Question about Hayward SAND FILTER, PRO SERIES
How to change sand in a s244s sand filter - Hayward SAND FILTER, PRO SERIES
  • 52 Answers
It is simple and take about 1 1/2 hours . Turn off system off and close valve on the top to closed position. Remove clamp at the bottom of the valve that holds the tank and valve together. Remove the Valve by lifting
up the valve off the sand tank. You will need a device called a "Sand Changer" which is a device that syphons out the sand via a water hose and a discharge hose. This device is a life saver. Duck tape a 1 1/2" pvc pipe the length of about the height of the tank plus 6" so you can press the sand changer with the hose wide open down into the sand. "do not empty water in the filter as this aids in the syphoning process. then connect the hose provided in the sand change box to the sand changer device. this will be the discharge hose. You are ready to start the syphoning process. It may take a minute to get the syphon but it will syphon depending on the condition of the sand.after discharging most of the sand you will need to remove the the center pipe that has a hub with Latterals at the bottom. the latterals typically unscrew for the hub. These tubes act as the Pressure burst that cleans The sand when in Backwash mode. Remove the latterals by un screwing them from the hub. Once tank is clean reintroduce the hub pipe and latterals into the tank. Ad proper amounts of sand. The amout of media can be found on the side of tank on the sticker. consult owners manuel or if you have the make and model consult manufacturer. once proper amount of sand is back in tank. Typically sand tanks or 300# media or 600# media. Ps when introducing sand into tank cover open pipe at the top of the hub so sand does not enter pipe or sand will return to pool. fill with water and reassemble valve. and Backwash sand till dust in the eye glass is clear. then Rinse. Return to filer and your done.
The Pool Tech
Posted on Jul 14, 2010
  • 11 Answers
Unhook the plumbing from the multiport valve, hopefully you have unions, it would make it easier. Take off the multiport valve on top by removing the bracket, usually held on by two phillips held screws that go into corresponding nuts. After bracket is removed, carefully wiggle the valve straight up, Don't wiggle it side to side, the PVC shaft in the is like Schedule 20 and breaks really easily. After valve is off do not try and pull the shaft up, there is too much sand waying it down and you will break it. Remove the sand with a cup or pop bottle cut in half or whatever. It is a pain to keep scooping it out with the shaft in your way, but I emphasize the strongly, do not try to move the shaft out of you way or pull it out without getting enough sand out of there. The other way to get the sand out, a little easier, is use a shop vac. You have to do it slow and kinda jiggle the hose while sucking sand because it'll clog the hose up. Get all the sand out, pull the shaft and lateral assembly out. The newer laterals fold up kinda like an umbrella so you can remove it, the older ones you have to unscrew each later individually to remove it. Inspect the shaft and laterals thoroughly to make sure none of them are cracked or not seating properly. Spray everything off, reinstall the lateral assembly, center it in the filter as best you can, most of them don't lock into anything, they just kinda sit there. Put duck tape or something over the top of the shaft so no sand gets in it. Pour about 50lbs. of sand in, (usually 1 bag), and recheck the shaft to make sure it is centered. An S244 requires 300 lbs. but just double check the label on your filter. Pour it all in, take the duct tape off of the top of the shaft, slide the valve back on, lubricate the gasket on it first, retighten the valve via the bracket you took off. Hook the plumbing back up and you are good to go. Backwash it right off the bat for a couple minutes before putting it on filter. You can potentially blow dust into the pool if you don't
3 Suggested Answers
jandjsay
  • 25 Answers
SOURCE: Why does my hayward pro series s244s blow out sand
This indicates that one or more of the laterals are cracked or broken. You will need to open the tank, remove all the sand, inspect the laterals(tubes that come off the center 'stand pipe'). replace any that have cracks or are broken. If you can't tell, replace them all. Fill tank back up with the right amount of sand and close it all back up.
www.cpo2go.com
Posted on Dec 03, 2010
adamh294
  • 310 Answers
SOURCE: model # s244s has dirty
This is a serious issue. These vessels are only pressure rated to 50 PSI. Anything more can be an explosion hazard.SHUT DOWN THIS SYSTEM!
You need to remove all the sand and replace it. While your inside, you must clean the LATERALs. (small tubes on bottom of the filter)
This will reduce the pressure.
It is a good idea to replace the laterals in the bottom of this filter if it is in your budget to do so. The pvc laterals become brittle and often break when tampered with .
Note: only use #20 silica pool filter sand as a replacement.
