Question about Horizon Fitness Club Series CST4 Treadmill
I own a horizon club series treadmill CST 3.6. i
I own a horizon club series treadmill CST 3.6. i got an error message stating "lube belt". i got the lube for treadmill & did it acording to the instructions but it still gives same error message. is there a reset button i need to push? or something else needs to be done? thank you.
4 Suggested Answers
  • 12 Answers
SOURCE: lost lubing instructions for treadmill and tool ex wife took them
Horizon fitness sells silcone gel lubricant or many stores also carry it.
Gerritt
Serving the Twin Cities
Posted on Mar 13, 2009
SOURCE: I have a horizon fitness, Quantum II treadmill.
im having this problem too if some one could email me how to fix it @ djbense@hotmail.com
cheers
Posted on Feb 26, 2010
AJIN G
  • 6694 Answers
SOURCE: lubed belt but display still
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
Posted on May 04, 2011
How come the circuit breaker keeps tripping when i push the start button on my treadmill
Before you give up on the unit check the AC wire (while unplugged) at the way to the control panel and or motor. It could be defective somewhere along the way especially where it passes through a hole or up through metal tubing.
Mar 02, 2015 | Horizon Cst 3.5 Club Series Treadmill
What does lube bell mean
Either your treadmill has a typo or....well, it's LUBE BELT.
Go here: http://www.horizonfitness.com/support/customer-support
Download the manual for specific model and it will describe how to lube the belt. There may be a RESET procedure required to turn off the message and turn on the treadmill.
GL,
Td
Aug 12, 2014 | Horizon Fitness Horizon T90 Treadmill -...
Treadmill
Dear Sir:
PLease LUBE the deck belt, is possible the deck is worn!
2) Test the drive belt too 3) Test and lube the roller bearing 4) Lube the bearing main motor. All this parts is subjects to maintenance, see your instruction manual.
Run the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
May 03, 2012 | Horizon Fitness Horizon T101 9 Program...
How do i get the key
If you have lost it here is one place you can order a safety key for the horizon CST models. I always recommend getting two so you have a spare in case you misplace one again.
May 09, 2011 | Horizon Fitness Club Series CST4 Treadmill
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
What is meant when it shows "lube belt"?
You need to apply lube between the walking belt and the black deck surface. Most manufacturers use silicone lube. We sell a lube kit for our treadmills that includes an applicator and a bottle of liquid silicone.for around $20.
Feb 09, 2011 | Horizon Fitness Horizon T103 Treadmill ...
Screen states Lube Belt , do not have user Manual , Where are lubrication points and what type "lube" can I use ?
hi,
It is necessary to lubricate your treadmill running deck every six months or 150 miles to maintain optimal performance. Once the treadmill reaches 150 miles, the console will display the message "LUBE" or "LUBE BELT". The treadmill will not operate while the message is showing. Hold Stop for 5 seconds to suspend message for 5 miles. Your treadmill came with a bottle of lubricant which can be used for two applications. If you need lubricant, contact Horizon Fitness. Only use lubricant provided by Horizon Fitness.
• Turn off the treadmill with the on/off switch, then unplug the power
cord at the wall outlet.
• Loosen both the rear roller bolts. (For best results, place two removable
marks on both sides of the frame and note roller position). Once the
belt is loosened, take the bottle of lubricant and apply it to the entire
top surface of the running deck. Tighten both rear roller bolts
(matching up the marks for proper position) to original position. After
you have applied lubricant, plug in the power cord, insert the safety
key, start the treadmill and walk on the belt for two minutes to spread
the lubricant.
• Lubricate the air shocks with Teflon based spray.
• Once lubrication is complete, reset the console by pressing and holding 'STOP' and Speed '+' buttons for 5 seconds.
ok
Dec 26, 2010 | Horizon T91 Treadmill
Lube Belt displays on digital display how to reset or where to lube the belt.
The message "LUBE" or "LUBE BELT" scrolls across the console display window. The treadmill will not operate while the message is displayed.
Reset the console by pressing the STOP and SPEED “+” or “^” for five seconds.
Jul 28, 2010 | Horizon Exercise & Fitness
Lost lubing instructions for treadmill and tool ex wife took them
Gerritt
Mar 12, 2009 | Horizon Exercise & Fitness
Horizon Fitness Club Series CST4 Treadmill Logo
249 people viewed this question
Top Horizon Fitness Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Electro Med Services...
L Pfaff
L Pfaff
Are you a Horizon Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
