Question about Husqvarna 28cc Gas Line Trimmer
125e edger runs 5 minutes when it ldles it dies but will restart
The gas line was rotten, replaced with new gas line. was told by lawn mower shop the the ethanol in gas is causing rubber to detoriate. Could it be the diaphram is bad also maybe the gas cap causing a vapor lock.
  • 211 Answers
SOURCE: Brand new Husqvarna 340e chain saw dies after 10 to 20 minutes.
Hi
Find out where is its airating sistem.It equalises the presure between the interior and exterior of the gas tank.Disassembly and clean it.
regards savumihai71
Posted on Dec 05, 2008
  • 7 Answers
SOURCE: I have a 15HP YTH 1542 riding lawn mower. It has a
check wires for short to ground
Posted on Jun 25, 2009
  • 218 Answers
SOURCE: Mower won't start
Hi..my name is Keith and some mowers do have a fuel pump..if the fuel tank is lower than the carb...and they are operated by vacuum thats created in the crankcase and they are usually located on the carb...but i would check to see if some trash didnt stop up your fuel line..also..if you have old gas in it..a lawn mower engine doesnt or wont run on it..i hope this has helped..if not..write me back
Posted on Jul 01, 2009
SOURCE: I have a YTH1542 husqvarna riding mower. Will not stay running
make sure the small vent hole on top of the gas cap is not clogged. Mine did the same thing and then I found mine was packed with dirt.
Posted on Jul 20, 2009
AUTODOC01
  • 216 Answers
SOURCE: Edger #125E stalls after 3-4 second of starting.
sounds as thou the carb plate gaskets are torn these are sandwiched on eithewr side of the carb and they let it pump/**** the fuel a rebuild kit will have theses new gaskets depending on how mech/ inclined you are you may just want to let a shop fix it $75?? thats what i charge
Posted on Aug 26, 2009
Toro lawn mower troubleshooting
Clean the carb, gas tank and fuel line (s). Replace air filter with a new one, I wouldn't recommend that you run it without the filter because that allows dirt and grass debri to enter the carb, fuel line and gas tank.
Replace the plug with a new one that is recommended for your engine.
Check oil level.
Other option is lawn mower repair shop....
Hope this helps, I had the same problem.
May 11, 2013 | Garden
2008 125E edger starts and runs for a bit (10-30 sec) then stalls. New ZAMA crab, new fuel line and filter pick up, fresh gas in clean tank. Any ideas? Carl
Check ignition module and the timing gap between the ignition module and the flywheel. Does it also have good compression.?
May 25, 2011 | Husqvarna Garden
CRAFTSMAN WEEDWACKER 316-791860, WILL NOT START. HAS SPARK, FUEL LINES FILL UP, WAS RUNNING FINE, DIED, STARTED NEXT AM, RAN 5 MINS THEN DIED AND WOULDN'T RESTART
Two things which may be the problem: 1) carb need to be rebuilt or replaced, and 2) you need a new spark plug. The carb with shipping is around $50.00 from sears ( http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Grass-trimmer-weed-wacker-Parts/Model-3167918602008/0247/1503820/P0805032/00001?blt=06&prst=&shdMod= ) A sparkplug can be had at any small engine repair shop and most auto parts stores for less than $5.00 Start with the cheap solution... Also make certain you have fresh gas and that the oil mix is correct.
Apr 07, 2011 | Craftsman Convertible 25cc. Gas Line...
Edger #125E stalls after 3-4 second of starting. Gas is new, mixture is correct, spark plug is new
Aug 26, 2009 | Garden
Weed eater starts, runs 5 min. then cuts off
The gas cap may be clogged.
The next time you run the trimmer and it starts to die, loosen the gas cap. If it starts running again, then you know that it's a clogged gas cap.
You may also check the air breather, it may be dirty as well.
Just let me know if you need further assistance.
Jim
Jun 28, 2009 | Poulan Pe550 Gas Edger
Gas lines rotten replaced new but not sure in right place
The short one goes to the primer bulb and the long one, with the filter in the tank, goes to the carb.
Jim
Jun 05, 2009 | Ryobi Garden
Trimmer puking gas out carb!
You could have a bad pump daiphram, which is holding the needle valve open. You can try rebuilding carb.or just replace carb. that is the easiest way.
May 16, 2009 | Garden
Husqvarna 28cc Gas Line Trimmer Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
