Question about RCA D52W19 52" Rear Projection Television
Tv wont come on power button lights up then makes a high pitched beeping and gose off then makes the same beep and comes back on and dose thise like 3 times then wont do any thing
  • RCA Master
  • 8,617 Answers
The deflection board needs replacement. You can get the deflection board from www.tvrepairworld.com
Posted on Jul 14, 2010
M2n68-la beep codes
Whenever electronics devices give high pitched beep, it generall means a future failure . There could be reasons for the same.
1. Static built up on the motherboard
2. Conflict on the USB ports.
Troubleshooting 1 :
1. Diconnect all the wires from the tower, including the power cable. Press and hold the power button in the front to remove any static from the motherboard.
2. Check and try again the devices on the USB port.
Troubleshooting 2:
1. Check USB ports for damage , try connect the device to the back of the tower.
Troubleshooting 3
Clear the motherboard setting , use the link attached and see clearing the BIOS settings
Thanks for using fixya
Proton
Jul 07, 2012 | Computers & Internet
Tv wont stop beeping every time i turn it on. It is a very high pitch beeping that doesn't stop. I have tried plugging the tv in several different plugs by itself but the beeping still didn't stop.
Ur High Voltage is dead.The FBT the flyback transformer is dead.The big block of plastic with a red wire with a cap hook to a CRT(tv tube).Replaced the FBT get power back.
Jan 19, 2010 | Televison & Video
Ps3 wont read discs.................
Try to restore file system on your ps3.
Follow this guide.
HOW TO GO TO THE RECOVERY MENU OF PS3 SYSTEM
1. Make sure the ps3 is plugged in (stand by mode).
2. Put out your usb cable for the controller and the controller itself (do not connect yet).
3. Hold down power firmly, ps3 will turn on and then turn off, release power button when t turns off.
4. Hold down power again, you will hear a beep and then a double beep, when you hear that double beep release the power button.
5. Now you should be seeing something in your monitor that say "Connect usb controller", do just that.
6. After connecting the controller press PS button.
7. You are now in the recovery menu.
8. To fix the problem of corrupt data you can choose #3.
9. If you want to format your hard drive choose #5. Be aware that this option will delete everything that is in your hard drive.
10. Remember that doing #3 and #5 is not 100% to fix the problem of corrupt data, I say about 70%.
Jan 17, 2010 | Sony Playstation 3 (PS3) Console
All three lights turn on like normal and then nothing
Depending on the pitch. humming noises are either a motor ie: fan motor or if it is very low a defective capacitor . Since you have the yellow band and the high pitched beep my fist thought is somthing defective in the power supply. Take it to an authorized servicer.
Apr 07, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Laptop wont tart
I would like you do reseat (take out and reinstall) the following:
Memory Battery
Next I would like you to verify that the powercord is still working, when you plug the cord into the laptop it should light up on your laptop, and there may also be a power indicator on the powerpack itself.
After you have done the following please post back here and let me know your findings
P.s. Note any beeps and sequence when/if they do.
Jan 19, 2009 | Toshiba Satellite M60 Notebook
TV WENT OFF WILL NOT COME BACK ON
All you need to do is look in the manuel and if it has that as a trouble shooting thing follow steps, if it says nothing locate the tv reset button and hold it if you can't find it conslut the dealer. Hope this helps
Nov 26, 2008 | Pioneer SD-643HD5 64" Rear Projection...
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
TV making high pitch sound
Hi, There are usually 1 or 2 fans inside the TV's. Could be worn bearings, or fan blade interference. Sorry, without my electric ear working, I can only guess.
Apr 21, 2008 | RCA HD52W56 52" Rear Projection HDTV
My TV shut off and will not come on
This is an issue with one of your power supplys wether it be high voltage horizontal power supply or the reg power supply. The beeping noise is letting you know that it has some power but not enough to start the high voltage needed to create the picture on your tube. I would seek professional help for this issue.
Nov 03, 2007 | RCA F36668 36" TV
RCA D52W19 52" Rear Projection Television Logo
400 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