Posted on May 09, 2011
How much sand do you add to a Hayward Sand filter S-21OT
200 pounds of sand make sure you use pool filter sand make sure not to get sand in pipe
Jun 27, 2014 | Hayward SAND FILTER, PRO SERIES
I just had a new Hayward s244s sand filter put in and now am having problems draining water from my pool. For some reason I can't get it to drain past the skimmer level. Suggestions?
What are you using to drain the pool? A sand pool filter is not the best option for draining. You need a submersible pump for that. Why are you draining the pool? The filter should be used to filter water, not drain. It is possible, but not efficient.
May 21, 2011 | Hayward SAND FILTER, PRO SERIES
Model # s244s has dirty sand and vacuum pressure is not good. Sand is dirty . Pressure valve has pressure of 50 psi
May 08, 2011 | Hayward SAND FILTER, PRO SERIES
How to change a lateral in an s244s hayward sand filter
You will have to remove the sand so you might as well buy new sand. Remove drain cap and allow to drain. Remove multi port valve from top of filter. This model should have a clamp holding the valve onto the filter. You will have to disconnect the piping from valve for removal, so if it's piped solid, cut piping, and buy PVC unions to glue back in place so you can open in the future. If it's hose, then no problem. OK so once you remove the valve, you can see inside and see the sand. Take a shop vacuum and vacuum the sand from the filter. Take your time and empty vac, before it gets too heavy. Once empty, you'll see the laterals in the bottom. They if you rinse them off with a hose, to remove sand to keep from binding. The laterals should fold up to the center. Once folded you can remove assembly. After installing new laterals, partially fill the filter with water before adding sand. Cover the down pipe so no sand can enter. Add sand gently so you don't break new laterals (water helps cushion the adding of sand) You can download a manual here :
http://www.haywardnet.com/products/Manuals/pdfs/Manual145.pdf
Jun 25, 2010 | Hayward SAND FILTER, PRO SERIES
Why does my hayward pro series s244s blow out sand when the filter is put on, and has little to no pressure?
www.cpo2go.com
Jul 08, 2010 | Hayward SAND FILTER, PRO SERIES
Pentair sm2-pp3 valve, triton II filter. Upon
Lots of sand? You may have a broken lateral in your filter.
To repair, you will have to remove all the sand from the tank to physically inspect.
Might you have changed the sand this year? (top 1/3 needed to be changed every 3 to 5 years normally) If you changed the sand ... did you put water in the filter tank first? If not ... there is a good possibility you broke a lateral (a small pipe with slits in it) when you put the sand into the filter.
It could be that you have too much sand in the filter. Check the owners manual for the clearance - top of sand to top of filter.
Thanks for your interest in FixYa.com
May 14, 2010 | Pool & Spa
Sand filter is a week old,has been back wash twice but still having trouble,with kpa over 100
This can be a few different problems I will list them out for you:
  1. Make sure you are following the instructions in your Hayward owner’s manual. The sand bed may be clogged with mineral deposits or other material that will not backwash away. Some calcium based chlorines and other alternative sanitizers could cause a build-up in your sand bed. You may need to change the sand.
  2. Before you change the sand in you filter, try removing approximately 1” of the top layer of sand, and replace with the exact amount of sand removed. This sometimes rids the sand bed of the deposits clogging the filter.
  3. You may have to clean you filter system with a special filter cleaner, check with your Authorized Hayward dealer for proper procedures.
  4. Check to see if there is a closed or partially closed valve on the return piping.
  5. Your pump may be too small to provide sufficient flow for proper backwashing. Your filter will filter properly, but if your pump does not supply at least 60% of the filter’s designed flow rate, you filter will never backwash completely. Refer to the label on you filter for flow rate requirements. It may be necessary to upgrade the pump or downgrade the filter.
Your pump may also be exceeding the maximum allowed flow rate of you filter causing excessive backpressure. Check you Hayward filter owners guide or the operations label on you filter for the maximum allowed flow rate. You may have to downsize the impeller or pump to a lower horsepower or change the filter for one that will accommodate the pump’s flow rate. If allowed to continue, a pump that exceeds the recommended flow rate of a sand filter could cause the sand bed to channel (small channels in the sand that allow debris to pass unfiltered). This would cause debris to by-pass the filter.
Hope this helps you
Jan 02, 2010 | Hayward SAND FILTER, PRO SERIES
Replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Apr 27, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward SAND FILTER, PRO SERIES Logo
1,442 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
