Question about iRobot Roomba 560 Robotic Vacuum
Goes in circles, will not go straight.
Worked well for about a year. Suddenly, it goes in circles, will not go straight. I've done what tech support said but it didn't help. Suggestions?
Roomba just turns in circles what could be wrong
What to do when the Roomba just goes in circles ' All about Roomba ...
https://roombafan.wordpress.com/2015/05/17/roomba-just-goes-in-circles/
May 17, 2015 - Single beep - Roomba is stuck or wheel is hanging down; you need to move your Rhoomba to a new location or check the wheels. Two beeps - this happens when the main brushes become immovable, so you need to check the brushes. Six beeps - the likely cause is a dirty cliff sensor or the robot is stuck on a cliff.
Roomba is backing up and circling. - Find Answers ' iRobot Customer ...
https://homesupport.irobot.com/app/answers/.../roomba-is-backing-up-and-circling. If Roomba backs up or spins in circles, run Roomba in an open area with no obstacles present for 2 minutes to determine if the robot will stop with an error ...
SOLVED: The Roomba just goes in circles, how do I fix this ...
https://www.ifixit.com/.../The+Roomba+just+goes+in+circles%2C+how+do+I+fix+this Oct 23, 2016 - Dirt and debris can cover the sensors and make the roomba believe it is ... When my Roomba turns on, it will only spin around in circles and ... Won't go straight; not circle of *****
May 30, 2016
Vacuum will not go straight
May 7, 2013
SOLVED: roomba 560 got wet and now it doesnt go forward ...
May 15, 2012
SOLVED: When I turn my Roomba on, it doesn't go forward ...
Apr. 25, 2011
More results from www.ifixit.com
iRobot Roomba circle dance - "fix" - YouTube
? 5:37
https://www.youtube.com/watch?v=sN03AWr1VAk Jan 21, 2008 - Uploaded by Scubaholic
Didn't feel like open my roomba at 10pm, so I just sprayed it with some canned air around the wheels and ...
Help! My Roomba goes in circles! - Robotic Vacs
https://robotic-vacs.com/2016/03/03/help-my-roomba-goes-in-circles/ Mar 3, 2016 - What to do if your Roomba just goes in circles. Roomba goes in circles. No, your Roomba doesn't have a mind of it's own, nor is it tipsy from ...
May 20, 2018 | Roomba Vacuums
Just goes in circles, will hit something back up but then just go in the same direction of circle
Your bump sensors are malfunctioning. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great. I'd recommend them..
Aug 07, 2011 | iRobot Roomba 560 Robotic Vacuum
Goes around in circles. wheels look fine
Your bump sensors are malfunctioning. I had the same problem... The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great.
Mar 24, 2011 | iRobot Roomba 530 Robotic Vacuum
Goes in erratic circles then stops
Your bump sensors are malfunctioning... The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great. I'd recommend them.
Feb 23, 2011 | iRobot Roomba 560 Robotic Vacuum
Goes in circles only. will not start cleaning pattern.
Jan 21, 2011 | iRobot Roomba 560 Robotic Vacuum
My irobot goes around in circles
Your bump sensors are malfunctioning.. The best thing to do is order a repair kit. I ordered mine from EESolutions.ca and it worked great.
Dec 19, 2010 | iRobot Roomba 560 Robotic Vacuum
Roomba going in circles
Roomba going in circles. Called irobot and if reseting it (by taking out the battery, unplugging it from the charger, and holding down the power button for 30 seconds), didn't work, turn the roomba over, take a compressor and blow air into the front. Maybe a shop vac would also work. We cleaned out the whole thing while we were at it. And now it works just fine. The tech person at irobot was very helpful.
Mar 14, 2010 | iRobot 530 Roomba Vacuuming Robot, White...
Irobot scooba 5800 spins quickly then sets off backwards
Remove and clean all of the wheels, and make sure the cliff sensors under the bumper are clean. Tap the bumper with your hand-- really smack it a couple of times. It sounds like the Scooba believes it's stuck against an obstacle.
May 10, 2009 | iRobot 5800 Scooba Vacuum
Scooba circles and only goes backwards.
try cleaning the cliff sensors under bumper
Dec 13, 2008 | iRobot 5800 Scooba Vacuum
iRobot Roomba 560 Robotic Vacuum Logo
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
