Question about Toshiba Portege M700-S7044X Notebook
No sound speakers or headset driver install
No sound speakers or headset driver install device working properly in device manager
    Novelist:
    Champion:
  • 226 Answers
Firstly check the volume is not low or muted on both windows and the speakers. In windows click the speaker icon in the bottom right of your screen, check the volume is turned up. Then click mixer or advanced and check that all volumes are turned up.
If using a laptop, check that the hotkey control for volume is on. You will see an audio icon on one of your ‘F’ keys, hold the Fn button located near the ctrl and press the volume function key.
Next open Device Manager from Control Panel and check there are no yellow exclamation marks on any drivers. If there are then you need a new driver.
If you are still having issues the sound card may be faulty, this is usually integrated into the motherboard. In a desktop PC you could buy a new PCI soundcard if you have a spare PCI slot in your machine.
You need to goto the manufacturers website, find their support section and there should be a list of drivers for your specific machine. Installing these should resolve your problem. I have a list of links to most manufacturers drivers on my website.
Hope this helps,
www.PuterCare.com
Posted on Jul 14, 2010
My desktop speakers not working but cable all plugged in and audio device working.
Hi tamjidzaee ,
Please follow the below steps to solve the problem that you have mentioned :-
  1. Check if the sound driver has been installed in your system, you can check this by going in the control panel's sound and audio devices option , if you find all options disabled and it reads no playback devices and no recording devices, then you have no sound driver installed. Therefore in this case you would require to install your sound driver using your motherboard cd.
  2. If you see your sound driver is installed in the audio options of the control panel and you also see the sound driver's name , then you need to check the volume in the volume settings to check if it has not been muted accidentally , if it has been muted , then please un mute it and things should work fine.
  3. A good idea would be use a headset and plug it into your motherboard in the slot where the speakers output is received , mostly the green round slot.
  4. If you have a front head phone option then you can try using it as well, if the headphone or headset works fine, then we are sure about two , things that the driver is installed successfully and there is a sound output from the audio output slots.
  5. Now, when you have checked the sound via headsets then you need to make sure that you are connecting your speakers in the green slot or the same slot which is working for headsets, remember headsets can be used to check the output in the back panel of your cabinet as well as front panel of your cabinet.
  6. Also check if there is any fuse in your speaker which has blown up so that you can replace it and it would start working, check the power cables and confirm they are not properly connected.
If the speakers work fine , then it's all ok , but if they don't you need to replace the speakers by checking them with your friend's pc or any other audio output device.
Hope his helps.
May 11, 2011 | Computers & Internet
I cant hear anything from my laptop acer3682wxci eventhough without hedset pls ..help to work this out ....thanks a lot....
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Apr 14, 2011 | Computers & Internet
In my Destop system Audio Sound is not coming
Check the device manager for any conflicts with the drivers. There would be "Other drivers" listed if there was any drivers that were not installed correctly. If there is any listed try right clicking on them and selecting to reinstall drivers.
To get to the device manager:
Right click on my computer or Computer > select properties > then click on hardware tab on top then device manager or click on device manager link.
Computer Repair - Support
www.jdtechsource.com
Oct 29, 2010 | Computers & Internet
Speakers is not working properly
You can first check for a speaker icon in your system tray (right bottom part of the screen). If you can see it, that means the sound card is properly installed in your Device Manager. (Control Panel, Device Manager). Click on the speaker icon to check whether your speaker is muted or the volume is lowered, make the necessary adjustments. If it case you don't see any speaker icon, it's whether your sound card is defective or not properly configures in the Device Manage. Go to your device manager and reinstall driver.
Good luck.
TedMac
Sep 18, 2010 | Acer Computers & Internet
Help guyz, i have my nec versapro va12j laptop reformatted lately but after doing it there no sound any more coming out from the speaker even using a headset. i had already checked on device manager...
OK you may indeed have the driver installed, but do you have your sound manager installed? Often you need a sound manager too. Again you need to install the whole package, and NOT just the driver itself. Usually just the driver gets installed if it is detected and windows just installs the driver only, and not the management software. You will need to obtain this installer to do this.
http://support.necam.com/mobilesolutions/hardware/notebooks/versavx/
website for drivers above.
Jul 21, 2010 | NEC Versa VX Notebook
Speakers are plugged in properly but won't work
Hi Rachelle,
First of all, make sure that the sound is not accidentally muted.
If the sounds seem to play, it means that your speaker cables are faulty or have some kind of break in them. Or, your speakers or the electronics inside them developed some kind of fault.
Unplug the speakers and the speaker cables and test them on another computer. If they work fine on another computer, the problem could be your sound drivers. You could also test the sounds, using a headphone in place of the speakers. If you can hear the sounds fine with the headphones, the problem is with the speakers or the cables.
This may be less likely since the sounds seem to play, but it's still possible that your sound driver is incorrect or not the one meant for your sound card.
Start the Device Manager (Right-click My Computer -> Properties -> Hardware -> Device Manager) and under the "Sound, video and game controllers", see that the sound driver is listed.
Double click the item in that list that contains the word "audio device" in its name. Does Device Manager say that the device is working properly? If Device Manager says that the audio device is not working properly, or if there is a yellow exclamation mark next to the device, or if it says that the drivers are not installed for this device, install the drivers from the CDs or from the laptop manufacturer's website. However, there's an easier way to do this, as given below.
Here's the easy way to get or update your sound drivers:
You could try to use this driver scanning tool, which scans the computer for needed drivers and has an option to automatically retrieve them for you.
You can download this free tool from here or directly from this link.
After you have downloaded the above file, double-click on it and follow the simple steps to install it. Then, when it asks if you want to run it, just answer yes. This is easier than manually searching, downloading and installing the drivers.
If, after trying with the above method, sound still can't be heard, you can try with the System Restore. To know more about System Restore, go to this link.
If none of the above methods worked, pull out your sound card and test it in another computer. You can also try re-installing Windows and lastly try another sound card, if it still fails to work.
Hope that helps,
Regards,
Raspal
Mar 21, 2010 | Altec Lansing VS4121 Computer Speakers
The sound is not working on the monitor.
  • check the system - device manager for sound adapter, checks for any markings on the device red x, yellow ? , or !
  • uninstall and re-install the device driver, or
  • install the sound drivers
  • use a headset or external speaker if it works the internal speaker needs replacement
Apr 14, 2009 | Computers & Internet
No sound and voice recording device;not able to get the right sound driver
  • NO SOUND,NO AUDIO
  • check the system - device manager for sound and audio adapter, checks for any markings on the device red x, yellow ? , or ! checks for any sound blaster if not detected (removed it and install back)
  • uninstall and re-install the sound and audio device driver, or
Toshiba Portege M700-S7044X Notebook Logo
125 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
