Question about C3 RS6652W (NEW with 1 LCD Transmitters) 2way 3Channel Vehic
My remote says no antenna. can not arm alarm.
My remote says no antenna. can not arm alarm. antenna is plugged in and cable seems ok. all fuses are good.
    New Friend:
  • 103 Answers
REPROGRAM YOUR REMOTES USING THIS PROCEDURE:
REMOTE TRANSMITTER PROGRAMMING
Enter:
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in
ON position. Within 15 seconds.
2. Push the Valet switch 2 times and hold in on the 2nd
push, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:
1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
Exit: Turn Ignition to 'OFF' position, or leave it for 15
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
Posted on Aug 13, 2010
I have an after market alarm the model number on it is 118c1123 -- other than that I do not know what it is called. Sometimes the car will not unlock when pressing the remote many times. It only does...
hi
first i would change the remote control battery's
if that works i would buy compatible remotes and reprogram via that working remote for a spare
i that didnt work
i would open the car via the key remove the cover under the dash below the steering wheel
there are normally 2 fuses to a car alarm remove the fuse on the red power led that will disable the alarm
but it will also disable the remote central locking
but you will b able to unlock the door with the key a start the car
aries
Oct 16, 2013 | Prestige Replacement Alarm Antenna...
Excalibur alarm
hi
when you press the off button you have to remove the plastic cover under the steering wheel
remove the fuse from the red wire which is the power wire to the alarm
this will disable the alarm but you will be able to use your car
aries
Sep 15, 2013 | Vehicle Parts & Accessories
Out of range issue on viper 3002
I am having this same exact problem. Have you found a solution to this problem yet?
May 16, 2010 | 3002 2 Way LED Car Alarm Keyless Entry...
Scytek 5100 RS-2W system Problem
How do you reset the remote, alarm. I have a scytek two way security alarm, remote start. I can lock and unlock my vehicle, however the remote start and alarm won't work. When I press the middle button to have the car start it just beeps, and when I lock my car it just locks it doesn't beep to let me know the alarm is on.
Please advise, do I need another alarm, or just reset it.
Claudia
Aug 14, 2009 | 5000RS-2W Remote Starter with...
Car remote lock/unlock no longer working
Check the batteries in your remote the may need replaced and if working OK check to see if you power locks work pushing the door switch. (If batteries are low they may not disengage both the alarm and the locks)
Jul 08, 2009 | 1987 Toyota Supra
Can not lock car by key remote . toyota rav 4 53 plate
If your car has an alarm with a separate remote, it is a separate system and it is probably self-arming. When you lock the doors with the key central lock, the alarm gets armed by the RAV4 being OFF and the door locking action. When you unlock the doors with the key, the alarm is still armed because the key is not comunicating with the alarm just the cars factory keyless system.
Mar 19, 2009 | 2008 Toyota RAV4
VEHICLE WONT START
Section 13-11: Anti-Theft System, Active 1998 Windstar Workshop Manual DESCRIPTION AND OPERATION Anti-Theft Alarm System NOTE: The system immediately monitors the ignition key lock cylinder upon removal of the key from the ignition. It is not necessary to arm the system for ignition key lock monitoring.
The anti-theft alarm system:
  • protects the vehicle from unauthorized entry into the passenger compartment, engine compartment and cargo area.
  • monitors the status of the ignition key lock cylinder.
  • is controlled by a remote anti-theft personality (RAP) module. The remote anti-theft personality module also controls the electronic door lock functions. Refer to Section 01-14B for more details.
  • when armed, detects unauthorized entry into the passenger compartment by using an input from the GEM module regarding the state of the door or liftgate (open or closed).
  • protects the engine compartment with a hood switch which is located on the LH cowl vent panel and is part of windshield wiper motor wiring (17A477) .
  • triggers an alarm if the ignition lock cylinder is forcibly removed from the steering column.
Once triggered, the system responds by:
  • flashing the low beam headlamps, the parklamps, rear lamps and the alarm indicator warning light emitting diode (LED).
  • sounding the horn (13832).
  • disabling the starter circuit until the system is disarmed.
Remote Anti-Theft Personality Module
  • The remote anti-theft personality module is located behind the instrument panel (04320).
  • It contains a radio receiver that receives the RF signal from the keyless entry remote transmitter (15K601) through the alarm and lock system antenna (15603) and sends the appropriate command to the power door locks, the horn relay, or the generic electronic module.
