KONICA 8031 DISPLAYS ERROR CODE D1.0A4A DEVICE FAILURE
  • RTAZ Jul 14, 2010
    THANK YOU NICE TO HAVE AN EXPERT FOR MY LEFT HAND!
    President:
  • 1,561 Answers
I advice you follow the below procedure,
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Take care.
Posted on Jul 13, 2010
Konica minolta 8031 occurring error code c-3c30 when the machine is ready to copy & i try to press copybutton.some body please help me
Sir/Mam,
You hit a serious code, noting can be done, this code requires a tech to come out and remove a chip inside the machine, which is then sent to Konica Minolta, then on to the US SECRET SERVICE since someone attempted to counter fit US currency!!!!!!!!!!!, until the US Secret Service determines what was done the machine stays inoperative , once what happen is determined tech will come out reinstall the chip reload firmware, and .NEVER EVER PLACE ANY CURRENCY ON A COPIER all the machine now a day have Bank Note chips.
Aug 13, 2016 | Konica Minolta Bizhub 8031 Copier
What does error code C-0510 mean?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 08, 2014 | Konica Minolta Bizhub 8031 Copier
I cant install it to my computer
Have you accessed the Konica/Minolta web-site, and downloaded the device-drivers specific for your printer and for your operating system (Mac OS? Windows 7?). Did you connect it, and try to use 'Windows Update' to find the correct device-driver?
Mar 07, 2014 | Konica Minolta Bizhub 8031 Copier...
Konica minolta 8031
same issue never found solution... Konica rep came out and said he didn't know what it is then told me to lease a new machine... lol
c-3c30 = Designed Obsolescence
May 09, 2013 | Konica Minolta Bizhub 8031 Copier
Konica 8031, error message C-3C60, What is it?
Image control board failure or the firmware for the copier crashed.
Dec 12, 2010 | Konica Office Equipment & Supplies
I have an error code on my Konica Minolta 8031... C-0F30... any ideas on how to fix?
it is a sensor problem, try a hard reset on it but making sure all is plugged in and on then unplugging it from the back. That usually solves the issue unless the sensor is actually gone then it is a cheap part but expensive to replace.
Sep 14, 2010 | Konica Minolta Office Equipment & Supplies
Our Konica 8031 Printer has given us a code of C 1265, and will not print. Could you please let me what this error means, and also what needs to be done to fix it... Thank You.
This seems to be related to an internal hardware problem. Try reseating the memory DIMMS and other visible internal connectors and try again.
This most likely requires service from a qualified technician.
Good Luck!
Feb 05, 2010 | Konica Minolta Office Equipment & Supplies
Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
Sep 13, 2009 | Konica Minolta Office Equipment & Supplies
Konica 8031 Malfunction Code C-0990
http://www.pressa.net/info/?id=34
This page says, that this code is displayed on "Main tray up problem".
I suppose they didn't change the codes that much, so its possible that you can work with this one...
Apr 02, 2008 | Konica Office Equipment & Supplies
276 people viewed this question
jasbo
jasbo
