHW9150P Front Load Washer
Fault code f-33 on a whirlpool duet.
My duet sport washer is flashing a f-33 fault code and won't start.
  • Anonymous Mar 23, 2014
    f-33 error code
  • 10,515 Answers
The F33 code is a pump failure code. The control unit is not measuring the proper amp draw on the pump during pump out. Remove lower panel and unplug then replug in the pump 2 or 3 times to remove any corrosion. While your down there, take the front of the pump off to check for any blockages.BE SURE TO UNPLUG YOUR WASHER WHILE SERVICING!
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 13, 2010
  • archangel587
    archangel587 Aug 05, 2012
    Dude. Lifesaver. Worked first try. Thanks!
It starts and then stops and then F28 flashes
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3708-whirlpool-washing-machine-fault-codes.html
Not good! Probably motor control board or motor or wiring harness from control board to motor.
This leads to a Kenmore Video
Whirlpool, Maytag, Kenmore. Same machine different name different trim.
Whirlpool Duet f28 YouTube
Sep 21, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet wfw9640xw00 won't turn on
my whirlpool aquasetam washer get fault code f23?
Apr 01, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Model WFW8300SW0 basket won't
The following list of codes indicates an electronics communication problem with the washer: - Duet HT washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
I would first replace the door latch/lock assembly, a number of users have and it fixed the F-11 error code completely. Its the cheapest part for this problem.
Hope helps.
Jun 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
I tried to start a load and an F-1 code flashes. I have a Duet Sport front load washer (2 years old).
Go to the Whirlpool webside and download a manual for free. They are good folks.
Here is mine...
https://secured.whirlpool.com/Service/.../Duet%20Job%20Aid.pdf
G.
Apr 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F-33
Hello there
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Possible Causes / Procedure
1. Check for crack or holes in the washer tub and pressure switch hose.
2. Replace components if necessary.
Dec 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer code f 33? What does it mean?
the fault code indicates that your main data cable from the controller to the motor has miss-comunicated: unplug the washer wait about 30 minutes then plug it back in and, let me know if the code clears
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet Sport Washer fault code F-28
f-28 code is a serial communication error between the central control unit-ccu- and the motor control unit-mcu-. depending on the age under one year the unit should be under warranty, if so call a service man that care of the problem in warranty. if the unit is over one old you can remove the top and check all connections between the ccu and mcu.
Jan 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet sport front load washer
the panel below the door has 3 screws under the bottom lip of the panel. remove the screws to get the panel off youll see the pump right in front of you. you can unscrew the cap on the pump and remove it to clean out the punp. thats where 99% of clogges are on that washer
Nov 25, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
762 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
