Im working wiy a Ricoh aficio 2045, and its printing blank both copy and print. when i removed the dv unit i noticed the steel mag roller isnt pulling as much developer oin the roller its very light and seems umagnitized could this cause the blank print and how do i fix this Thanks
  • 4,281 Answers
First make sure your ink cartridges are fine and not empty.
If ink cartridges are fine then you need to check fuser assembely there should be problem heat plate inside fuser assembely .
Try with another ink cartridges then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on Jul 13, 2010
Ricoh Aficio MP2000Le copier drum serviced and cleaned after prints blank pages. pls help thanks a lot.
if you replace drum and blade. You left off developer couplier goes on mag roller. Easy to do look at end of developer unit that goes in first and see if is missing. If that is on then inside copier is a spring that makes contact with charge roller make sure it didn't get bent.
Jan 04, 2018 | Ricoh Office Equipment & Supplies
We have Ricoh Aficio 1018 , machine functions , gives print without the matter printed
Sounds like a bad photoconductor unit (PCU), or problem with the transfer roller which is mouned inside the right side door. The PCU consists of 2 main sections; the development unit, with developer ang mag roll (on the bottom) and drum, with charge roller and cleaning blade (on the top). If the gears that turn the mag roll go bad, toner will not be applied to the charged drum. If the transfer roller is missing or not being charged the image will not be transferred to the paper. Check the connector from the copier to the right side door and the leaf springs that carry the charge from that wire and contact the transfer roller.
Sep 07, 2012 | Ricoh Aficio 1018 Printer
My ricoh MP 2000 is printing blank documents when a print job is sent
is the copying ok? if yes then reload the print driver .it is causing the problem.if copying is also blankthen check the processing unit. the charge roller might be facing some problem or the developer gears might be worn out .
Sep 28, 2011 | Ricoh Aficio MP 2000 Black and White...
Im using ricoh 2045..Paper jam occurs at point A1 (the lever the drops to remove the paper) . I have noticed roller A1 and registration roller doesn't rotate. When i remove the paper and close the covers...
this is not a thought I am 100% sure and give you the correct solution:
problem with the paper feeding section is dusty or due to developer drooping
1. Open the developer unit and check the rear side developer unit bush one or two bush are faulty
and drop the developer.
2. remove all paper trays with remove the four each screws
3. Remove the toner collection bottle
4. Remove the right side cover.
5. Remove paper left roller plate.(show in the picture)
6. Now remove the first tray paper feeding section(is a complete unit included paper feed rollers motor and clutch and gear section)
7. Clean the drooped developer from all gears and roller and motor section
8. remove the second and third tray paper feeding section and doing the same.
9. now fix it all
10. replace developer unit bush witch are faulty or if you don't have yet cut a plastic sheet and past the upper side of first paper feeding unit gears witch are don't disturb the paper path and stop the developer drooping on the gear good_help.pnggood_help_0.png
Jan 27, 2011 | Ricoh Aficio 450 Copier
Ricoh 1224c prints on left side only - Blank on right side
well if its just on the black then it might be the black drum see if it does the same on the color from copying and printing. If it does the same in color then its not the drums it may be the developers, but you wont know untill you test the color if it only happens in black and white its definitely a problem with the drum.
Mar 25, 2010 | Ricoh Aficio 1232C Color Copier
What is the defrance between aficho 450 & 2045
the aficio 2045 is new version of the aficio 450.
so on the 2045 if you have installed printer/scanner option you can scan directly to folder on your computer or you can scan and sent documents to email addresses ,also the print or copy is much more quality.
you have a touch screen control panel.
mainly the look is the same with some new design on the look, but also some staff which has bean detected as problem on the aficio 350 now are corrected and improved.
Dec 13, 2009 | Ricoh Aficio 450 Copier
Ok WHile I waited for the reset directions I took the fuser and roller assemblies off the 2035 I had and put them on this 2045. Still had the error. So I put them back on the 2035. Put the originals back...
Hello sir; I don't know what's the problem of the machine, anyway I can give you reset procedure; Press "clear/mode" "107" and press and hold "clear/stop" key for 3 sec.until screen change, then turn off the power and back on again.
Nov 13, 2009 | Ricoh Aficio 450 Copier
Copier Prints Blank Pages
My copier Mita DC 1560 prints blank. Any solution?
May 07, 2009 | Ricoh Aficio 2015 Copier
k24674
jasbo
jasbo
