Question about Sharp AL-1551CS Copier
My sharp AL 1551 CS is getting a L1 error code before that it was getting a E7 code. The scanner will light up and shut right back down, then it shuts itself down again.
  • 1,110 Answers
I have a tip posted here on Fixya that will help you diagnose and repair an L1 failure code on the Sharp AL series copier.
Here is the link:
http://www.fixya.com/support/r4378514-sharp_al_series_copier_l1_l_1_error_code
If this works for you then please return here and give me positive feedback.
Thanks for using Fixya today.
Posted on Jul 13, 2010
What does L 1 mean on my Sharp AL-1540CS Also E 7. Help.
The L1 is for a scanner movement failure. The scanner bar that maoves back and forth under the glass is not moving as it should. The E7 is for a scanner lamp reference failure which CAN be caused by the scanner movement failure so I would try and resolve the L1 first. I have a tip posted here at Fixya that resolves the L1 so try that first and it may fix both problems. If not just comment on this and I will try and help you resolve any remaining issues.
Here is the link to the L1 solution:
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 10, 2010 | Sharp AL-1540CS All-In-One Laser Printer
Error code on display, L1 or 1L flashing. What is
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
Jul 15, 2010 | Sharp AL 1631 Copier
Sharp al 1661 cs ..it shows System error(L1-00)
When your copier scanner is locked then show L1
Solve :Unlock position
clean all surface in scanner area
clean scanner sensor
Nov 05, 2009 | Sharp AL-1661CS All-In-One Laser Printer
Sharps AL 1530CS flashing L service code and shuts down
You didn't mention the number or code or L code.
If its L1-00 its just only the scanner, it means the scanner is locked.
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Feb 23, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Copier not working shows a flashing L on display
Sharp AL-1553 code
E7 03 Scanner position error 04 Exposure lamp blown 05 CCD calibration error 12 White level calibration error 14 Main board malfunction 15 Exposure lamp blown L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed H2 00 Fusing unit temperature error H3 00 Overheated fusing unit H4 00 The fusing unit doesn't heat up U2 01 Counter error 04 EPROM error CH blinking Dev unit is not properly installed
Nov 18, 2008 | Office Equipment & Supplies
My sharp AL-1217 greets me with a flashing "L1" error
try to clean the scanner glass, it has a white stripe at the home position of the scanner optics, clean it well.
Jul 28, 2008 | Sharp AL-1217 Copier
Sharp AL-1540 CS Error
there is a lock on the left hand side ... make sure it is in the unlock position.
Mar 10, 2008 | Computers & Internet
440 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
