Question about KitchenAid 24 in. KUDS01DLSS Built-in Dishwasher
Has a high pitch sqeal while running (not during the drain cycle) I've had it all apart, nothing in any hoses or screens. A little coorsion on main pump motor, possible leakage? Maybe enough to make the motor load? Any thought would be appreciated. A new motor is over $100!
  • 901 Answers
Check motor bearings and replace with identical part and type. Check for water leakage through shaft to the bearings. Replace the oil seals as a full set along with bearing replacement.
Posted on Jul 14, 2010
Testimonial: "Thanks for your feedback."
Kenmore 70 Series washer - agitates and drains but does not spin
my kenmor washes and drains but does not spin, help
Jun 17, 2009 | Washing Machines
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Water leaks during drain cycle and the machine
Hi
If the water leaks during drain and spin only: A washer that leaks only during the drain/spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate this solution as "FixYa" if found useful.
Thanks
Rylee
Mar 17, 2009 | Washing Machines
Won't complete cycle
It sounds like your water pump is going bad or is bad.
Nov 08, 2008 | GE WCVH6260F Front Load Washer
Will not hold water during initial cycle
The drain hose needs to be lifted above the high fill level in washer.The easiest way to fix this is take the drain hose (if your drain hose starts from the bottom of machine and goes up)tie or strap it to the back of the washer so it cant sag or drop down and start syphoning the water.Remember the washer will drain out the water if the drain hose is lower than the amount of water in the tub.Thats why your making sure by tieing the drain hose to the highest point before it makes it way to the drain .
May 21, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
High pitch continuous sound during washing cycle. not during fill or drain
Probably have something stuck in the chopper blade. You can try to dismantle the pump and clean out the obstruction, from the inside. But sometimes it will eventually work itself out. So try and run few more cycles.
Apr 26, 2008 | Dishwashers
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Water draining is premature
In my case, I had the same problem until I realized the drain hose was not looped high enough. Once I looped the drain hose higher than the dishwasher, the problem went away and it washes dishes perfectly.
When the drain hose is installed too low, the water in the machine will only stay as high as the hose is installed because of the laws of physics.
The same applies to laundry machines - that is why the drain hose is set to drain from a higher point than the drum of the washer.
Good luck and Blessings!
Apr 26, 2017 | Kenmore 17252 Free-standing Dishwasher
KitchenAid 24 in. KUDS01DLSS Built-in Dishwasher Logo
154 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
