Question about Maytag MZD2752G Side by Side Refrigerator
Ice maker water is pouring out of the ice maker. overflowing.
    Genius:
  • 1,073 Answers
Check the fill cup on the back of the ice maker for an obstruction of frozen ice, it the fill cup is frozen over then the water entering the ice maker will cascade over the frozen ice down into the freezer
if frozen melt it with a hair dryer then it will be ok
Posted on Apr 20, 2008
  • 1073 Answers
SOURCE: whirlpool icemagic
fill cup of the icemaker is frozen, take your finger and feel in the little white square cup at the rear of the ice maker, if you feel ice in it then thaw it out wit a hair drier and you are good to go
Posted on Apr 10, 2008
  • 109 Answers
SOURCE: Ice maker overflows with water
yes, in fact the icemaker does meter the amount of water delivered to the icemaker, the valve should only be energized for 7 seconds. after that the power is cut off, so if valve continues to let water flow, it's bad (might have debris from water line keeping it open. unserviceable. )
Posted on Mar 31, 2008
Bgillespie
  • 89 Answers
SOURCE: Ice maker feeding too much water and overflows
There is nothing wrong with the icemaker if infact it is "overflowing". Be carefull not to confuse "overflowing" with the ice maker leaking. Nevertheless, if the icemaker is "overflowing" with water and is still making "BIG" ice cubes then you need to replace the water valve located behind the refrigerator in the compressor department. Hint: it is blue.... Also, you may want to hire an appliance person to do this for you. Should cost around $200 to have fixed.... goodluck..
Note: If you determine that the icemaker is not "overflowing" but instead is "leaking" water then you need to replace icemaker instead of water valve. One more tid bit of information for you, Its bad when I can look at the model number and know EXCATLY what your fridge looks like! This GE fridge will give you cooling problems in the near future. Turn off during thunderstorms, too many flicker's of electricty will burn up the computer board on your fridge costing you around $400 big ones.. More from my website on GE at: http://www.houstongofarappliancerepair.com/Refrigerator.html
Posted on Dec 02, 2008
  • 356 Answers
SOURCE: Ice Maker Problem with overflowing
When the ice maker calls for water it pours for about 7 seconds if more will overflow and the problem is in the ice maker board but if pours water for nomore than 7 seconds and still overflow it means that was extra water in the ice maker ,that means that the dual water valve(located in the bottom back of the refrigerator) is leaking and needs to be replaced.
Posted on May 02, 2009
SOURCE: ice maker overfills and leaks into the ice bin.
I have had a similar problem several times. What I have found is that the ice tray coating has begun to flake off. Then, the ice sticks or partially dumps. Next more ice builds up and when the valve opens the water runs over the partially emptied tray and spills into the bin making "icebergs". The remedy is to replace the tray or if that is not possible, then, the whole icemaker. In fact, I have one down stairs to put in tomorrow. They don't seem to last more than about 4 years or so.
Posted on Jul 23, 2009
I have a kenmore 106.9552621 and the ice maker pours too much water into the ice tray causing it to overflow
Pull the front cover off the icemaker.
There is a small slotted screw on the right side.
Turn it counterclockwise to reduce water flow.
If that does not correct the problem the icemaker will have to be replaced.
Jan 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker won't stop producing ice, even when bucket is full.
the arm that swing up and down maybe able to be ajst by bending arm and the water leaking down the icemaker. is it unlevel when if fills if not unlevel is it hooked up to an r/o system if it is when was the last time filter were replaced if not, does it have a water filter has it been changed lately.
Aug 20, 2009 | Kenmore 57029 Side by Side Refrigerator
Does anyone know how to fix an ice maker?
When the ice maker calls for water it pours for about 7 seconds if more will overflow and drips into tray , but the most common problem is the dual valve that leaks even after ice maker called for water (this valve is located in the back of the fridge at the bottom where the water line is hooked up.)
Aug 09, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Water in icemaker overflows into ice cube storage box AND CAUSES ICE CUBES TO FREESE TOGETHER AND FORM BIG ICE CHUNKS. ALSO THE FULL SHUT OFF PADEL HAS ICE FORM ON TOP OF IT
Check the ice maker after it dropped the ice cubes and when it calls for water it should be pouring it for no much more than 7 seconds ,if more it overflows, in this case the module board inside the ice maker has to be replaced(or for almost the same price with parts and labor you can replaced it for a new ice maker) But if water is sitting in the ice maker all the time , the dual valve which supplies water to the ice maker is leaking and needs to be changed (it's located at the back of the fridge in the bottom behind the cover where the water line is hooked up).
Aug 05, 2009 | Refrigerators
Water leaking from ice maker
When it calls for water it should be pouring for about 7 seconds if is much more it overflows .in this case the board inside the ice maker needs to be replaced,but is water sitting in the ice maker all the time that means the dual water valve(at the back of the fridge behind the cardboard cover) is leaking and has to be changed.
Aug 03, 2009 | Whirlpool Refrigerators
May 02, 2009 | LG LRSC26925 Side by Side Refrigerator
Ice maker over flows with water
There is an orifice that controls the water flow to the ice maker . If to much water is being fed to the ice maker it will result in an overflow. You may want to check the pressure of the water system in your house.
If the overflow is being caused by a continuous feed to the ice maker your electric valve supplying the water may not be reseating after it shut off electrically. If this is your problem obtain a new valve assembly to replace it.
Apr 30, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool icemagic
Apr 08, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Maytag MZD2752G Side by Side Refrigerator Logo
359 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
