Question about Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
My oven wont heat up? - Hotpoint SY36 Style Line Stainless Steel Electric Single Oven
  • Hotpoint Master
  • 3,051 Answers
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Posted on Jul 14, 2010
Kenmore duel fuel oven wont heat
I take it this will be an electric oven. If so the likely hood is that the oven element has blown and will need replacing. Normally when elements short they will trip the houses RCD (once only normally)
Apr 10, 2014 | Ovens
I have a GE microwave/convection oven that the lower oven wont heat, fan comes on top microwave works but the oven wont heat
First reset your breaker, then check your wiring in the back of the oven. You may have just a wire loose.
Feb 24, 2013 | GE Profile JT965 Electric Double Oven
MEW 5527DDB oven wont heat up. bake button works but oven will not heat to any temp setting>
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 20, 2011 | Ovens
Bake wont heat in oven
heatman101
Jan 15, 2011 | Ovens
The oven wont heat over 105 degrees
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
heatman101
Nov 23, 2010 | Maytag MEW6530DDS Stainless Steel Electric...
The oven wont heat up and i beleive there are two fans but the one at th back wont heat up
If the fan is working o/k then thit is usually the oven element that is faulty.
Located at rear of oven compartment behind a removeable cover.
Sep 28, 2010 | Kuppersbusch EEB65000MX Electric Single...
MY OVEN wont heat up. its takes at least an hour
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 28, 2010 | Ovens
More than likely a faulty oven elementr.
This is located at the reae of the inner oven compartment behind a removeable cover.
Apr 09, 2010 | Belling XOU174 Electric Single Oven
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
Hotpoint SY36 Style Line Stainless Steel Electric Single Oven Logo
705 people viewed this question
Top Hotpoint Ovens Experts
Colin Stickland
Colin Stickland
Charles T Nevin
Charles T Nevin
Jacques Valiquette
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
