Question about Black & Decker Black Decker 18" Lawnhog Electric Mulching Mower
Motor stops working, it jerkes but doesn't move when I start it
I had the connected long power cable with 18" mower and then when I started mower, it tripped the main switch. After restoring it, my mower motor doesn't start. there is a little **** but it doesn't rotate at all when I pull start handle. I tried rotating blade manually but it seems too tight...any suggetions ? is my motor dead ?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
It sounds and i think you know it It sounds dead
Posted on Jul 26, 2010
Why does mower jerk when I push levers forward to move?
Model?
Does it start to move then stop...
Oct 17, 2015 | Cub Cadet Garden
Brand new Troy-Bilt XP Horse, model 13bx79kt011 - Won't Move
Confirm the park brake is off. If a hydro-static drive tractor starts but engagement of the operator controls for the transmission drive results in neither a forward or reverse drive of the mower itself, the operator should check that the manual bypass controls have not been left in the activated (bypass) position.
Look in to where the lever connects and confirm the movement. You should be able to hear the hydraulic oil with a slight whine as you activate the drive forward pedal!
See page 18 for bypass setting?
Cut and paste link
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/riders/HorseXP_2012_769-07569[1].pdf
Jun 27, 2017 | Garden
Looking for a manual ..i tried www.managemyhome ,,butthey did not have my model #944607042 thanks
How long has it been since the device? Maybe the engine is "frozen". Put it in the highest gear and take the brake off. Then try to move the mower or whatever it is by hand. If you can get the vehicle to move, then try starting it. If that doesn't work, then you need to see if you're getting power from the battery to the starter motor. Check the starter relay if it has one, and check all connections from the battery and to the starter motor to make sure they are tight and clean.
Sep 19, 2012 | Craftsman Garden
We have a brand new toro 22 in Recycler lawn mower that we have used 2x and today it stopped working. We are unable to pull the start cord more than 2 inches out so obviously we cant start it. Help.
Check the oil ... does it have oil in it?
Disconnect the spark plug, tip the mower up, can you move the blade? If the blade will not move, the motor may be seized.
No oil = ruined motor ...
If the blade will move freely, there is a recoil starter problem.
Thanks for your interest in FixYa.com
May 15, 2010 | Toro Lawn Mower With Toro Power Tools
Stopped. Black and Decker Lawn Hog 18-Inch Electric Lawn mowe
you could check the brush connection on the motor or your switch mat not be making contact
Mar 28, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
I CANNOT START MY MOWER. iT FEELS LIKE SOMETHING
I bet it got over heated and shut off? That happems often to me when the grass is to long and wet!! When it cools down it will start again right?
Aug 13, 2009 | Toro Lawn Mower With Toro Power Tools
Poulan Pro riding mower jerks in forward and the blades engaged
This is a lawn mower catagorized as a chainsaw. We don't answer lawn mower questions ands you don't cut down trees.
Mar 23, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My lawn mower doesn't start -all wires and cords are ok - and then sometimes it starts itself and when i move it it stops again. it was working perfectly fine one day and then the next....its gone it's a...
sometimes you get an internal break of the electric feed cable which shorts out with movement and gives problem that you are having , another fault with them is that the switch has a safety machanism in it which can cut power for up to twenty minutes before it will reset which is done by operating lever as you would normally ,occurs a lot with m/cs used with adittional extension cables,hope this helps
Mar 23, 2009 | Electric Lawn Mower
18" mower suddenly stopped working
motor problem.if you hit something stone our water springler may be the motor magnetic ring broke & jam the armature & not
to start & house pop. see toolpartsdirect.com looks for the model of the mower. black & decker
Feb 08, 2008 | Black & Decker 19" Electric Lawnhog...
Black & Decker Black Decker 18" Lawnhog Electric Mulching Mower Logo
219 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
