Question about Canon PIXMA MP810 All-In-One InkJet Printer
It just won't scan. It prints fine and it photocopies fine but if I go on to scan and choose any of the scanning options it says "Place document on platen glass and press ()" (i tried to draw the button there) But if i press either the colour OR b/w version of that button it doesnt react at all even though those buttons work fine for photocopying. Help?!
Hey Yasmin,
I had the same problem.
I installed the MP Navigator (MP Navigator Ver. 3.03 (Windows 7/7 x64/Vista/Vista64/XP/XP x64/2000/Me/98) from the canon website (http://support-au.canon.com.au/contents/AU/EN/0900173112.html) and then I released the scannerlock (http://www.fixya.com/support/t5363070-trace_release_scanner_lock)
and then I could scan! Not only through the printer itself by pressing the (<I>) button but also through the MP Navigator program. When I pressed the (<I>) button on the printer, the scanned document would be automatically saved on the computer in a folder of MP Navigator.
Hope this helps you!
Esther
Posted on Aug 11, 2010
  • BlackEnginee Jan 04, 2011
    You can find solution in vincenzomazzotta.blogspot.com or traslated by google traslate service in english inhttp://translate.google.it/translate?hl=...
  • rowsy Sep 16, 2011
    I had the same problem, and this fix worked.
    I could copy but not scan.
    Scanning doesn't work on my PC with MP Navigator ex1.2, going back to ano older version fixed the problem!
When I am photocopying and scanning documents I am noticing vertical lines on the print in the middle of the page which is ruining the copy, any ideas? Alos message intermittently coming up waste toner...
Most probably you are using the automating document feeder for the photocopy or scanning. If you can lift up the document feeder , there should be the mirror where you can put the original document for manual photocopy or scan. Clean the edges of the mirror with a printer cleaning liquid. There may be some foreign particle stuck there or it is just dirty from long use. Hope this helps.
Sep 02, 2011 | Office Equipment & Supplies
I have a canon MG5220 printer and unable to scan properly the messages I receive are saying Scanner turned off, disconnected from LAN, code 2,145,50. Printing pictures and all other printing jobs work...
Regarding the Cannon scanner error 2145,50. I note you have tried to fix this, but failed. The actual problem is that the scanner will not communicate with the computer correctly if it is connected through a USB hub. A direct connection to the computer cures it.
I know, I had that problem. I am a retired elctronics design engineer.
Mar 07, 2011 | Canon Pixma MG5220 InkJet Printer
My Dell V105 printer won't scan a document onto my Dell laptop. It will scan and print but won't scan and send the document to my laptop.
Hi
I have not familiar with the printer but I have alternative for your problem. I suggest you install Acrobat reader 9 that if have a friend that you can borrow.
From that program, you can scan a document and save it as pdf file. Just go to the document menu and there is a scan to pdf option there. Choose which one you preferred like print in black and white.
Mar 04, 2011 | Computers & Internet
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, paint.net etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
My HP J5780 will not scan.
you document was place in a different direction, try to place the document in the right place and scan again.
hope this helps
Aug 06, 2009 | HP Officejet J5780 All-In-One InkJet...
Seems to do everything but scan to computer it will scan and print a photo but when I try to scan to computer it prompts, "place document on planten glass" well the document is on the planted glass but it...
Click Start, choose printers and faxes, choose scanners and cameras, right click WIA Canon MP970, click properties, choose events tab, choose select an event, scroll to "attach to email".
Jul 26, 2009 | Canon MP970 Photo All-In-One InkJet...
Can i use my DCP 130C machine for photocopying? for small business. meaning iwill frequently use my machine for photocopying. would it be okey?What could be a posible problem in the future if there's any
You may use this a copier but usually, all in one printers used as copier take a long time to produce print outs. It isn't as robust as It usually scans the pages first (duration is the same as scanning a document) then prints it out (duration is the same as printing a document from a PC).
In my experience with our multifunction printer, a single page can be photocopied in about 45 seconds to 1 minute. It isn't as robust as photocopying machines.
Jun 25, 2009 | Brother DCP 130C All-In-One InkJet Printer
Won't recognize legal size paper
I have a Brother MFC-8840Dn (full legal-size flatbed as well as document feeder). I use Windows XP Pro and a USB connection. I'm not sure my fix works with other Brother models or different Windows operating systems, but it's a way to start troubleshooting at least.
I've always been able to print legal-sized pages from word processing or spreadsheet programs and receive legal-sized faxes. But I never could make legal-sized photocopies or PDF scans. The image was always cut off at Letter size. The fix is a Brother Utility set-up setting:
*** Go to Start / All Programs / Brother / MFL-Pro Suite MFC 8840Dn / Scanner Utility. (This link may also be called something like Scanner Settings.)
*** At the "Maximum Scanning Size", select "Legal" instead of "Letter/A4".
*** Click OK and restart your PC for the new setting to take effect.
It's like magic -- I can now scan a full legal-sized PDF, whether on the flatbed or through the ADF. I also tried a compressed TIFF scan and it came out fine.
**** Make sure your software and/or Brother Control Center scanning configurations are set to Legal if that's what you want for the particular image scan. The Brother Utility setting simply enables the option of choosing the larger legal-sized paper, which then allows the full legal-sized image scan, You always have to set your software to make that choice, just as you would to make and print smaller images on Letter, A4, envelopes, etc. (NOTE: I always start scans through software on my PC, like Adobe Acrobat or PaperPort, and the Utility Setting fix is working fine. However, I just tried pressing the SCAN button on the front panel of the MFC itself with a legal-sized document on the flatbed and through the document feeder. I still got Letter-sized image scans. So, there must be another setting somewhere for starting scans directly from the MFC that I'll locate later.)
I was about to buy a different brand of scanner because of the frustration with legal-sized images. It's like having a new scanner now :) I hope this Utility Setting info helps you troubleshoot your legal-sized image problem.
Sep 04, 2008 | Brother MFC 9600 All-In-One Laser Printer
Can't Scan documents
on the scan options , "select "scan to pdf", it will scan as a document instead of printing.
May 06, 2008 | HP Photosmart C6180 All-In-One InkJet...
Canon PIXMA  MP810 All-In-One InkJet Printer Logo
397 people viewed this question
old marine
old marine