  • The remote anti-theft personality module is equipped with an internal backup power supply which holds the programmed code in memory in the event the vehicle battery is disconnected.
Remote Anti-Theft Personality Module Removal
  1. Disconnect battery ground cable (14301). Refer to Section 14-01 .
  1. Remove radio. Refer to Section 15-01 .
  1. Remove lower instrument panel center finish panel. Refer to Section 01-12 .
  1. Lower glove box.
  1. Remove two remote anti-theft personality module bracket retaining screws.
  1. Disconnect electrical connectors and alarm and lock system antenna (15603).
  1. Remove remote anti-theft personality module and bracket.
  1. Remove remote anti-theft personality module from mounting bracket.
Installation
  1. To install, follow removal procedure in reverse order.
  1. Tighten remote anti-theft personality module bracket retaining screws to 6-8 Nm (54-70 lb-in).
Components The system is composed of the following components:
  • remote anti-theft personality (RAP) module with integral antenna
  • alarm indicator LED
  • door lock cylinder switch RH, door lock cylinder switch LH
  • liftgate door lock cylinder switch (220A40)
  • hood switch (part of windshield wiper motor wiring (17A477))
  • ignition lock anti-theft switch (19A438)
The following vehicle components are also used by the anti-theft alarm system:
  • generic electronic module
  • power door lock switch (14028)
  • door open warning lamp switch (14018)
  • autolamp relay (14N089)
  • horn relay and bracket (13853) and horn (13832)
  • low beam headlamps
  • rear lamps (13404) and parking lamps (13200)
  • starter relay
  • door lock relays
  • keyless entry remote transmitter (15K601)
Disarming an Untriggered System NOTE: A perimeter alarm will "shut off" after 165 seconds, but the system is still triggered and is not disarmed.
An armed but untriggered perimeter anti-theft system can be disarmed by one of the following four events:
  1. Unlock the doors by pressing the keyless entry remote transmitter (15K601) UNLOCK button once.
  2. Unlock any door with a key.
  3. Turn ignition switch to RUN or ACC.
  4. The remote entry PANIC button will disarm the anti-theft system only when the perimeter alarm is triggered and sounding.
System Triggering NOTE: Although the remote entry PANIC alarm is not associated with the monitoring of the vehicle, the user will frequently say that the theft system was triggered when actually the keyless entry remote transmitter PANIC button was inadvertently pressed. A panic alarm will not flash the THEFT indicator.
The alarm can be triggered by the following events if the system has been armed and has not been disarmed first:
  • Open any door or liftgate.
  • Open the hood (16612) (if the hood was open when the system was armed, it must be closed before it can trigger the alarm).
  • Dislodge the ignition key lock cylinder.
  • The anti-theft system may be triggered inadvertently when the module is disconnected and then reconnected. To avoid inadvertent alarm triggering, disconnect the smaller 22-way connector first.
When the system is triggered the perimeter alarm will operate as follows: The remote anti-theft personality module will pulse the following outputs at approximately 1.3 Hz, 50 percent duty cycle for two minutes 45 seconds for North America. NOTE: Other perimeter alarms can be programmed for the system.
  • parking lamps
  • horn
  • THEFT indicator
The perimeter alarm can be retriggered, after a perimeter alarm has sounded for 165 seconds. After a perimeter alarm has timed out, if any trigger input is first seen as normal and is then seen in its trigger state, the perimeter alarm will be retriggered. The perimeter alarm can be triggered a total of three times between an arming sequence and a disarm event. An active panic alarm will be deactivated when a perimeter alarm is triggered (a perimeter alarm overrides a panic alarm).
Mar 02, 2009 | 1998 Ford Windstar
Remote locking on 1996 jaguar xj6
it sounds like the module to the alarm in the car is going bad. the sensor that detects for jags is the tied into the dash speedometer so this will need to be swapped out by the dealer only. the module will also need reprogrammed and rechecked after the reprogramming.
Nov 26, 2008 | 1996 Jaguar Xj Series
Alarm won't beep when doors are locked with key fob
hold both the lock and unlock buttons for three seconds the horn will honk and the lights will flash!
Nov 16, 2008 | 2002 Nissan Altima
C3 RS6652W (NEW with 1 LCD Transmitters) 2way 3Channel Vehic Logo
284 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
